chrisarnt Samba Member
Joined: November 28, 2005 Posts: 541 Location: New Jersey
Posted: Tue Feb 07, 2017 10:05 am Post subject: A question for you Porsche people about 914 motor starter/config |
Does anyone know if the starter on this 1974 2.0 engine has a starter with the bendix clutch pac buried in the starter?
the whole point of this question is to see if we can put this motor into a baja with minimal issues. I've already discussed the pressure plate issues, but then someone mentioned the starter issue.
This is from another thread but thought I would post here also.
If this helps:
Engine code is GA014844
an online source says the trans code is "HA 01 01 4- HA 31 07 4"
When I do a quick search on a standard parts website the description of the starter has the statement "Direct drive starter which has no internal gear set. " Maybe this answers the Q. I don't know.
Original thread is http://www.thesamba.com/vw/forum/viewtopic.php?p=8344264#8344264
Pic of the engine code:
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Tue Feb 07, 2017 10:16 am Post subject: Re: A question for you Porsche people about 914 motor starter/config |
I will have to dig for the information....but whats internal to the starter mechanism is not the big issue IIRC.
The issue with the 914 is the 914 specific flywheel whose ring gear is spaced about 5mm differently as compared to the bus and 411/412....so if its going in a 914....with a 914 forged flywheel and with a 914 transmission...you need the 914 starter.
If its going in a bus or 411/412....or a bug...you just need the standard buss starter and flywheel. Ray |
Posted: Tue Feb 07, 2017 10:35 am Post subject: Re: A question for you Porsche people about 914 motor starter/config |
raygreenwood wrote: |
Thank you.
it would be going into a 71 Baja with the stock transmission and someone raised the starter issue in the other thread. |
Posted: Tue Feb 07, 2017 12:50 pm Post subject: Re: A question for you Porsche people about 914 motor starter/config |
chrisarnt wrote: |
Thank you.
Yes.....though the stock 914 2.0 starter "may" have an internal bendix arrangement.....that is not what makes it different enough that the car cares. Its the flywheel ring gear spacing.
Since the engine cases are largely all the same.....just use a bus flywheel and starter. If you have a 914 2.0 starter.....and it works......you can probably sell it for enough to buy the flywheel and starter you need. Ray |
Posted: Thu Feb 09, 2017 7:27 am Post subject: Re: A question for you Porsche people about 914 motor starter/config |
According to the PO this was installed in his 1973 camp mobile
When he purchased the vehical.
He swapped this out for a 1.7 bus motor when he roasted an exhaust valve.
At that time he took the starter and carbs off the 2.0 to install in the 1.7
So... does that explain the starter flywheel situation?
I'm guessing these clues will tell me if I need a. Is starter or a Porsche starter.
And yes. I realize is just a matter of the parts number.
Many thanks in advance |
Posted: Thu Feb 09, 2017 8:32 am Post subject: Re: A question for you Porsche people about 914 motor starter/config |
chrisarnt wrote: |
Post a picture of the flywheel you have.
Here are some notes.
http://www.shoptalkforums.com/viewtopic.php?t=4407
Really....just get a bus flywheel for 210 or 215mm . Also if you Google 914 flywheel versus bus differences you will see lots of info.
Ray |
Posted: Thu Feb 09, 2017 9:11 am Post subject: Re: A question for you Porsche people about 914 motor starter/config |
Ok. Got it |
Posted: Wed Feb 15, 2017 5:29 am Post subject: Re: A question for you Porsche people about 914 motor starter/config |
chrisarnt wrote: |
Ray |
Ok. So here is a pic of the flywheel.... it is not there.
So does that mean I can slap some bug stuff on there and call it a day?
I realize this is totally wishful thinking.
Bleyseng Samba Member
Posted: Wed Feb 15, 2017 8:16 am Post subject: Re: A question for you Porsche people about 914 motor starter/config |
No you can't slap in a bug flywheel as they are for Type 1's. Get a BUS on 210 or 215 flywheel and then the right pressure plate for it along with clutch disc. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Wed Feb 15, 2017 8:38 am Post subject: Re: A question for you Porsche people about 914 motor starter/config |
Wishful thinking |
Posted: Wed Feb 15, 2017 8:42 am Post subject: Re: A question for you Porsche people about 914 motor starter/config |
Bleyseng wrote: |
No you can't slap in a bug flywheel as they are for Type 1's. Get a BUS on 210 or 215 flywheel and then the right pressure plate for it along with clutch disc. |
What do you think about dual H40s for carbs?
I'm on a budget and want power but can't spring for fancy carbs yet |
