Albertoprop17 Samba Member
Joined: March 15, 2016 Posts: 196 Location: Valencia (Spain)
Posted: Wed Feb 08, 2017 7:56 am Post subject: 1500 'S' daily upgrades |
Hi, I have a '63 notchback and I want to squeeze its engine a bit. What can I do? I think about W110 cam, 4 to 1 header, lightened flywheel...
Can I increase bore and/or stroke this engine? I want a reliable engine with good mpg.
I'm waiting for your answers
Cheers
Alberto |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Wed Feb 08, 2017 8:43 am Post subject: Re: 1500 'S' daily upgrades |
You have a stock 1500 S engine? I would find a 1600 type 3 donor to make something from scratch, the 1500 is close to blowing up as it is: 8.5:1 C/R with the stock cam, essentially a 1200 case & 6mm oil pump studs, etc.. 1500 rods, and twin carbs, enough to get you in trouble as is.
that same engine with a w-110 will be a miserable wreck!!
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
you can increase the bore/stroke of any engine.
it just depends on how much work you want to do.
which, if you want the benefits of a W110 you're going to need to do plenty.
like bigger valves, dual carbs and counterweighted crank.
if you don't want to get into a bunch of machine work and/or different heads, think about a smaller cam like a W100 or a "cheater".
87/88mm pistons/cylinders can be done with minimal machine work.
research, grasshopper _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Wed Feb 08, 2017 9:13 am Post subject: Re: 1500 'S' daily upgrades |
borninabus wrote: |
research, grasshopper |
There is not much out there about hopping up early type 3's, but I think it's you that may benefit from doing some research. 1500S already has dual carbs, bigger valves, and bubble pistons.
87/88 in a type 3? 100 cam in a 1500S? Ok grasshopper...
Alberto, you probably should go to the Type 3 forum, where people know about the early cars better than here
http://www.thesamba.com/vw/forum/viewforum.php?f=6 _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Wed Feb 08, 2017 10:33 am Post subject: Re: 1500 'S' daily upgrades |
Erik G wrote: |
borninabus wrote: |
http://www.thesamba.com/vw/forum/viewforum.php?f=6 |
Okey, thanks to all!! |
Posted: Wed Feb 08, 2017 1:36 pm Post subject: Re: 1500 'S' daily upgrades |
The 1500S is one of the SWEETEST stock engines there is, I would find it worthwhile to build it back up, really hard to source the hi-comp pistons, though.
I rebuilt mine on a stock 1600 case, though, really much better. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
