Buggeee Samba Member
Joined: December 22, 2016 Posts: 4419 Location: Stuck in Ohio
Posted: Thu Apr 20, 2017 4:25 pm Post subject: Re: Buggeee's 1972 Super Beetle |
Buggeee wrote: |
bnam wrote: |
Did you put foam on the Hoover bit and over the oil cooler? Foam is needed in those locations as well. |
Yes on the cooler, No on the HB. I'll get on it. Thx |
Awww Bnam, this is going to be a PITA. I just looked. Thats backing out the Rubic's Cube again! Deep breath. Ok. I'll be tearing back in there again for a yet to be disclosed adventure so I'll hit that HB foam too. Thank you again for watching the details. It's how I want to roll this build and you can tell.
HEY PEEPS. Pic of the Hoover bit area. Waz da hole for? Should this have had a rubber plug or something? Should I block it up?
_________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
72 Super Duper http://www.thesamba.com/vw/forum/viewtopic.php?t=672387
(adopted out) 61 Turkis Pile https://www.thesamba.com/vw/forum/viewtopic.php?t=728764
SnowDaySyncro wrote: |
Every setback is an opportunity to learn stuff and to buy new tools. |
vamram Samba Member
Posted: Thu Apr 20, 2017 5:21 pm Post subject: Re: Buggeee's 1972 Super Beetle |
I believe that hole is where the accelerator's metal guide tube goes thru, from the back where the carb sits and thru that and then the front engine tin. From the factory, it had a hard plastic cover that would slide down and snug the accelerator tube. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
bnam Samba Member
Joined: July 02, 2006 Posts: 2936 Location: El Dorado Hills CA/ Bangalore, India
Rome Samba Member
Joined: June 02, 2004 Posts: 9653 Location: Pearl River, NY
Posted: Thu Apr 20, 2017 5:54 pm Post subject: Re: Buggeee's 1972 Super Beetle |
Aargh- you have your generator positioned incorrectly! It needs to be rotated 1/4 turn clockwise. The ground screw will then point nearly straight up, and the two terminals for the generator cables will point to approx. "2:00". Compare with your factory manual. I'm nearly certain that all you need to do is to loosen your strap and push it forward, remove the four M6 bolts from the backing plate, break your sealant grip and rotate the backing plate (with gen attached) 1/4 turn. No, VW did not put sealant on that joint. You had the gen strap oriented correctly.
Yours:
Correct position (from gallery; this engine is being prepped for dual carbs, therefore the center linkage behind the fuel pump)-
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Thu Apr 20, 2017 6:19 pm Post subject: Re: Buggeee's 1972 Super Beetle |
Rome wrote: |
Aargh- you have your generator positioned incorrectly! It needs to be rotated 1/4 turn clockwise. The ground screw will then point nearly straight up, and the two terminals for the generator cables will point to approx. "2:00". |
Yes, do what Rome says. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
TX-73 Samba Member
Posted: Thu Apr 20, 2017 6:25 pm Post subject: Re: Buggeee's 1972 Super Beetle |
I was glad to see that your Adventure in Curil turned out much better the second time. Mr Duncan helped me rebuild my engine and he's a fanatic about details like that. Even with a seemingly microscopic application of the stuff I was really surprised to still find some bits of it in the oil sump screen after the initial start-up. So just a mention to check that after the successful first start of your powerplant.
Very nice read overall. _________________ My 1973 Standard Beetle Build SOLD
Click to view image |
sb001 Samba Member
Posted: Thu Apr 20, 2017 9:08 pm Post subject: Re: Buggeee's 1972 Super Beetle |
Buggeee is going to have his newly rebuilt 72 super engine up and running before me--and he hasn't even had his car as long!
I'll just blame it on me having autostick stuff to deal with.
Looks fantastic- great job! _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
jerrybromley Samba Member
Joined: August 06, 2016 Posts: 124 Location: Michigan
Posted: Thu May 04, 2017 5:21 am Post subject: Re: Buggeee's 1972 Super Beetle |
I have rebuilt and or modified many a V-8 ,but after buying my first Beetle the motor looked intimidating to me ( jugs instead of cylinders , loose studs splitting cases and all that air cooling stuff, ect.) Your post does a fantastic job of reducing my fear level. Thanks for a GREAT thread _________________ http://www.thesamba.com/vw/forum/viewtopic.php?t=670629&highlight= |
Posted: Thu May 04, 2017 12:00 pm Post subject: Re: Buggeee's 1972 Super Beetle |
jerrybromley wrote: |
...Your post does a fantastic job of reducing my fear level. Thanks for a GREAT thread |
Glad its reduced your fear... I think its increased mine!!! The whole thing is a lot of fun, but my goodness it is such an opportunity for growth that I am not sure I'll survive the process. (Think Conan's wheel of pain). It may break me before its over but I'm not out yet. Thank you for the motivation Jerry!
Two steps forward, one step back. Its better than one forward and then two back right? I've got some good progress going now and am looking forward to posting it all up when I get stalled on the wrenching. Right know its all go, go, go down there.
Also, I have something to add to the whole Samba thing, I do believe, rather than just the monkey see, monkey do that I've been posting up here so far. It has to do with marrying the stock motor culture with the dual-carb culture. Its a very small, but I do believe necessary, step in bridging the divide. (I have made up imaginary camps of dubbers in my mind and there is a stock motor culture and dual-carb culture in there that I identify with and long to reconcile with my little made up work-around that I will get to later....)
BTW on where I am in the posting process so far, there have been some views but no guesses yet on the reason for the dial back to the gasket shots and the new tool comment... So I'll blow my lunch hour closing the boards on that. The envelope please......
Its a 75 amp alternator!!! Worth the wait wasn't it? I thought so. I'm just as excited as you are. The stock generator puts out 30 amps, the stock later-model alternator gives you 50 or so but this one is a whopping 75 amps. Now what to do with all that power....
In my younger days I'd definitely be thinking mind-melting quadraphonic audio system or whatever but in my graying slide to the grave my imagination is drifting towards Rally lighting for those night drives. Rally Rat anyone? We'll see, I'm a long way from body work right now.
Well, of course, you can't just swap one right in. To go alternator you also need one of these (its an alternator sized oil filler stand):
And if you get one of those, you'll need one of these (it's a smaller "alternator" fuel pump that can be pulled out even with the smaller clearance of the alternator sized oil filler stand):
Oh, and with one of those, you'll need one of these (its a shorter "alternator fuel pump" rod):
And to think this was made necessary by you kind folks pointing out that I needed a piece of foam on my Hoover Bit and a twist to my generator orientation. Thanks alot Bnam and Rome! At least I'm not ending up in one of those "whats wrong with this picture" threads. Yet, anyway. Here you go Bnam, this one's for you:
So whats with the new tool you ask? Glad you did. Here's the oil-filler neck nut removal tool in action, about to re-install the oil filler neck onto the alternator sized oil filler stand.
Ooooo.... here's another don't throw this away you're gonna need it shot (its the gasket between the oil filler neck and the stand, which I re-furbished with a little degreaser and a thin film of Curil-T). Of course I noticed it for the first time on the floor next to the old stand right after I finished installing the neck on the new one without it. New tools get more use than they should sometimes
As long as I had easy access, I dropped in my Coil re-location bracket. The Empi 34 dual carbs that came with this project bug have a linkage that goes across the face of the fan shroud, so the Coil can't live there anymore. Sorry Coil, but don't worry you'll be snug as a bug in a rug in your new home. Here's the bed for it:
And it goes right here, slid onto the case stud that sticks out this side for some reason and one of the fuel pump studs, then tighten those two nuts down and its not going anywhere. The threaded holes in the face of it mimic the mounting holes that are on the shroud so the same Coil strap is still used.
Boy its a tight fit down there now. My distributor really only gives me room to adjust timing when its in there like this. I'll pay attention to what wire is acting as No. 1 now that I won't be following the mark on the distributor body for that.
Who would have thought that there were all these parts in the backing plate for the generator/alternator????
Now, I am a glutton for punishment so also took this as an opportunity to actually get a hammer finish out of the antique pewter hammer finish Rustoleum rattle can. Last time I did light coats like every other rattle can project and just got a satin silver out of it.
This time I read the instructions. (This was more difficult than you think. For some reason they are using much smaller letters these days. When I was a kid painting go-carts the letters were much, much larger). So get this... It say's one thick coat! Mmmm.... if a little is good than a lot is better, it got one more, multiple can-emptying, thick, gooey, hold-your-breath what am I doing now coat of antique pewter hammer finish Rustoleum. Boy was that fun to watch set up. And here you go....
My bug motor is hammered.... tee hee... It would say it loves me anyway, its not just the paint talking.
joey1320 Samba Member
Joined: September 12, 2006 Posts: 2325 Location: Cleveland, OH
FaanP Samba Member
Joined: May 03, 2017 Posts: 99 Location: South Africa
Posted: Thu May 04, 2017 11:03 pm Post subject: Re: Buggeee's 1972 Super Beetle |
Awesome job there .... you are really doing a proper build |
Posted: Fri May 05, 2017 7:41 am Post subject: Re: Buggeee's 1972 Super Beetle |
Here is a little tour of the underside, where I installed an OG thermostat to work those flaps shown in earlier posts. When the thermostat is cold, it contracts and pulls the rod down from the flaps, closing them so air is not blown over the cylinders, as discussed above, and it warms up quick avoiding wear on the bearings. Then when hot it begins expanding to allow the spring to pull the flaps open, steering the air over the cylinders and, eventually, directing it over the heads where it is needed most.
I learned on the thermostats that the new style Mexican ones fail in the closed position, meaning when they fail they they contract and hold the flaps totally closed and overheat your engine. The OG thermostat fails in the open position, meaning it if it fails it expands and holds the flaps wide open. In that position, it won't warm up as fast when the car is cold but it won't overheat the car when its running.
I found a used OG thermostat and have seen them here on the Samba classifieds. You can get a new American made replica of the German from Awesome Powdercoat, but they are not cheap. Here is a link from them that explains all about the different kinds:
http://www.awesomepowdercoat.com/thermostat_new_used_rebuilt.html
So, uuuurrrrgh, tip the motor onto its flywheel because I have a wood cart instead of an engine stand (they both roll around you know). Here is the little threaded end of the flap rod sticking through the necessary head-tin piece that keeps the air going through the fins rather than just flowing through the passage there (Later I painted that scratch with a little brush btw - because that's how I roll ):
And here is the OG brass (I think) accordion thermostat. It's sealed and permanently filled with a couple of drops of rubbing alcohol or something, that vaporizes at the right temperature, allowing the accordion to expand. When it cools, the vapor condenses into droplets, creating a vacuum in there that pulls the accordion into the closed position. I cleaned it with a soft nylon brush but not scrubbed. These things feel really delicate...
I put a little grease on the threads so it wouldn't seize on there and just screwed on. Then I started hanging the bracket.
The bracket has an oblong mounting hole so it can be slid, adjusted, up and down. I turned it into position and slid it until it just barely contacted the top of the thermostat.
The spring is holding the flaps in the open position right now so this is exactly where it needs to end up when it is fully expanded. I tightened the bracket to the case.
Then, after taking a little breath. I played with pulling the thermostat down to its seated position and then letting it rise back up by the spring of the flaps to see if it traveled smoothly. It did not. I had to remove, massage, and reinstall the bracket and that head-tin piece a few times until the grove in the top of the bracket was positioned just right so the top of the thermostat and the rod did not scrape on those other parts at any point in the travel. Finessed to a precision mechanism, I held the thermostat down into the bracket and installed the bolt into it from the bottom.
Now I put the sleds, or toboggans, or bottom tins on while I had access. Once the heater boxes are on the outside of these, the sleds create a tunnel where the air blows down over the cylinders and heads and then back out the rear of the car.
Here is a blurry picture of the thermostat sitting restfully in its little tunnel, waiting patiently for the temperature of the air rushing over it to tell it what to do.
Posted: Thu May 11, 2017 3:42 pm Post subject: Re: Buggeee's 1972 Super Beetle |
And here is exactly why I decided to do what I am about to do to some old OG heater boxes I got from one of our friends in the Samba classifieds, rather than buy new reproductions, just look at all those fins inside!
It's like a radiator in an old house. It gets COLD in Ohio. There are lots of DRY, COLD days inOhio that will be fine for driving a classic car IF IT HAS HEAT!!!
Here's a view of the inside:
Eric&Barb wrote: |
Those fins are on the outside.
Corrugations on the inside of the stock 60 mm outlet HEs make a big difference in surface area to let the exhaust cool down against.
Can you figure out which is the Dansk repro HE and OG VW? |
So here is what I'm starting with, after a good power washing:
Here's what I'm going to mate them with - an NOS German muffler:
So to get them ready for their bridal night, I soak them for like four (4) hours in a whole bottle of this powder stuff I found in my linen closet and dumped into a tub full of water at my curb:
That smelled like sulfur but who knows what kind of acid it really is. Don't use Muriatic Acid even though lots of people swear by it. It binds with the iron molecules in a way that accelerates their degradation and rusting, "flash rust". As if I know. I don't I just read the h e double hockey sticks out of it so I can Cliff Clavin (verb form) my friends, and you!!! Phosphoric acid, on the other hand binds with the iron molecules to stop the rust process - rust blocker, inhibitor, whatever.
So the Iron Out soak results in this:
LOTS of rust melted off and flowed away down the street. But because I have no idea what chemicals I just trashed them (and the fish I'll be catching out of Lake Erie later this summer) with I neutralize all the acid with another bath... in baking soda:
Then, its a quick power wire brush with the drill and then onto the multiple soaks in phosphoric acid metal prep, inside and out, to lock up all those anarchic molecules and make them go to sleep forevermore....
And here they are all naked like and out in the world for all to see.
One is really, really nice. The other is a little rough in a few thin spots. Lets take a closer look
The answer, of course, is to learn to weld with the little mig welder on this thing before I start screwing up the couple spots on my bodywork that will need a spot weld or two. So.... here we go!!!!
BUTT UGLY!!!
Thats better.
At the top and bottom collars of both I just melted in a bunch of rod so the outer box would not be rattling around the inner tube on every freaking bump in the road.
Now its nice and solid again.
Time to plug up some un-needed (for me) sensor and heat riser holes (the heat riser covers have gaskets, the're just not shown in the picture):
Hit it with some cool silver heatproof Eastwood paint and final inspection by the Boss:
Install it with some gaskets from my not-so-complete gastket kit, some clamps with steel wool ring gaskets and a couple of pipe connectors (which I found in the plumbing isle of Lowes hardware store)
And here she is ready to breath AND keep me warm!
Stick-em-up :2gunfire:
The pea shooters are not clamped on yet because I have to get this ship in bottle out through my basement door first!!!
P.S. This muffler stuff is the biggest pain in the Arse I have dealt with in a long , long time, nothing fits right and all needs repeated massage and adjustment until its finally tightened down together as one unified system. Don't give up!! Persistence pays off on this muffler stuff. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Posted: Thu May 11, 2017 4:03 pm Post subject: Re: Buggeee's 1972 Super Beetle |
The dual Empi 34 EPC carbs that came with this have sensitive float valves that can withstand no more than 3 psi of fuel pressure before they start overflowing drowing the motor with excess gas.
The stock fuel pump is 5 or 6 or 7 psi or something and can supposedly, or not, be adjusted down by adding more gaskets under the pump somehow.
I am going to be in enough of a world of hurt trying to tune these carbs as it is. I'm not going to be fooling with extra gasket guesswork. So I got a Holley fuel pressure regulator with a lower range (1-15 psi) appropriate for these carbs. And a cool little gauge that will help me adjust it properly. And a little adapter that the guage goes into. And 1/4 inch barbs to route my hoses as I see fit. Here's the goods:
My friend suggested some gas-proof Curil-T for the threads. Who am I to argue?
Screwed the mounting plate onto the Shroud in a spot that was just screaming for a fuel pressure regulator:
...and then mounted the regulator. I was not looking for bling but thats how it comes and, I must admit, I like the look of it.
P.S. After this pic I cut the hoses to the proper length, pushed them on all the way and used fuel hose clamps (not the corkscrews) to seal it up. _________________ 1966 Sportsmobile Camper https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
wcfvw69 Samba Purist
Posted: Thu May 11, 2017 6:48 pm Post subject: Re: Buggeee's 1972 Super Beetle |
Only the "new" craptastic fuel pumps sold today are putting out the 5 PSI and up fuel pressure.
An original Pierburg fuel pump, either dome top or square top rebuilt w/an NOS repair kit or a NOS fuel pump puts out 2.6-3.0 out of the box. I recently purchased an NOS dome top Pierburg fuel pump made in Mexico for $100 dollars. I installed it and it had right at 3.0 PSI.
They are great pumps and last for decades vs. years like the new ones. And you don't have to use all that aftermarket fuel pressure gear. _________________ Contact me at [email protected]
The Samba member since 2004.
sb001 Samba Member
Posted: Thu May 11, 2017 7:36 pm Post subject: Re: Buggeee's 1972 Super Beetle |
Lookin' great!! Your attention to detail is amazing, you have the patience of Job. And you're setting up dual carbs, welding heater boxes, etc... no wonder it's taking a bit longer-- I tihnk you still win!
I have had very good luck with the original VW replacement Brosol pumps made in Brazil, I think there are some crappier knock-off ones now but I have an original Brosol on both of the bugs I have and they put out just over 3 psi, like 3.2 when I measured it on my 69:
You may find one of those for a bit cheaper when/if you go looking. _________________ I'm the humblest guy on this board.
1600 SP engine
