nocreditnodebt Samba Member
Joined: September 28, 2012 Posts: 332 Location: Socal
Posted: Sat Feb 11, 2017 5:48 pm Post subject: Re: Anyone using LED headlights? |
A very different outcome when a reflector/projector is designed around an LED light source by a OEM manufacturer.
Cannot compare such a headlight, to one into which one drops the best appearing aftermarket LED bulb whose marketing tickled their serotonin receptors and caused a 'click order' to be placed.
I get so irritated at the 'bro trucks' arond here with their LED drop ins which blind every single vehicle on the other side of the road, and have a horrible beam pattern which makes the 'bro' think he can see better with a bunch of warm and fuzzy pupil constricting foreground lighting.
It is the ultimate in arrogant ignorance. |
takeiteasy Samba Member
Joined: August 11, 2016 Posts: 169 Location: New York, NY
Posted: Sat Feb 11, 2017 8:26 pm Post subject: Re: Anyone using LED headlights? |
Steve M. wrote: |
Check out these LED Headlight advertised for Jeep's using the DRL feature and Amber turn signal ability for a few bucks cheaper. $165.00
https://www.amazon.com/dp/B01DLLAJOQ?psc=1
It looks to have the basically the same type of LED projectors in the same locations with a just a different face/background. |
Anyone used the suitech from amazon? _________________ '85 Weekender 1.9L
"With your past and your future precisely divided.
Am I at that moment? I haven't decided." |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sun Feb 12, 2017 6:40 am Post subject: Re: Anyone using LED headlights? |
takeiteasy wrote: |
Steve M. wrote: |
Anyone used the suitech from amazon? |
These are the ones I ordered from Amazon and they are now $120.00.
They are still working!
https://www.amazon.com/gp/product/B00WM3WDXA/ref=oh_aui_detailpage_o09_s01?ie=UTF8&psc=1 _________________ This free advice is worth exactly what you paid for it.
Yellow Rabbit Samba Member
Posted: Sun Feb 12, 2017 8:47 am Post subject: Re: Anyone using LED headlights? |
Has anyone tried Sylyania Zevo LED headlights? I'm considering these. I think they may be made by the same manufacturer as what Gowesty sells, but they are priced lower. |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Sun Feb 12, 2017 2:14 pm Post subject: Re: Anyone using LED headlights? |
The 7" round LED headlights from Sylvania, Peterson, GE and several other brands are all relabeled versions of the TruckLite 7" round technology. I tested a set of the GE NightHawk LED headlights a couple years back and found them to be good, but not great.
The reflector style LED headlights work well, but they don't offer the same performance as the projector lens styles like the JW Speaker 8700 Evolution 2. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
Posted: Sun Feb 12, 2017 8:37 pm Post subject: Re: Anyone using LED headlights? |
I posted an update on my h4 led trial
https://shufti.blog/2017/02/12/vanagon-h4-led-bulb-update/
One of those lights shining on a wall and also down the road comparisons.
Not by any means a well done field comparison of the led and halogen bulbs, but good enough for you to get the idea.
Alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
Old address still works...
http://shufti.wordpress.com |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Mon Feb 13, 2017 12:35 am Post subject: Re: Anyone using LED headlights? |
Hairy,
Interesting - thanks. Agree the beam pattern kinda falls apart with the LED bulb in the incandescent lamp. But worse - the high beams. If the photos mimic the observed appearance, it looks like the 100w conventional bulb kicks ass. The LED high beam also seems to sear the snow in front of it, which tells me it's going go cause a lot of very bright illumination right in front of the car on high beam - not good.
I'd love to see similar shots of a true LED lamp. Out in the garage I have a pair of audi PES low beams. I should investigate hiding them behind the grille or something. Great cutoff, and overall illumination. Just ugly!! _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Mon Feb 13, 2017 5:23 pm Post subject: Re: Anyone using LED headlights? |
Doug,
I disagree with a couple of your points. I don't think the beam pattern is that bad. Yes, the halogen beam is very crisply defined, but the led ain't that far behind. And the near front glare on the snow isn't what you might think from the pics. In falling snow and snow packed roads I didn't find any problem.
It's always difficult to convey theses things with photos, you'll just have to believe me Doug
Today I played around with one led and one halogen a bit more. Some close up beam pattern experiments and some lectrical measurements. The electrical measurements were not done as well as they could have been, I used hand held meter instead of my bench top unit. The latter would have been more accurate ( what with the switching and reg circuitry in the led bulb).
That stuff is posted here
https://shufti.blog/2017/02/13/vanagon-beating-the-h4-led-subject-to-death/
The physical placement of the led elements on this bulb is, in my opinion, as good as you can get. On the long axis it's very comparable. But on the horizontal axis it's impossible (as far as I know) to get a surface mounted led in the same position, and radiating 360 degrees.
But you know, the light output for the low current draw is still very impressive.
Alistair
IdahoDoug wrote: |
Hairy,
I'd love to see similar shots of a true LED lamp. Out in the garage I have a pair of audi PES low beams. I should investigate hiding them behind the grille or something. Great cutoff, and overall illumination. Just ugly!! |
Skidub Samba Member
Posted: Tue Mar 07, 2017 12:04 am Post subject: Re: Anyone using LED headlights? |
I completed my LED headlight install today using the Sui-Tech 7" universal LED kit with DRL harness. Super easy install and pleased with the results. I figured for the price, $175, it was worth a shot compared to some other more expensive options. Pics and notes:
I removed, primed, and painted the GW bucket assembly that had a little rust and finish painted the light retainer trim ring:
Back side of light with connections: (red for DRL, yellow for flasher)
Adapter + Connections:
DRL Harness: (came with a spade on the end and needed a terminal, fixed that, and has a simple add-a-fuse connection...connected to fuse position 18 which is switched power on)
Putting It All Together:
I'm happy with the results and the lights are really bright. Makes the standard high beam light appear very yellow in comparison. I still need to make a little connector wire to route from the yellow wire with the spade on the back of the lights and t-tap it or splice it to my signal wires for amber halo operation. Anybody know what color wire to tap into on the front turn signal harness? Yellow? _________________ 86 Syncro GL Tin Top
Subaru 2.5L Swap
Rblt Transaxle w/ R Locker + Decoupler |
unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
Posted: Tue Mar 07, 2017 5:13 am Post subject: Re: Anyone using LED headlights? |
Looks great! I went with the Sunpie version from amazon.
What is the anti-flicker adapter for? |
Posted: Tue Mar 07, 2017 5:57 am Post subject: Re: Anyone using LED headlights? |
Looks good! _________________ '85 Weekender 1.9L
Skidub Samba Member
Posted: Sat Apr 01, 2017 8:27 am Post subject: Re: Anyone using LED headlights? |
I completed my turn signal halo connections last night. Works great. It took just 18 or so inches of 16GA wire with terminal connectors on each end.
I connected one terminal end on the turn signal spade on the back of the head light and then I ran the wire through the side marker bulb/housing boot, removed van the signal wire, put a piggy-back spade connector on the free spade (decided I didn't want to tap or splice the wire), then reinstalled the van turn signal wire and my new turn signal halo wire on the piggy-back terminal.
On my van, 86 Syncro tin-top, the signal wires were black/green on the passenger side and black/white on the drivers side. Confirmed first with a multimeter,
Interestingly, when the engine is on, but headlights are off, the DRL white halos are on as designed. When I flip the turn signal wand up or down the orange signal halo replaces the white DRL halo as designed. However, when I flip the signal wand off, it takes about two seconds for the white DRL to re-illuminate. I'll post up a video today or tomorrow.
I am wondering if the delay between turn signal halo off and DRL halo reactivation is some kind of voltage lag between switched power going fully off and constant power coming back on, use of my piggy-back set up, or maybe this is just normal for the Sui-Tech light operation. The halo function described does not affect headlight operation. When on, the headlights are on and experience no lag or drop in illumination. _________________ 86 Syncro GL Tin Top
Subaru 2.5L Swap
raoul mitgong Samba Member
Joined: July 05, 2009 Posts: 1338 Location: Denver, CO
Posted: Sat Apr 01, 2017 8:42 am Post subject: Re: Anyone using LED headlights? |
Anyone have issues with snow build up with their LEDs?
I read that there was an issue with snow/slush build up due to the cooler glass up front. I also read that some new LEDs had a heating element built into the glass. Don't know what that adds to the price of these already spendy units.
-d _________________ 84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim)) |
bajaleo Samba Member
Joined: March 21, 2009 Posts: 211 Location: San Juan Capistrano, CA
Posted: Wed Apr 26, 2017 1:55 pm Post subject: Re: Anyone using LED headlights? |
Skidub wrote: |
I'll post up a video today or tomorrow. |
Looking forward to your video! _________________ Leo in San Juan Capistrano
1984 Wolfie Westy, Subaru EJ22 powered. |
OB Rat Samba Member
Joined: November 11, 2013 Posts: 77 Location: Florence, OR
Posted: Mon May 01, 2017 4:06 pm Post subject: Re: Anyone using LED headlights? |
JW Speaker 8700J's on the outside for both low and high beam. Insides are the stock high beam Hella's that I painted (3 coats lens yellow & 2 coats clear).
The JW Speaker's really are the best you can get, I believe. Developed for the US military, they are, not literally, bomb proof and will stand up to abuse more so than any other headlight out there.
86scotty Samba Member
Posted: Tue May 02, 2017 7:04 am Post subject: Re: Anyone using LED headlights? |
Skidub, thanks for the writeup and pics! You've pushed me over the edge.
_________________ 86 Vanagon Westfalia 87k
1998 Ford E350 4x4 camper build
Vans flip flops |
Posted: Tue May 02, 2017 7:28 am Post subject: Re: Anyone using LED headlights? |
Any pictures of the installation process? Did you need new buckets? Do these have a DRL feature also?
OB Rat wrote: |
baltik Samba Member
Posted: Tue May 02, 2017 11:37 am Post subject: Re: Anyone using LED headlights? |
OT what bumpers are these?
OB Rat Samba Member
Posted: Tue May 02, 2017 6:05 pm Post subject: Re: Anyone using LED headlights? |
[quote="bajaleo"]Any pictures of the installation process? Did you need new buckets? Do these have a DRL feature also?
Sorry, no pics. The JW Speaker series (7") fit right into the standard round 7" buckets. Very easy to install. The only extra mod came at the connection. Mine, (the 8700 "J"), came with the H13 plug out of the back of the light. I needed the more common, 3 blade, H4 to just plug & play. You would need the adapter to do it right but I wasn't patient enough to order, wait and then install with those as I wanted the lights in for a little road trip. You'd want the H13 "female" and H4 "male." adapter, which are cheap and easy to find. I instead cut the plugs off each end and connected each of the 3 wires together with simple blade connectors. Took just a few extra minutes to do. The model I got do not provide DRL's, tho there are models that do.
I can't say enough good things about the JW Speaker 8700 series lights. Wether you go with the standard 8700 Evo 2 or the "J" like mine, you just can't go wrong.
OB Rat Samba Member
Posted: Tue May 02, 2017 6:13 pm Post subject: Re: Anyone using LED headlights? |
baltik wrote: |
Custom (aka; homemade). Unfortunately I do not know who did the work as they came from the previous owner. Same guy built the roof rack.
