inorganic Samba Member
Joined: September 26, 2016 Posts: 60 Location: Portland, OR
Posted: Fri Nov 03, 2017 10:52 pm Post subject: Re: Anyone using LED headlights? |
[quote="OB Rat"]
baltik wrote: |
OT what bumpers are these?
Custom (aka; homemade). Unfortunately I do not know who did the work as they came from the previous owner. Same guy built the roof rack.
i see on your rear bumper what appears to be a quick connect valve and a switch. onboard air perhaps? really curious to see your set up!! _________________ '86 SYNCRO Weekender |
WestyWanter Samba Member
Joined: February 15, 2017 Posts: 459 Location: San Diego
Posted: Sat Nov 04, 2017 2:53 pm Post subject: Re: Anyone using LED headlights? |
Pretty sure that is a south african bumper, Gowesty sells one i'm pretty sure its like 400-800$ depending what all you need to go with it
[quote="inorganic"]
OB Rat wrote: |
baltik wrote: |
i see on your rear bumper what appears to be a quick connect valve and a switch. onboard air perhaps? really curious to see your set up!! |
averyo Samba Member
Joined: April 12, 2000 Posts: 73 Location: Northern California
Posted: Sun Apr 22, 2018 4:30 pm Post subject: Installed SuiTech RGB Color LED Headlights |
Like Skidub I went with SUITECH 7" but I got the newer version that has RGB color options with a Bluetooth controller and app
These on Amazon $122.80 https://www.amazon.com/gp/product/B0727ZNSSF/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
They came with everything I needed to hook up to the GoWesty South African Grill kit connectors. I bought the SA Grill kit with no exterior lights but did buy the exterior light brackets separately. I am using the smaller interior incandescent lights from the GoWesty kit, they go on with high beams and the LEDs brighten up as well.
The Suitech kit comes with wire and connectors to hook up DRL power to the halo rings (any color you like) plus wire to hook the halos into your turn signals so they swap to amber on turn. I chose to use better wire and connectors but otherwise the kit is complete and includes what I believe they used to sell separately as an anti-flicker unit.
There is quite a bit of volume of adapters, wire, the bluetooth controller, etc. but it does all fit it you take your time.
I hooked the turn signal halos with a piggy back connector just as Skidub described by threading a wire through the turn signal boot and then connecting to tab with a piggy back.
For DRLs I plugged into G5 on the back of the fuse panel.
The RGB color is pretty cool, the kids love it. You can program different patterns and save them with shortcuts so you can set to all sorts of flash or gradient fade through a few colors.
I've tested it all out and it works, final test and headlight adjustment after dark. I will try to post a video to show all the functions.
averyo Samba Member
torbot Samba Member
Joined: September 09, 2010 Posts: 121 Location: Michigan
Posted: Sat Jan 05, 2019 1:23 pm Post subject: Re: Anyone using LED headlights? |
Necro posting I know, but didn't see mention of this in any of the other LED posts and felt this was an appropriate place for this question (actually 2 questions).
Question 1: It seems most of the LED replacement units use polycarbonate or similar materials for the lens, vs. glass which the originals had (I have an '82 with the original round sealed glass housings). Has anyone had issues with the plastic lenses yellowing/fogging over time? It's about the only concern keeping me from pulling the trigger on LEDs vs upgrading to HIDs.
Question 2: Anybody had any experience with these units? I like that they're chrome and they have glass housings, but at $71/pair they're almost in too-good-to-be-true range.
https://www.amazon.com/dp/B01J4GG6L2/?coliid=I1W3Q..._lig_dp_it _________________ '82 Westy w/2012 Subaru EJ25 (AKA "Dave"). |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Sat Jan 05, 2019 3:48 pm Post subject: Re: Anyone using LED headlights? |
I bought a pair of housings like that year ago because I needed the clear glass fronts, and even with the H4 halogen bulb they're designed for, they're pretty terrible. With an LED or HID H4 "bulb" they're only going to be worse.
Thankfully, I was only trying them with H4 bulbs as a laugh before prying them open and using them for an HID projector retrofit using proper OEM D2S HID capsules and quality ballasts. For that use, they're excellent... |
?Waldo? Samba Member
Posted: Sat Jan 05, 2019 4:13 pm Post subject: Re: Anyone using LED headlights? |
I have had these on one van for ~a year. No perceptible difference in appearance (no yellowing or fogging) although it would be surprising if there was in a year. They are an amazing lighting upgrade. Much better than e-code H4's with relays and high wattage bulbs. They are so good that I got another set and installed them in my '79 Rabbit also. At <$100 for the set and plug and play install for the rounds, that is one of the best bang for buck upgrades I have ever done.
I have no personal experience with the linked housings. |
torbot Samba Member
Posted: Sat Jan 05, 2019 5:03 pm Post subject: Re: Anyone using LED headlights? |
tristessa wrote: |
I bought a pair of housings like that year ago because I needed the clear glass fronts, and even with the H4 halogen bulb they're designed for, they're pretty terrible. With an LED or HID H4 "bulb" they're only going to be worse. |
Kinda what I was thinking for the price
?Waldo? wrote: |
Thanks Waldo, I saw your post on one of the other threads here. Those look nice (esp. all the positive reviews), but can't find chrome versions. I'd like to retain at least a little of the original looks. But I suppose at around $100, even if they lasted a few years without fogging it'd be worth the upgrade. Appreciate the feedback. _________________ '82 Westy w/2012 Subaru EJ25 (AKA "Dave"). |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Sun Jan 06, 2019 7:25 am Post subject: Re: Anyone using LED headlights? |
My 944 uses these rounds. I called Daniel Stern Lighting and asked what the best I could possibly put in there would be. Beam pattern, quality optics, high beam penetration, etc. The best. Answer was Koito H4s. He found me a set and I’ve been very pleased for more than a year now. Hard to find and not cheap. Would enjoy a side by side comparo some time. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
xclemjustinx Samba Member
Posted: Sun Jan 06, 2019 11:00 am Post subject: Re: Anyone using LED headlights? |
I’m using inner and outer led lights front Transporter Werks. I have the inner lights and halo wires into the turn signal.
Birdrocksweeper Samba Member
Joined: February 05, 2017 Posts: 23 Location: San Diego
Posted: Sat Jan 12, 2019 11:36 am Post subject: Re: Anyone using LED headlights? |
xclemjustinx wrote: |
That looks good. Are the inners activated via high beam or separate switch? Any pics of how the inners are mounted since it isn’t using the normal inner lights? Looks like the provide some type of custom bracket for those? |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Jan 12, 2019 6:42 pm Post subject: Re: Anyone using LED headlights? |
LOVE 'em...hugs & kisses! (XOXOXO)
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Thu Mar 14, 2019 9:37 pm Post subject: Re: Anyone using LED headlights? |
On Waldo's recommendation, I got myself a set of the LED headlights. I am sure that I am missing something painfully obvious, but I don't see how to mount them. My H4 headlight has three tabs that screw in to the bucket, which the LED's do not have. What am I missing here?
_________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
Posted: Thu Mar 14, 2019 10:28 pm Post subject: Re: Anyone using LED headlights? |
As far as I know, your current headlights are not stock Vanagon headlights. Vanagon headlights do not have those metal tabs on the perimeter and instead are held on by a chrome trim ring around the light. The trim ring screws to the bucket. You'll need to get a set of the stock Vanagon trim rings to mount the LED's.
Here's a set: https://www.ebay.com/itm/79-93-Vanagon-Gl-Westy-Ra...xyEIJTemP7 |
Posted: Thu Mar 14, 2019 10:38 pm Post subject: Re: Anyone using LED headlights? |
Many thanks! _________________ 1986 Westy Weekender
Now a full camper
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Fri Mar 15, 2019 9:35 pm Post subject: Re: Anyone using LED headlights? |
The chrome ring with the mounting tabs is not integral to the headlights you removed. Gently pry the rings off and put them on your new 7" LED's. _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
Zeitgeist 13 Samba Member
Posted: Fri Mar 15, 2019 10:37 pm Post subject: Re: Anyone using LED headlights? |
I don't think this is apropos of this current issue, but factory 7" round E-code lights do not have a separate trim ring. They have integral tabs spot welded to the light housings. If these are the lights you currently have, then if the desire is to swap in LEDs or any other non-factory 7" round lights, you will need to source those NA spec trim rings. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Kirsche Wasserboxer Samba Member
Joined: November 03, 2016 Posts: 104 Location: Seattle
Posted: Thu Mar 21, 2019 1:10 pm Post subject: Re: Anyone using LED headlights? |
Anyone have experience with the LED round grille kit from Van Cafe?
https://www.vancafe.com/VCLEDLIGHTGRILLKIT-p/vcledlightgrillkit.htm
I'm looking into changing out the stock square bulbs/grille on my '90 Westy with this kit. I have the relay and higher wattage bulbs now, and it is still not bright enough for me. I'm not wedded to the square look, and don't want to drop the money needed for the SA grille set-up, so this looks like a good option. I could always hit the junkyard for the grille and buckets I guess, but this looks like a much easier way to get to the same thing when you're lazy like I am. _________________ 1990 Westfalia Vanagon
2.1 Wasserboxer |
DeadSetMonkey Samba Member
Joined: April 15, 2010 Posts: 532 Location: Denver, CO
Posted: Thu Mar 21, 2019 4:05 pm Post subject: Re: Anyone using LED headlights? |
I just upgraded.
I sourced LEDs from JWSpeaker. 8700 outer. 8630 inner.
Other parts were from GoWesty.
Ultimately had the stuff installed by RMW in FtCollins.
Inner buckets required modification to accept the JW 8630 lights.
Major improvement in night driving.
Only major difference is the clean horizon the LEDs make.
Prior square lights sort of faded away.
New LEDs have a very straight beam, makes more of an on/off horizon... if that makes sense.
Pleased with the result.
_________________ ----------------------------------------------------
'90 Syncro Westy 2.5Subi Turbo, BFGs 215/75/15 Rheins |
oldskewlsk8ter Samba Member
Posted: Thu Mar 21, 2019 7:46 pm Post subject: Re: Anyone using LED headlights? |
Cheap LEDs off eBay/amazon. Only problem I have now is everyone flashes their high beams at me because they think my lights are on high. _________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
1965 Kombi project |
