maskinmester Samba Member
Posted: Wed Feb 15, 2017 1:59 pm Post subject: 1954 Brakes |
Hi
I am currently restoring my July 1954 Oval. Both front and rear brakes have backing plates with 2 holes for the wheel cylinder. Any one knows when they changed from 4 to 2 bolt mounting of the cylinders?
An any one knows if possible to get new brake drums fitting the old type backing plate?
Mine are very close to the wear limit 231,5mm, so not much room for machining _________________ 1954 Beetle - running - Went to HO 17
1961 Beetle in the workshop
1960 Beetle waiting for repair
1956 Unimog 411
30 old farm tractors and stationary engines
1999 Golf - daily driver |
EVfun Samba Member
Posted: Wed Feb 15, 2017 5:55 pm Post subject: Re: 1954 Brakes |
Wolfsburg West lists front and rear drums for the early Bugs as being available. For whatever reason they are not listed with the Bug "Brakes and Wheels" but instead in the "Front Axle" and "Rear Axle" sections. _________________
Wildthings wrote: |
3foldfolly Samba Member
Joined: March 08, 2009 Posts: 894 Location: Edwardsville, Il
Posted: Wed Feb 15, 2017 7:05 pm Post subject: Re: 1954 Brakes |
Not sure of the date when they changed. I have a 7-5-54 beetle that I've had since 1977 and it has 2 bolt wheel cylinders. I used less expensive later front drums on mine by turning the brake lathe cutter around and machining off the outer rim. If you're planning on driving your car regularly you may want to consider upgrading to later (wider) front brakes as the stock brakes leave a lot to be desired in modern traffic. I had shoes relined with high friction linings and had them arced to the drums. Also switched to a 65-66 17mm master cylinder and they're still fairly lame. Probably as good as it's gonna get with a setup that appears stock.
laneven28 Samba Member
Joined: January 09, 2007 Posts: 312 Location: Cedar Hills, Utah
Posted: Wed Feb 15, 2017 7:36 pm Post subject: Re: 1954 Brakes |
My March 54 beetle has 4-hole front backing plates, and 2-hole rears. _________________ 1950 Pearl Grey Hoffman Standard Split Window
1954 Iceland Green Euro 3-Fold Oval
1955 Strato Silver Transitional 3-Fold Oval
1956 Iris Blue Convertible
1958 Pearl White Lowlight KG Convertible
1961 Turkis Ragtop |
suleyman Samba Member
Posted: Thu Feb 16, 2017 8:57 pm Post subject: Re: 1954 Brakes |
I read some ware many years ago 53 parts still being used till depleted around early march 54 .My Feb 54 German built bug has four bolt cylinders front and rear. |
volksartist Samba Member
Posted: Fri Feb 17, 2017 7:29 am Post subject: Re: 1954 Brakes |
My April trans has 4 bolt cylinders. My June car is all two bolt. Cant say my car is original, but the trans looks all original. |
Posted: Sat Feb 18, 2017 4:33 pm Post subject: Re: 1954 Brakes |
Thanks for all the input. So basically I can conclude that it is fairly correct with 2 bolt mounted cylinders on a July car.
It will never become more than a pleasure driver with maximum 2-3.000 km a year mostly in off peak/Sunday traffic and it have to be original so will go with original drum setup, but might look into the 17mm master cylinder to reduce the efforts on the pedal as this will be barely visible from the outside. _________________ 1954 Beetle - running - Went to HO 17
1956 Unimog 411
EVfun Samba Member
Posted: Sat Feb 18, 2017 6:07 pm Post subject: Re: 1954 Brakes |
I'd recommend the 17mm master cylinder. My '57 is stock and it has a lot heavier brake pedal than the '59-'64 Bugs I've driven for years. Not a shock, both have 19mm masters, but the wheel cylinders are different. The oval has 19mm front and 17mm rear. The 40 horse Bugs are 22mm front and 19mm rear. Area relates to diameter squared. The 17mm master should come real close to making the oval brakes feel like the 40 horse brakes. In heavy use the oval brakes will fade more because they are smaller. _________________
Wildthings wrote: |
TheLadyBug Samba Member
Joined: August 17, 2014 Posts: 639 Location: Saskatoon, Saskatchewan, Canada
Posted: Sat Mar 04, 2017 3:49 pm Post subject: Re: 1954 Brakes |
My Feb '54 car has 4 bolt wheel cylinders up front, and 2 bolt in the rear.
I'd say you are safe (and saving a ton of money) by having two bolt cylinders. _________________ Charmaine
1954 Beetle - because I can
2016 Golf highline - hubby’s daily
2016 Golf R - my daily |
splitjunkie Samba Member
Posted: Sat Mar 04, 2017 5:13 pm Post subject: Re: 1954 Brakes |
Even if you have four bolt backing plates you can still use the two bolt cylinders with no modifications. If it is a car that you drive a lot then I would recommend using the two bolt cylinders since they are a lot cheaper and easier to find. _________________ Chris
Posted: Sun Mar 05, 2017 2:34 pm Post subject: Re: 1954 Brakes |
Thanks for the inputs. I hope it will be driven often, however due to insurance rules it is only "driving for pleasure" - so not a daily driver even in summer season. So mainly events and a ride for ice a summer eve - we also have quite a few even meets during the season where all kinds/makes of vintage cars and bikes show up. But on the other hand I do not see these cars fit in during rush hours on a daily basis.
So as original as time and money allows. Everything doesn't need to be done at one time - needs to get on the road
/René _________________ 1954 Beetle - running - Went to HO 17
1956 Unimog 411
mbliss13 Samba Member
Joined: October 15, 2013 Posts: 45 Location: Santa Clara, CA
Posted: Wed Mar 08, 2017 2:57 pm Post subject: Re: 1954 Brakes |
I have a July 14 1954 car that is all original. I will check and report back.
-Mike _________________ 1951 Standard Beetle (German Delivery)
1954 Beetle, L275 Light Beige Survivor
1960 Beetle Convertible, L41 Black
1962 Beetle, L87 Pearl White with Judson/1200 power
1967 Beetle, L282 Lotus White |
Posted: Wed Mar 08, 2017 6:48 pm Post subject: Re: 1954 Brakes |
To answer my previous post, my July 1954 car has two bolt wheel cylinders front and back.
Posted: Thu Mar 09, 2017 1:29 am Post subject: Re: 1954 Brakes |
Trust there is no doubt anymore - July 1954 are born with two bolt wheel cylinders front and back.
Thanks to everyone.
1956 Unimog 411
Posted: Thu Mar 09, 2017 9:09 am Post subject: Re: 1954 Brakes |
I am going to assume the same for June. Listed my 4-bolt backing plates and
am relieved to save a bit of money on cylinders |
