Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Sat May 12, 2018 9:14 am Post subject: Re: 1963 15 Window resurrection |
Meticulous work! _________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
Burlyhammer Samba Member
Joined: March 07, 2002 Posts: 1693 Location: Great north woods Maine
Posted: Sat May 12, 2018 9:30 am Post subject: Re: 1963 15 Window resurrection |
Skim wrote: |
Meticulous work! |
I just hide the big hammer whenever I take a picture. Haha
Thanks |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3851 Location: San Jose, CA
Posted: Mon May 14, 2018 7:11 am Post subject: Re: 1963 15 Window resurrection |
I dig the way you have the remnants of the ol' girl hanging on the shop wall. That is 'art' in itself. Impressive work, you spot-weld drillers.
Edit: Ooops...just looked at more of your pics...I guess that nose is from another ol' girl, not necessarily this one. |
Posted: Mon May 14, 2018 7:17 am Post subject: Re: 1963 15 Window resurrection |
Busstom wrote: |
The bus on my wall is the same bus that is my avatar. I did not have to drill out anything. Just lift and separate. I do enjoy drilling out a spot weld, though. |
Posted: Mon May 14, 2018 9:02 am Post subject: Re: 1963 15 Window resurrection |
I finished the drivers side dog leg this past weekend:
I put the rocker spear on just for fun:
I used the measurements that Everett B. posted to put it in the proper location. When I found the bus, it only had one rocker spear, and it was hanging by 1 screw. Once I jacked the bus up, I raked the ground and found the other one. They are both fairly straight. I guess that's what happen when Mother Nature removes them!
I also finished up the door seal pieces:
And started fitting the seat pedestal:
It is ready to go in once I put the Copper Weld to it:
My biggest concern was removing my rigging and losing the door gap, but everything stayed in place. I must have opened and closed the door 30 times. Things are going well! |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon May 14, 2018 9:56 am Post subject: Re: 1963 15 Window resurrection |
Amazing work! _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
type2rescuemaine Samba Member
Posted: Mon May 14, 2018 9:57 am Post subject: Re: 1963 15 Window resurrection |
Just a quick comparison to show the extent of repair that has been done to this lucky bus:
^^^This is what the front of the bus looked like in the beginning of April 2017
^^^and now...
BarryL Samba Member
Joined: November 01, 2004 Posts: 14266 Location: Casa de Oro, California
Posted: Mon May 14, 2018 10:26 am Post subject: Re: 1963 15 Window resurrection |
crofty wrote: |
Amazing work! |
What ^^^ said.
Burlyhammer wrote: |
My biggest concern was removing my rigging and losing the door gap, but everything stayed in place. |
So every time you hear a popping sound you spin around and your heart sinks. |
Posted: Mon May 14, 2018 10:58 am Post subject: Re: 1963 15 Window resurrection |
BarryL wrote: |
crofty wrote: |
Amazing work! |
What ^^^ said.
I didn’t think the welds would come apart. I was worried about flexing. I pulled it in further than necessary hoping it would relax into the desired spot. Pretty close. |
Posted: Tue May 15, 2018 12:47 pm Post subject: Re: 1963 15 Window resurrection |
crofty wrote: |
Amazing work! |
It is still a lot of fun! I look forward to getting to work on it every chance I can get.
Thanks Crofty. |
Posted: Tue May 15, 2018 12:56 pm Post subject: Re: 1963 15 Window resurrection |
I got the drivers side seat pedestal 1/2 welded in this morning:
I didn't notice until this morning that the replacement metal has an indent and a hole for earlier bench seat rubber stops I believe. I was hoping I could live with this, but I think they are going to have to go away. I put the seat in to see if it would be covered:
Nope.
I am going to attempt to get this panel all the way in tomorrow. I had to flatten the lower lip to make it reach the line where the front floor will sit, so I will need to weld a flange to that part as well. |
Brendel20 Samba Member
Joined: October 21, 2010 Posts: 300 Location: Troy, IL
Posted: Tue May 15, 2018 3:45 pm Post subject: Re: 1963 15 Window resurrection |
Inspiring work. A+ |
Posted: Tue May 15, 2018 4:42 pm Post subject: Re: 1963 15 Window resurrection |
Brendel20 wrote: |
Thanks man. Much appreciated. |
Posted: Wed May 16, 2018 3:46 pm Post subject: Re: 1963 15 Window resurrection |
I finished welding in the seat pedestal last night, and ground all the spot welds this morning.
I put the floor in to check the fit:
I am extremely excited. I still have to weld a lip on the bottom edge of the floor, and get the outer seat track repaired and installed, as well as getting the seat belt mount removed from the old seat pedestal. Then on to the other side. While I was grinding spot welds, I was looking at the hump where the rubber stop goes, and trying to figure out what I would have to do to remove it. I decided to look at the ones I removed from this bus, and the donor bus:
Hmm... They both have the same indent. I guess the hump stays. I did fill in the hole:
I won't be able to work on the bus for a few days, but I am going to try to make some progress this weekend! |
edgood1 Samba Member
Joined: September 30, 2004 Posts: 2049 Location: Plymouth, MA
Posted: Wed May 16, 2018 4:38 pm Post subject: Re: 1963 15 Window resurrection |
edgood1 wrote: |
Wow. It's better than new! |
Haha. Thanks |
ryans65 Samba Member
Joined: February 16, 2016 Posts: 1263 Location: Yulee FL
Posted: Wed May 16, 2018 5:18 pm Post subject: Re: 1963 15 Window resurrection |
I'm sure you can't wait to get that floor in and give it the obligatory smack with your hand so you know it's real! That was a good day for me when I could pound my fist on the floor and I wasn't afraid it was going to come through the the other side |
Posted: Wed May 16, 2018 5:35 pm Post subject: Re: 1963 15 Window resurrection |
ryans65 wrote: |
That will be an awesome moment. It blows my mind to think where we started compared to where we are today. Unreal 🤯 |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Wed May 16, 2018 5:52 pm Post subject: Re: 1963 15 Window resurrection |
Impeccable work _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
Posted: Wed May 16, 2018 6:42 pm Post subject: Re: 1963 15 Window resurrection |
ryans65 wrote: |
Had lots of mile stones building my bus. Installing the floors are some of the most memerable. Feels like you have really accomplished something. Looks like you are going to run out of metal work to do soon. _________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
