Brass shift rod bushing
Fs71
Fs71 is offline
PostPosted: Tue Dec 19, 2017 8:08 pm    Post subject: Brass shift rod bushing Reply with quote
There is a company that sells a brass shift rod bushing to replace the nylon type bushing. It is suppose to be a life time replacement. Any one have experience with this brass bushing? Any cons to a brass bushing instead of the nylon bushing?
Thanks for your opinions.
mondshine
mondshine is offline
PostPosted: Tue Dec 19, 2017 9:09 pm    Post subject: Re: Brass shift rod bushing Reply with quote
It's funny how the rubber and plastic parts that were originally installed on these cars seem to outlast the replacement parts available today despite the huge improvements in the materials used to make these things.
Anyway, the last time my shift rod bushing croaked, the spare I had in stock was so old that it just crumbled in my hands.
The simplest solution was to just make one.
I just turned a brass bushing on my lathe. It's held in place with a snap ring. It was basically free.
If I remember correctly, the ID was about 21.15mm, and the OD was about 26. So the wall thickness isn't much, especially at the groove for the snap ring. It shifts nice and smooth, it's accurate, and doesn't rattle.
I think the lifetime bushing for sale in the classifieds comes with some sort of installation tool; I just used a long nose snap ring pliers, but it took some patience and finesse to get the snap ring in place.
I hope the bushing I made outlives me.
With any luck, I will never have to dick around with this again.
Good luck, Mondshine
Wildthings
Wildthings is offline
PostPosted: Tue Dec 19, 2017 9:23 pm    Post subject: Re: Brass shift rod bushing Reply with quote
CB Performance sells what they claim is an OEM busing
http://www.cbperformance.com/product-p/111-701-259a.htm
BNMike
BNMike is offline
PostPosted: Tue Dec 19, 2017 10:49 pm    Post subject: Re: Brass shift rod bushing Reply with quote
I put one of the bronze bushings in Hermann. Wasn't too much trouble and it tightened up the shift pattern pretty well. And....like their ad said, I won't have to ever replace it.
BNMike
NY thing
NY thing is offline
PostPosted: Thu Dec 21, 2017 3:47 am    Post subject: Re: Brass shift rod bushing Reply with quote
https://www.thesamba.com/vw/forum/viewtopic.php?t=685654&highlight=brass+shifted+bushing
I'm looking into getting one too
Hyatt181
Hyatt181 is offline
PostPosted: Sat Dec 23, 2017 12:34 am    Post subject: Re: Brass shift rod bushing Reply with quote
Did you also buy the install tool?
BNMike
BNMike is offline
PostPosted: Sat Dec 23, 2017 8:42 am    Post subject: Re: Brass shift rod bushing Reply with quote
I did. I still have it. I shouldn't need it again, I suppose that if somebody wanted it, I'd sell it for a few bucks. It includes the instructions on a USB 'Key'.
BNMike
Fs71
Fs71 is offline
PostPosted: Sat Dec 30, 2017 7:41 pm    Post subject: Re: Brass shift rod bushing Reply with quote
Heads up on install. I purchased the install kit. It is simply a short piece of plastic pipe with a cap and a home made tool for the installation of the snap ring. I advise to purchase the install kit. Do yourself a favor and purchase a 90 degree, long reach snap ring pliers; I found them on Amazon. The only kind of pliers I could find were internal snap ring pliers and not external snap ring pliers (external snap ring pliers would be best because you only need one hand). Internal snap ring pliers will work, but require two hands. Throw the home made tool for the snap ring in the trash. The 90 degree long reach pliers made the installation of the snap ring so easy compared to using the home made tool included with the install kit.
The bronze bushing seems to work really well. Only time will tell.
74 Thing
74 Thing is offline
PostPosted: Sun Dec 31, 2017 9:20 am    Post subject: Re: Brass shift rod bushing Reply with quote
You can get the bronze bushing at your hardware store or search the internet. The part is listed on this thread
https://www.thesamba.com/vw/forum/viewtopic.php?t=...ware+store
