Buzzfagan Samba Member
Joined: April 03, 2016 Posts: 102 Location: Georgetown,Texas
Posted: Sun Feb 19, 2017 7:48 pm Post subject: Rear camber |
How do I adjust the camber on my rear swing axle? Got it on the ground today and riling but it looks like the camber is such that only about 50-60% of the rear traction/tires are in contact with the road.
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun Feb 19, 2017 8:00 pm Post subject: Re: Rear camber |
You will need to adjust the rear splines one notch.
You can also adjust the inner and out up and down since they are a different clocking to get more or less drop.
With a swing axle transmission it is a PITA to do the job due to the axles not being able to move far enough out of the way without moving the whole transmission back.
At least that was the issue for me.
I did mine on one of my yearly winter stripdown upgrades since I pull my buggy apart almost every winter to upgrade or change something.
It's kind of a mess right now.
You might want to drive it to see how it settles since it will sit up a little high until you get everything installed and drive it down the road a bit.
I think mine is one outer notch lower than stock if I remember correctly.......although that was in about 2004-2006 that I last messed with it. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
Posted: Sun Feb 19, 2017 8:14 pm Post subject: Re: Rear camber |
What would you replace them with? |
andygere Samba Member
Joined: January 31, 2014 Posts: 600 Location: Central Coast, CA
Posted: Sun Feb 19, 2017 8:27 pm Post subject: Re: Rear camber |
Replace them with ordinary oil filled shocks. If you can find a soft, used set, all the better. |
BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Sun Feb 19, 2017 9:04 pm Post subject: Re: Rear camber |
You should hold off on re-indexing the torsion bars until its built. The weight of the body, engine sheetmetal, alternator, rollbar, seats, battery, etc., will change the camber, after you take off those helper spring shocks. You can't tell how far it needs to be lowered until its assembled. You want it to have just a slight amount of positive camber with no one in it. |
stevemariott Samba Member
Joined: November 09, 2003 Posts: 1052 Location: Portland, OR
Posted: Sun Feb 19, 2017 9:20 pm Post subject: Re: Rear camber |
BL3Manx wrote: |
I agree. My suspension would always level out after driving it a little.
_________________ 1963 Manx copy
1968 Bus |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Mon Feb 20, 2017 8:42 am Post subject: Re: Rear camber |
Listen to everyone... Adjusting camber is absolutely the last thing you want to do in build... Preferably after you have put some miles on buggy so everything has chance to settle in....
And dump the coil overloads, you don't need them... Car/suspension is setup for vehicle that is 600/800 pounds heavier when it has steel body... When you reindex spring plates you are actually going to reduce preload/spring rate of standard suspension parts, coil overs just get in the way as they are not needed....
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Mon Feb 20, 2017 9:36 am Post subject: Re: Rear camber |
Have you rolled the car back and forth a bit? If not, roll it forward and backward several feet (like maybe 6') a couple times and it will come down some.
And Dale is right on the money with his comment. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Mon Feb 20, 2017 2:48 pm Post subject: Re: Rear camber |
If you are on a budget and don't care to spend more money to replace those rear shocks. (And front?) you could strip off the springs and have usable shocks. Like I did.
Oh and Buzz. If my post came off abrupt it was unintentional. Great job so far keep it coming.
Mike T _________________ BIGMIKEY
Deserter Series 1 project.
https://www.thesamba.com/vw/forum/viewtopic.php?t=787047&highlight=
1973 Beetle Driver, Marina Blue. |
Posted: Mon Feb 20, 2017 7:49 pm Post subject: Re: Rear camber |
And avoid any gas shocks... plain old maybe even tired oil shocks OEM style...
Posted: Tue Feb 21, 2017 5:46 am Post subject: Re: Rear camber |
For once I will disagree with Dale. I have KYB Gas Adjusts on the back of our buggy. Would never use them on the front, but they seem to work very well on the rear. There is enough weight in the rear that they wont lift the car at all. _________________ D-Dubya Manx clone - 63 Short pan,1914.
911pickup Samba Member
Joined: March 06, 2004 Posts: 625 Location: Near Goats on the Roof
Posted: Tue Feb 21, 2017 9:16 am Post subject: Re: Rear camber |
I've gone the same route as andk5591.
I replaced the worn out shocks on my IRS buggy with cheap oil filled shocks in the front and KYB Gas shocks in the rear.
I figured the gas shocks would work well with the extra weight of the engine. |
Jacob Baja63 Samba Member
Joined: January 13, 2018 Posts: 7 Location: Houston TEXAS
Posted: Sun Jan 14, 2018 4:11 pm Post subject: Re: Rear camber |
Im having the same issue on my baja bug with "coil overs".
did you end up swapping out for gas shocks? if so did it fix the camber issue? |
Posted: Sun Jan 14, 2018 6:28 pm Post subject: Re: Rear camber |
Pull the coil overs and see how it sits. The Gas adjusts may give a very slight lift in the rear, but not anything like the coil overs usually do. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Sun Jan 14, 2018 8:02 pm Post subject: Re: Rear camber |
andk5591 wrote: |
Pull the coil overs and see how it sits. The Gas adjusts may give a very slight lift in the rear, but not anything like the coil overs usually do. |
Thanks will pull them tomorrow and see what it does. |
Posted: Mon Jan 15, 2018 7:29 am Post subject: Re: Rear camber |
Would suggest taking the car for a ride around the block after you pull them to help things settle. I hate coil overs. I feel like they are a bandaid for folks that want to raise the car and are too lazy to reindex the springs. I have a 77 or 78 vert that we are redoing and they are on it. Once we paint the car, they are coming off. If I need to tweak the springs rotation, I'll do that.
You should notice a dramatic different in ride quality without them. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Deh Shark Samba Member
Joined: December 09, 2006 Posts: 704 Location: U.S. Virgin Islands
Posted: Fri Jan 19, 2018 2:52 pm Post subject: Re: Rear camber |
laid out.... _________________ AH TIYAD AH DAT DEH BAI!!!
Organize folks are just to lazy to look for stuff!!
55 3 fold Ragtop
Manx Dune buggy 2387cc |
