AS350driver Samba Member
Posted: Thu Feb 23, 2017 2:44 am Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
""I could lift the hatch up and down an inch at the hinges. Does your hatch seem firmly connected to the roof? If so, it is excellent. ""
To Clara, I spent a good while last night just around the sub hatch. It opens and closes smooth, and has zero vertical or lateral movement in the hinges. I also found a little prop rod laying in one of the cabinets that holds it slightly open. |
64 ragtop volks Samba Member
Posted: Thu Feb 23, 2017 9:10 am Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
does your bus have a heater log under the rear seat area? i have a 64 velvet fathatch so33 and mine does not have one, i have the 4 tent mounts wile youes has the rail for awning. cool to see another velvet subhatch |
Posted: Thu Feb 23, 2017 9:24 am Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
No heater log on this one, either. There are some screw holes in the areas the tent pole brackets would have been, though. |
Bendango Samba Member
Posted: Thu Feb 23, 2017 9:54 am Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
My floor looks about the same as yours (so satisfying aint it?) - I put down a layer of spray waxoli ove the cab floor. It cleared a little matt after drying. seemed really good but honestly held a kind of milky texture if rain got between the cab matt and the wax.
Maybe some one more experienced could chime in here on their thoughts on that?
Feels good to me though. To me once you have primed and replained you might have well as replaced the floor. Protect and enjoy the the OG as long as it can possibly last. _________________ I want a real garage.
WANTED - [WTB] 55-62 Bus Thin Lip Package Tray SWR
Getting Used - SWR 60 westy copy built by vw ( apparently )
http://www.thesamba.com/vw/forum/viewtopic.php?t=320866
Braukuche wrote: |
Where did you find the elephant dick? |
johny__utah Samba Member
Joined: September 02, 2008 Posts: 426 Location: Arizona/California
Posted: Thu Feb 23, 2017 9:57 am Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
You can clearly see the holes for the westy tent.. up from at the end of the awning rail. Also it has the front inside roof channel system for non headliner buses. Panel, Westy, Kombi used it for the grey commercial panels. _________________ 1956 L31
1961 L346 L347
1963 L380 L289 |
Posted: Thu Feb 23, 2017 10:00 am Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Yes, for those asking about tent mounts, if you zoom in on the front of the awning rail in this pic the holes are still there.
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Thu Feb 23, 2017 11:05 am Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Clara wrote: |
GTV wrote: |
EverettB wrote: |
In Arizona - Do whatever you prefer. It will take many years to get worse, unless you have water leaking in and sitting there. |
X2. I wouldn't worry about it there. |
x3 ask Lind about the bare metal on his sunroof standard... it only rusted when he brought the bus to W WA. |
I still have not painted that spot. It is only surface rust, so I have another several decades to go before it becomes a problem in my climate. _________________ .
Wanted:
srfndoc Samba Member
Posted: Thu Feb 23, 2017 12:43 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Is this inside rear wall painted white or just a color issue with the flash?
_________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Posted: Thu Feb 23, 2017 2:25 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Just the flash. It's a actually a gray color. |
Longboardluv Samba Member
Joined: September 23, 2014 Posts: 934 Location: Austin TX
Posted: Fri Feb 24, 2017 1:38 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
you're a lucky man! Great bus! I wouldn't worry about your front floor rusting any more. Subscribed |
bubba Samba Member
Posted: Fri Feb 24, 2017 2:05 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Velvet green is one of my Favorite colors!! Cant what to see it finished! _________________ ***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591 |
langsmer Samba Member
Joined: November 18, 2004 Posts: 1127 Location: CO/NM border
Posted: Fri Feb 24, 2017 6:26 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Am I correct in thinking that Riviera was the only one who used the long rail tent mounting method? I believe their tents were made (and designed?) here in Portland by Beckel Canvas. It also has the singe pane Hehr windows used on 1965 Rivieras. I wonder if this bus made a visit to Portland at some point in its early life? |
67_SO42 Samba Member
Joined: August 27, 2006 Posts: 668 Location: Oslo, Norway via Arizona
Posted: Fri Feb 24, 2017 7:17 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
This bus is getting some mechanicals here at the shop.
engine out... had the old 4th bolt installed and was frozen from corrosion (yay rats)... the good old starter bolt had a almost missing head and was near impossible to get out hahaha
Everything else is going smooooth. _________________ 58 Binz DC #151 "Nacho"
61 Norwegian, bug "Greta"
65 Swedish, Westfalia 400 trailer "Melania"
57 Binz scooter “Micha” |
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Fri Feb 24, 2017 7:57 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Killer Westy! Congratulations! I have a 65' Subhatch I've been slowly working on.
https://www.thesamba.com/vw/forum/viewtopic.php?t=642362&highlight=so-35
I agree with what Lind and Clara posted.
Lind wrote: |
Many tourist delivery buses had no port code. Same with US serviceman ordered buses. This bus has a USA spec package code, so it is likely one of those two.
A 523642 paint code would guarantee it was ordered as a westy. Lack of that paint code does not disprove that it was ordered as a westy.
I would bet this is an original westy, either ordered as such or a private conversion. |
Clara wrote: |
I think there are layers of conversion in this buses history.
1) Sold as kombi in Europe. M-code 374, so the original owner ordered it planning to bring it back to US after their awesome vacation?
2) Early owner, probably the original owner took it to be converted to subhatch westy by Westfalia (not sure how complete a kit was purchased)
3) A PO found a parts SO-23 and installed that kit
4) A PO installed camper windows and tent rail ( in US)
I am just guessing from what I can see from the pics. A closer inspection would find more clues.
In any case, it is an amazingly dry bus. Have fun camping this spring!
_________________ Brandon |
Posted: Sat Feb 25, 2017 11:17 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Got new tires and painted the black wheels back white today before work. My friend that has a split bus repair shop pulled the engine and pressure washed everything. Looks like the tank and sending unit can be reused.
Posted: Sun Feb 26, 2017 8:20 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Spent the day working on the bus. The battle against rat droppings/nests continues but I think I'm gaining the upper hand lol. The bus is back on its own wheels now.
First, the bad. The pedal pan had around 40-50 lbs of rat poop in it. After dropping it I had to lay on my back with the longest screwdriver I had, gloves welding shield and face mask on, and try to scrape more rat poop out that was still jammed up under the floorboard. Nasty!
Now the good, while under the bus I was just blown away how rust free it is. Here's some token dry undercarriage porn....admit it, you know you like it!! Lol
And some post washing/polishing pics
npbusguy Samba Member
Joined: February 08, 2006 Posts: 1658 Location: Budapest, Hungary
Posted: Sun Feb 26, 2017 9:11 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Damn that under carriage looks fantastic.
I think I would leave the pedal pan off for a while and drive the bus down some bumpy roads to knock/blow the rest of the rat poop out of the front. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Mon Feb 27, 2017 10:19 am Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Bee ute a full! That pan picture looks kinda like an ad for granola. |
Posted: Mon Feb 27, 2017 4:43 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
^^^^. I won't be able to eat granola for a few months now. ^^^^
I got some work done today tidying up the engine bay and installing new firewall and apron seals. And more polishing.
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon Feb 27, 2017 4:45 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Cleaning up nice! _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
