Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24732 Location: Olympia Wash Rinse & Repeat
Posted: Mon Feb 27, 2017 5:04 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Get the grommets for the cables where they pass thru the fire wall. Sharp metal edge will work thru insulation.
Adjust the RH rear brake line support so it will not cut that line... _________________ In Stereo, Where Available! |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Tue Feb 28, 2017 6:19 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
_________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
AS350driver Samba Member
Posted: Tue Feb 28, 2017 10:42 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Stuck at work tonight, but my friend worked on dressing the motor back up for reinstallation and happened to drain the transmission. Surprisingly, what appeared to be auto transmission fluid came out. Could gear oil have broken down and resemble automatic tranny fluid in 17 years of inactivity?
plane_ben Samba Member
Joined: February 27, 2005 Posts: 349 Location: Tucson, AZ
Posted: Wed Mar 01, 2017 5:27 am Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
That looks thick. AFT would flow out and soak into concrete real quick. Looks like clean hypoid with only a few hundred miles on it. I'd still drain and replace it. _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
Dewayne Samba Member
Joined: October 05, 2003 Posts: 332 Location: Oklahoma
Posted: Wed Mar 01, 2017 12:38 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Another thought.. One of the few makers of straight GL-4 year oil is Redline. That looks like their MTL gear oil... good stuff but expensive. When replacing the gear oil, DON"T use anything other than GL-4. Anything else will not allow the syncros to do their thing properly and you will be having hard shifting and scratchy shifting.
Others amy have thoughts on subject, but this has been my experience... _________________ "My ex-wife had a hint of a beard and she looked like a manly-girl... that made no difference..."
Drive 'em if ya got 'em, and don't brag if you didn't do the work yourself...
'64 SO34
'60 SO23 |
srfndoc Samba Member
Posted: Wed Mar 01, 2017 1:57 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Dewayne wrote: |
Others amy have thoughts on subject, but this has been my experience... |
Oh sure, bring the GL-4/GL-5 hoard in here. I've only ever used GL-5 and never had an issue. This is the same gear oil my rebuilder (Rancho) recommends.
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...start=1080 _________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
67_SO42 Samba Member
Joined: August 27, 2006 Posts: 668 Location: Oslo, Norway via Arizona
Posted: Wed Mar 01, 2017 2:47 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
That pic was taken right when it hit the floor.
Its spread out thin now.
looks like ATF.
Ill drain and report.
Might play on it tonight. _________________ 58 Binz DC #151 "Nacho"
61 Norwegian, bug "Greta"
65 Swedish, Westfalia 400 trailer "Melania"
57 Binz scooter “Micha” |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22639 Location: NYC/Upstate/ROW
Posted: Wed Mar 01, 2017 3:25 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
I think ATF was used in cold climates? Whats the history on the Bus - did it ever live up North? _________________ .ssS! |
Posted: Wed Mar 01, 2017 3:55 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Definitely not, its a San Diego, then somewhere in southern New Mexico, then Tucson bus since 1995. |
Posted: Fri Mar 03, 2017 12:24 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
The fuel tank appeared to be in such good shape that it was simply cleaned and reused, with a new petcock, fuel hose , and sender seal.
The fuel tank is in and the engine runs nice after its 17 year hibernation, but the tank is now having second thoughts....
Posted: Fri Mar 03, 2017 12:32 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Scary!! One spark and poof.... Did you install the body to gas tank seal in that area? _________________ In Stereo, Where Available! |
Malokin Martin Samba Member
Posted: Fri Mar 03, 2017 1:22 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
So did you use Gl 4 or 5? |
Posted: Fri Mar 03, 2017 3:16 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Eric&Barb wrote: |
Scary!! One spark and poof.... Did you install the body to gas tank seal in that area? |
No, however, Ive never had an issue with it not being there. _________________ 58 Binz DC #151 "Nacho"
Posted: Fri Mar 03, 2017 3:17 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Malokin Martin wrote: |
Firmly believe that this is ATF. There was only a quart in the tranny. Still have to drain the RGB's
been swamped _________________ 58 Binz DC #151 "Nacho"
Posted: Fri Mar 03, 2017 3:21 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
67_SO42 wrote: |
Eric&Barb wrote: |
No, however, Ive never had an issue with it not being there. |
It does help to keep that area from collecting all sorts of debris from being sucked up into there, and collecting under the tank where in turn it can cause rust.
Just got to see a low rust Arizona Deluxe that rats set up house in front of the tank causing a hole to rust out in the front of the tank. _________________ In Stereo, Where Available! |
Posted: Fri Mar 03, 2017 7:03 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Got an emblem today. It is mango, but too nice to repaint white. Just gonna go with it
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Sat Mar 04, 2017 9:42 am Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
What will happen to the plates? That "R" sequence is correct for '65. Someone in California could transfer those although I have no idea how that is done. I can't get over how decent that bus is. Even the headlight interiors remain relatively unrusted. Will you go white on the bumpers eventually? |
Posted: Sat Mar 04, 2017 10:10 am Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
I'm going to hit the bumpers with oven cleaner and steel wool and see if the OG white is still under there. |
GTV Samba Member
Posted: Sat Mar 04, 2017 12:36 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
Try Citri-Strip first. In some cases oven cleaner will go straight through OG paint. _________________ EMPI Power Rules! |
paulsvwbug Samba Member
Posted: Sat Mar 04, 2017 2:06 pm Post subject: Re: The Good Karma bus.....1965 Velvet Green Westy |
AS350driver wrote: |
Spent the day working on the bus. The battle against rat droppings/nests continues but I think I'm gaining the upper hand lol. The bus is back on its own wheels now.
First, the bad. The pedal pan had around 40-50 lbs of rat poop in it. After dropping it I had to lay on my back with the longest screwdriver I had, gloves welding shield and face mask on, and try to scrape more rat poop out that was still jammed up under the floorboard. Nasty!
Now the good, while under the bus I was just blown away how rust free it is. Here's some token dry undercarriage porn....admit it, you know you like it!! Lol
And some post washing/polishing pics
Nice bus, amazing under carriage. What were your steps in getting the wheels repainted, look great |
