theDrew Samba Member
Posted: Thu Aug 03, 2017 9:22 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
got the exhaust header ceramic coated -- for the curious minds out there, it cost $175 to get it coated.
_________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
Posted: Sat Aug 05, 2017 7:38 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
more progress -- all the detail work takes tons of time
finally, after about a thousand times taking the exhaust on and off, I finally put it on for good. Using copper gaskets and copper lock nuts.
Slapped toghether a breather out of an old EMPI one I had. Cast aluminum sucks for welding -- I'm willing to bet those welds are 100% sealed.
I might remake the whole thing if I notice it leaking, but it works for now
Got the shroud on for good as well, running full thermostat flaps with an OE thermostat.
Mounted the crank sensor -- using Mario's hall sensor.
Got my cam sensor in, using Mario's Mini Cam Sync
Heres the oil line routing I finally settled on. It gets cramped quickly with the turbo sitting there, so thats the best I could come up with. Using some heat covers to shield the lines from the exhaust heat.
Posted: Tue Aug 15, 2017 10:24 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
finalizing the plumbing and whatnot.
The fuel feed is 5/16 hardline than I ran through the tunnel and the return is the stock line.
Getting to mounting the fuel pump and filter
I'm using a Bosch 69136 pump that I wrapped in some closed cell foam. Two hose barbs, one for the tank outlet, and the other for the return. This worked in my previous setup, so we'll see how well it does with the fuel needs of a turbo'ed engine.
for a filter, I'm using a stock filter from a Subaru. I'm using a Mann-Filter 1030 Fuel Filter. I made a holder out of some 3" pipe, and it will be secured in the holder with some safety wire.
Dauz Samba Member
Posted: Tue Aug 15, 2017 12:18 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
I used 3/8" stainless for fuel. Will the stock line suffice for the return? Isn't it only 5mm? |
Posted: Tue Aug 15, 2017 1:10 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Dauz wrote: |
i want to say Mario said this setup was fine uptill like 300hp? I will have a fuel pressure sensor and will be monitoring see if I'm running out of supply or not getting consistent pressures. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
widefivebug Samba Member
Posted: Wed Aug 16, 2017 3:54 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
theDrew wrote: |
Dauz wrote: |
i want to say Mario said this setup was fine uptill like 300hp? I will have a fuel pressure sensor and will be monitoring see if I'm running out of supply or not getting consistent pressures. |
Yes, that's the same as he told me. I installed the new line through the tunnel and use the old line for return. |
gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Wed Aug 16, 2017 9:28 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
If you think about it during idle and coast is when you are returning the most! If you can idle without loading up you should be fine. The more you mash the pedal the less it returns.I used the stock line for return for a long time.the biggest issue with fuel is to not put in a fuel pump that will feed 1000hp and only run 200hp it will overheat the fuel since it keeps returning and leans out the tune.you can see it with fuel pressure and shitty mileage because it turns your gas to fumes.....ask me how I know!! _________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
Posted: Tue Sep 19, 2017 9:00 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
well I might have missed my goal of getting this done and driving this summer -- having a 1yro keeps you focused on more important non-toy things
I'm basically ready to try and fire it up once I get all the wiring done. In the back of the manx, I have an aluminum box that will hold all the wiring and guts for the engine. The box has a floor that removable, and thats what all the wiring is mounted to.
The key requirement is I can disconnect everything and pull the wiring board out to futz with it as I see fit. I'm a computer engineer by trade, so I made up some breakout boards to Molex MiniFitJr connectors. The same board can be used in 3 different configurations, so its pretty versatile.
I'm using all TXL auto grade wire. (same as the harness from DIYautotune) 20 gauge for the sensors. 16 gauge for the power/gnd to the coils. I'm using some Leash Electronics relay boards. Also have JPerf's TinyIox to handle the ADC inputs for the thermocouple amplifiers.
Heres it all somewhat complete:
Fired up the MS3X and loaded up the latest firmware (1.5.0), and tested most of my connections on the bench.
About ready to get the engine in and actually fire it up for the first time! _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
clonebug Samba Member
Joined: January 29, 2005 Posts: 4026 Location: NW Washington
Posted: Tue Sep 19, 2017 9:30 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
I put all my MS stuff under the hood.......but I can pull my hood in about 30 seconds with two bolts.....
It makes it so much easier for my old eyes to see the connectors without having to crawl in or underneath something to upgrade the wiring......
It also keeps it dry when I get caught in the rain.
I also have a bluetooth connector for my ECU to laptop. It is sooo nice to just set the computer on the seat and have it connect when I turn the key on. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Posted: Tue Sep 19, 2017 10:07 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
clonebug wrote: |
I also have a bluetooth connector for my ECU to laptop. It is sooo nice to just set the computer on the seat and have it connect when I turn the key on. |
Nice wiring. I hope mine will look that clean. I'm with ya on the ease of change, thats what I'm shooting for.
yeah, I got one of those bluetooth things too..... _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Blasted Samba Member
Posted: Tue Sep 19, 2017 10:50 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Great work, will be be keeping an eye on it. |
DeathBySnuSnu Samba Member
Posted: Tue Sep 19, 2017 5:44 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Wow!
That does look really neat and serviceable.
I had to stuff my squirt and relays just anywhere they would fit (engine is in a motorcycle style frame). |
Posted: Tue Sep 26, 2017 3:49 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
getting to the bitter end here.
Done working on it for today, but hoping to get it started this week
Posted: Fri Sep 29, 2017 5:27 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
cranked it without the plugs in to primed the oil system -- using Brad Penn 5w30
ready to fire up!
I wanna check over everything one more time, then I'll get try and get it started.
SO CLOSE! _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Howard 111 Samba Member
Posted: Fri Sep 29, 2017 6:03 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
If it runs as good as it looks, you have some good times coming your way! Nice job! _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
Posted: Tue Oct 10, 2017 1:03 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
It lives!
Went through the break-in, drove it around the block. YES!
Got one oil drip to sort out, but now I gotta get the fuel maps in order.
I gotta futz with a few things, re adjust the valves etc, but hey, it works!
madmike Samba Member
Joined: July 11, 2005 Posts: 5291 Location: Atlanta,Michigan
Posted: Thu Oct 12, 2017 3:54 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
_________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
pondervwmike Samba Member
Joined: June 16, 2017 Posts: 373 Location: Ponder(Dallas) Texas USA
Posted: Thu Oct 12, 2017 7:21 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
WOW! All those electronics make my head hurt. Good job man! _________________ 1967 Cal Look Beetle Street Car in re-restoration,customization. Mom and Dad bought it in 1983 when I was 4.
2010 VW Tiguan
2000 BMW 528i
1997 Jeep Cherokee
2127cc build thread https://www.thesamba.com/vw/forum/viewtopic.php?t=681556&highlight= |
Posted: Thu Oct 12, 2017 7:35 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Nice job, it sure looks nice. I would like to add a turbo to mine once I get it all sorted out. |
rubenski Samba Member
Joined: December 03, 2014 Posts: 100 Location: belgium
Posted: Sat Oct 14, 2017 5:46 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Nice build!
Maybe a dumb question,
Why do you have a triggerwheel setup AND a cam sensor?
Cant you use the cam sensor to tell the ecu the engine position? Why is a triggerwheel needed then? |
