theDrew Samba Member
Posted: Fri Feb 24, 2017 11:52 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
67rustavenger wrote: |
Is this beast gonna be ready for the NW Bug Run? I hope so. I'd really like to have a look at your engine.
i'll be there one way or another, I'm not sure it will be done by then, but deadlines make the world go round! _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
1985 Vanagon Campmobile w/ 2005 EJ25 |
Bret Young Samba Member
Joined: August 26, 2006 Posts: 756 Location: Turlock, CA
Posted: Fri Feb 24, 2017 12:07 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Looking good Drew!
I will be watching this build up. I have been contemplating a turbo with the CB high flow end castings for my spare 2176cc. I look forward to seeing what you do for an intercooler! |
Posted: Fri Feb 24, 2017 1:44 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Bret Young wrote: |
me too! Trying to shoe horn it all under the decklid will be interesting. I'll be using a water to air intercooler -- I need to get it in the engine bay to start mocking up how and where everything will go.
using the high flow castings will get me some extra space, that's why I decided to go that route. also, ITB's are such a pain to keep in sync. even with the SyncLink (which works fantastic), I was always fiddling with it in search of perfection. IMHO no matter what, one will follow the other. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Posted: Fri Feb 24, 2017 5:28 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
theDrew wrote: |
Bret Young wrote: |
using the high flow castings will get me some extra space, that's why I decided to go that route. also, ITB's are such a pain to keep in sync. even with the SyncLink (which works fantastic), I was always fiddling with it in search of perfection. IMHO no matter what, one will follow the other. |
I agree with you on the simplicity of the single TB versus ITB's. Not sure how the performance difference would be between the two once you apply boost though.
Since you are going the single throttle body route, you should look at how Shag did his intercooler. Mounts behind the shroud on the drivers side and makes the piping look pretty simple. I am sure there are some complexities to it, but keeps the engine bay super clean. Or are you thinking more along the lines of a barrel intercooler?
Well I am glad you are doing the ground work. Based on how yours does, will determine my plan of attack in the next year or so. |
gprudenciop Samba Member
Joined: July 06, 2008 Posts: 606 Location: portland or
Posted: Fri Feb 24, 2017 5:31 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
http://www.siliconeintakes.com/front-mount-interco...p-220.html
These are good for up to 350 hp..nice compact size.
Also look at the mustang/escort throttle body. It has a good tps and has a very easy to setup idle valve. You can also find BBK for ford (bling). _________________ Never look down at anybody unless you are helping them up..
Loaning someone your strength instead of reminding them of their weakness = kindness.. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Fri Feb 24, 2017 6:19 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
A 45mm to 50mm Single TB would probably handle whatever you would want and give you drivabilty too.
A stock German Beetle TB is 45mm and that is what I am running on my turbo. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
Chip Samba Member
Posted: Fri Feb 24, 2017 7:02 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
I have a 50mm single on my turbo driver setup. Nice and responsive. |
Posted: Tue Feb 28, 2017 10:04 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
did I mention I love anodized red? also have his red pushrod tubes as well.
heres my injectors -- flow matched and tested by FiveOh motorsports.
1000cc/min Black Ops injectors.
DIY auto tunes boost controller:
managed to get out in the garage and go over the valve train a bit. the swipe is looking good, so I dont need to futz with it.
Posted: Wed Mar 01, 2017 7:06 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Why are those spring retainers smaller in diameter than the springs????? _________________
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
Posted: Wed Mar 01, 2017 9:00 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
clonebug wrote: |
Why are those spring retainers smaller in diameter than the springs????? |
i trust Steve & Greg Tims expertise. I haven't changed anything on them. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
sled Samba Member
Posted: Wed Mar 01, 2017 9:57 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
awesome build, cant wait to see the finished product. I might have to track you down at a show and ask for a ride
curious though, are your head studs different lengths?
are you hoping for reduced knock and/or detonation by running squishies with that compression ratio? _________________ drive your split. |
Posted: Wed Mar 01, 2017 10:02 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
sled wrote: |
are you hoping for reduced knock and/or detonation by running squishies with that compression ratio? |
ha, good eye -- I'm using some SCAT 8740 studs which are 1/2" longer than stock. I only cut down the ones that interfered with the rocker assembly.
yes, the squishies let you run higher CR on boost. I believe Chip B was pushing 20lbs on pump gas, and like 28lbs on E85 and his static CR was like 9.2. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
d5626 Samba Member
Joined: December 09, 2008 Posts: 154 Location: Pomona
Posted: Wed Mar 01, 2017 4:40 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
You're sure gonna have a whole lot of fun when done. Your build is on point. Some advice I do have is to build up the fuel system to support those injectors to their max so you dont have to go back and redo again when on E85 you find that more than 300hp sounds like fun. I don't know if youve ever tuned F.I. before but once thru the newness/learning curve the ability to add more and moore boost/power and control it with the ecu is exciting like the feeling of going from a1600 to a built 2ltr for the first time. I'll be looking forward to your updates. |
Chip Samba Member
Posted: Wed Mar 01, 2017 5:16 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
theDrew wrote: |
sled wrote: |
yes, the squishies let you run higher CR on boost. I believe Chip B was pushing 20lbs on pump gas, and like 28lbs on E85 and his static CR was like 9.2. |
My highest 91 octane pump gas number was just over 24psi, without water/meth. I'm a believer |
Dave's 65 Samba Member
Joined: February 27, 2017 Posts: 5 Location: Tennessee
Posted: Wed Mar 01, 2017 6:47 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
So do you have your heads cut to fit the piston crown? Is there a one stop for buying the pistons and having your heads cut to utilize them? What about running e85 with this set up and an even higher static CR? I ask because I am working on putting together a 2276 for my 65 plan is high CR (12:1) naturally aspirated efi and possibly turbo it later on. |
Chip Samba Member
Posted: Wed Mar 01, 2017 6:59 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Dave's 65 wrote: |
I recommend building it one way or the other. With big chambered heads, there is not a lot of clearancing required. I have had to do minor chamber manipulation in the past. All of my heads have had chambers in the 60+cc range. Small chamber heads are where the clearance horror stories come from. |
Posted: Thu Mar 02, 2017 7:44 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Chip B. wrote: |
Dave's 65 wrote: |
It would seem that this set up along with e85 would provide a large gain in power not to mention the cooling effects from both also with e85 you should be able to raise cylinder pressure even higher am I tracking here? |
Posted: Thu Mar 02, 2017 9:17 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Dave's 65 wrote: |
correct, and e85 has a higher octane rating.
so downside is your fuel system has to handle almost 25% more flow, but if planned correctly and with a flex fuel sensor you can adjust for it all in real time. _________________ Turbo 2276 MS3X build http://www.thesamba.com/vw/forum/viewtopic.php?t=673125
Chip Samba Member
Posted: Thu Mar 02, 2017 11:56 am Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
theDrew wrote: |
Dave's 65 wrote: |
so downside is your fuel system has to handle almost 25% more flow, but if planned correctly and with a flex fuel sensor you can adjust for it all in real time. |
I switch between e85 and gas regularly. I have a sensor. Works great. |
Posted: Thu Mar 02, 2017 11:28 pm Post subject: Re: Down the rabbit hole -- 2276 MS3X Turbo build |
Little more work tonight...got the pushrod tubes on and pushrods and rockers on.
Jaycee red (of course) push rod tubes, ACN's Heavy Duty Ally PR's and some lash caps. (I know the debate on these, I like em, but I know some dont)
I took a set of Scat SS valve covers and welded on some AN-8 breather ports on the 1-2 side. two of em, cuase why not.
Speaking of AN fittings, here's my stash of AN-6 for fuel, AN-8 for oil and breather hoses, AN-10 for the turbo drain, and AN-4 for the turbo feed -- been buying em a couple at a time for months.
I got a Setrab 1x19row oil cooler to add to the million things that will be going on in the engine bay.
And a Mocal thermostatic sandwich plate to hook it in to the oil system
