Dellorto DRLA float needle clip
EMPIImp69
EMPIImp69 is offline
PostPosted: Thu Feb 23, 2017 9:19 am    Post subject: Dellorto DRLA float needle clip Reply with quote
Anyone know the size of these clips for Dellorto DRLA float? Seems to be metric, trying to source 2 of them locally, Thanks
http://www.fastech-racing.com/dellorto-needle-clip.html
1963 Ragtop Bug
Danwvw
Danwvw is offline
PostPosted: Thu Feb 23, 2017 11:59 am    Post subject: Re: Dellorto DRLA float needle clip Reply with quote
Like little get 3 sizes at the hardware store one will fit! Yeah, I got a hold of a carb the other day that did not have one. Really though I don't think it's going to be a problem to run without one.
1960 Beetle And 1679cc DP W-100 & Dual Zeniths!
EMPIImp69
PostPosted: Thu Feb 23, 2017 12:15 pm    Post subject: Re: Dellorto DRLA float needle clip Reply with quote
Yea I got the 2 smallest ones at HD, but the smallest still slides off. I may run the carbs without them, Thx
1963 Ragtop Bug
Danwvw
Danwvw is offline
PostPosted: Thu Feb 23, 2017 12:24 pm    Post subject: Re: Dellorto DRLA float needle clip Reply with quote
Humm, I have seen those at the local true value store the kind they have in the assorted sizes and the smallest is too small. But Yeah, they come in metric sizes like 2 mm or something. I think the size must be the ID the size of shaft they fit so they would be pretty little that little float shaft can't be much more than 1/16".
esde
esde is offline
PostPosted: Thu Feb 23, 2017 3:20 pm    Post subject: Re: Dellorto DRLA float needle clip Reply with quote
you can run without them, as there is no way for the screw to back out when the top is on the carb.
modok wrote:
mcdragracer
mcdragracer is offline
PostPosted: Thu Feb 23, 2017 11:11 pm    Post subject: Re: Dellorto DRLA float needle clip Reply with quote
Yes not necessary, but if you want I'll send you 2 for free.
j-dub
j-dub is offline
PostPosted: Fri Feb 24, 2017 8:02 am    Post subject: Re: Dellorto DRLA float needle clip Reply with quote
Without the e-clip the float can slide back and fourth and sometimes the float will bind in the far position. I have seen a small bit of wire twisted around the shaft in the grove to work in a pinch.
1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on."
HBRag
HBRag is offline
PostPosted: Fri Feb 24, 2017 12:01 pm    Post subject: Re: Dellorto DRLA float needle clip Reply with quote
Measure the groove, and you can get clips here;
https://www.mcmaster.com/#retaining-rings/=16hw0m0
Danwvw
Danwvw is offline
PostPosted: Tue Feb 28, 2017 5:56 pm    Post subject: Re: Dellorto DRLA float needle clip Reply with quote
The Samba Ad: Dellorto DRLA Float Securing E-Clips Price: $.25.
