Terry Kay Banned
Posted: Thu Mar 16, 2017 7:50 am Post subject: Re: Front Suspension: how far to go & how to proceed? |
If you are using 12 point chrome sockets, they will fail.
You didn't break a 6 point impact socket on them fasteners.
The issue with the map gas setup, it doesn't have a small enough focused tip to use.
Oxy acetylene torch does, and develops more heat to break them frozen fasteners loose.
Be creative, soak a rag wet & wrap what you don't want to burn. _________________ T.K. |
epowell Samba Member
Joined: September 23, 2015 Posts: 4733 Location: Czech (mostly) Vancouver (sometimes)
Posted: Thu Mar 16, 2017 8:36 am Post subject: Re: Front Suspension: how far to go & how to proceed? |
Chuey wrote: |
If the shock is new, the nut should not be frozen. |
That's exactly what I was thinking too... the PO said they are new.... ...or maybe they we done like 2 years ago and installed by some bozo with an impact gun? _________________ www.edwardpowell.com |
Terry Kay Banned
Posted: Thu Mar 16, 2017 8:49 am Post subject: Re: Front Suspension: how far to go & how to proceed? |
Impact on-impact off. _________________ T.K. |
61Scout Samba Member
Joined: November 06, 2011 Posts: 1297 Location: Shoreline/Yakima WA
Posted: Thu Mar 16, 2017 8:52 am Post subject: Re: Front Suspension: how far to go & how to proceed? |
Impact guns help a lot in removing fasteners. The vibration and constant hammering they create on a fastener does wonders to loosen them. In a shop environment, flat rate techs will only torque down what they consider critical. Some techs don't even turn their gun down for fasteners they know need low torque. Time is money, zap it on. I wouldn't be surprised at all if the shock bolt was impacted on there.
You don't need a torch to remove the tie rod end. The nut is already off. Hit the knuckle with a ball peen hammer and it will pop out. Get it in a spot where your blow will be absorbed into the fitting (straight shot) and not try to turn the knuckle as you are hammering. Sometimes they don't come out, but it's pretty damn rare, tbh. In those cases a tech would use a tool called a pickle fork to help pop it off. At that point, the tie rod end would need to be replaced. Frankly, I'd just go ahead and replace the tie rod end unless you know it to be new/low mileage.
If you don't have an impact gun and aren't ready for air tools, at least buy one of these: https://www.amazon.com/Lisle-30200-Hand-Impact-Too...pact+1%2F2
Have someone weld a chunk of rod on the side that you can slide a pipe over and this will give you good leverage (so you don't have to rely on your hand grip.) Then hammer away at fasteners.
Some of these fasteners may need to be cut out if they are too far gone. For stuff like the connection on the steering column where it's just a through bolt, I wouldn't waste much time fighting it. If it didn't come off, I'd just cut it off. Here, an angle grinder works well, or an oscillating tool like this: https://www.amazon.com/Rockwell-Sonicrafter-Oscill...ation+tool
Having the right tools sure makes the work easy. I imagine building high end custom musical instruments is the same.
-Kevin _________________ 1986 Westfalia Weekender Wolfsburg, RJE 2.3
1985 Tin Top, Subie 2.2 + 5MT
Floppy Mirrors no more: http://www.thesamba.com/vw/forum/viewtopic.php?t=653018&highlight=
Remove the front spindle nut with ease: https://www.thesamba.com/vw/forum/viewtopic.php?t=679567&highlight=
Remove the rear wheel bearing housing without messing with the big 46mm nut: https://www.thesamba.com/vw/forum/viewtopic.php?t=679507&highlight=
-Nec Spe, Nec Metu |
Posted: Thu Mar 16, 2017 9:22 am Post subject: Re: Front Suspension: how far to go & how to proceed? |
The only things left causing me major aggravation are:
1) tie rods
2) lower shock bolts
3) dr.side caliper bolts
I am going to try the wax trick on those caliper bolts.... see if it helps. I am SURE they were impacted on there. _________________ www.edwardpowell.com |
Posted: Thu Mar 16, 2017 11:39 am Post subject: Re: Front Suspension: how far to go & how to proceed? |
...at the end of the day > sore hands and muscles... made some gains, but still somewhat stuck.
I torched and torched and waxed and torched and torched again those caliper bolts and they AIN'T GOIN' NOWHERE FAST!
OK, my plan for those currently is simply leave the rotors/calipers still on there as I remove the entire octopus assembly LCA, RR, SK, SPINDLE, and ROTOR/CALIPER > gonna be a heavy mother but so be it... then once off it will be easier to deal with on the bench, and very very likely I will take to my local shop and have them impact gun the buggers off!!
So all I am left with then are the LOWER SHOCK BOLTS (looks like I can torch them without fear of burning the shocks)... and somehow deal with the TIE ROD ends.
Still attempting to detach some of these brake lines and on the OTHER side I ended up twisting and ripping open a line! ...I think the writing is on the wall and I need to take a serious look at those brake lines > chances are they are original and on their last legs... I am assuming that if two times now they just basically crumbled when loosening a bolt, then that means they are all really old. OK, new brake lines can't be so expensive > just a lot of fiddly work to get them in.
Posted: Thu Mar 16, 2017 12:01 pm Post subject: Re: Front Suspension: how far to go & how to proceed? |
This looks cool.... will it also work with regular 1/2" sockets? _________________ www.edwardpowell.com |
Posted: Thu Mar 16, 2017 12:49 pm Post subject: Re: Front Suspension: how far to go & how to proceed? |
epowell wrote: |
This looks cool.... will it also work with regular 1/2" sockets? |
Yes, it will work with 1/2 sockets. The head piece (the one that holds the screwdriver bits) comes off and just leaves a regular 1/2 drive. This device works by grasping the outside handle and then twisting it to the left. Inside there's what I imagine to be a ramp device, so that when it's twisted to the left it's at the top of the ramp. When you hammer on the end, it drives down the ramp and forces the driver to the left to loosen. It's dependent upon holding the outside casing though, and that's why I recommended having a rod welded to the outside of the handle. This way you can slip a hollow tube over the end to help hold it. Otherwise you can get in the situation where when you hammer on the end to drive the tool the outside casing just spins in your opposite hand. Each time the driver successfully rotates left the handle needs to be turned again to reload the tool to prepare for the next hammer blow. Before the fancy cordless impact drivers were around, this is what guys would bring to the junkyard with them when something had to be impacted off. It's basically a poor man's impact gun. Effective, but very very slow.
Posted: Thu Mar 16, 2017 12:53 pm Post subject: Re: Front Suspension: how far to go & how to proceed? |
61Scout wrote: |
that's why I recommended having a rod welded to the outside of the handle. This way you can slip a hollow tube over the end to help hold it. |
Kinda hard to picture that... a photo would help... _________________ www.edwardpowell.com |
Posted: Thu Mar 16, 2017 1:46 pm Post subject: Re: Front Suspension: how far to go & how to proceed? |
epowell wrote: |
61Scout wrote: |
Kinda hard to picture that... a photo would help... |
Sure thing. I simply have a nut welded at the bottom of mine. When I need it, I screw in a bolt and then slide a chunk of pipe over that. Please excuse my sloppy/hasty welds, I wasn't going for pretty here.
The set up:
Bolt in and socket on:
Pipe slid over, ready for action:
I'll refer you to YouTube for videos on how-to use it, but I just checked and there are plenty. Most of the videos deal with stuck screws, but the principle is the same. There are many limitations with this tool... it doesn't always get into tight spaces, it requires two hands to use, it can be awkward to hold, and so on. But all in all it's a great tool to have around the shop. It's really a must have tool for stuck screws.
Posted: Thu Mar 16, 2017 1:57 pm Post subject: Re: Front Suspension: how far to go & how to proceed? |
Amazing.... I will looking into finding one here in Czech! _________________ www.edwardpowell.com |
Posted: Fri Mar 17, 2017 3:08 am Post subject: Re: Front Suspension: how far to go & how to proceed? |
I managed to free up the lower shock bolts by torching them... but some rubber burning smoke came out so I wonder what that was... I guess I will find out once I fully remove those shocks.
Finally those TIE RODs are NOT popping out!! I tried wrapping the balljoint in a wet rag and using a piece of aluminum sheeting as a heat shield and torched it a bit, but didn't want to go crazy because those TIEROD BALLJOINTS are new and good....
....here on this vid at 5:55 it shows a guy doing what I think is a good technique for freeing up the tie rods... I noticed that he actually does tap a bit on the bottom of the bolt, but not on the threads... I will try again... https://www.youtube.com/watch?v=dLVvS6CuNlQ _________________ www.edwardpowell.com |
Posted: Fri Mar 17, 2017 4:33 am Post subject: Re: Front Suspension: how far to go & how to proceed? |
Wow... I got that TIE ROD freed up on one side - by wrapping in wet cloth, and using a heat shield, then hammering, also a little bit from the bottom but not on the threads... and it popped free Gives me hope > but then spent another hour on the stuck side - lots of torching hammering etc and still totally stuck.
Next, after lunch, I will try a more focused torching from ALL SIDES... see if that helps. I sure hope I can get this off today because thereafter I can dismantle everything! _________________ www.edwardpowell.com |
Posted: Fri Mar 17, 2017 10:44 am Post subject: Re: Front Suspension: how far to go & how to proceed? |
Serious Issue with dr.side TIE ROD
I tried everything possible with my limited tool selection. The threaded portion of the tie rod is 1/2" shorter than the other side which came out. Now I understand why. I also now understand why we are not supposed to hammer on the end of that threaded part. It mushrooms. So obviously this has happened before and someone solved it by chopping off the mangled end of that threaded portion.
Anyway I torched and hammered for AGES! No movement whatsoever! I then tried to make a puller - didn't work... Then resigned to the fact that that tie rod is toast, I torched some more frying the boot etc... then hammered with a VERY large hammer..... nothing. I think it needs an oxygen torch.
Help! Any suggestion?
I am tempted just to cut it off, that way I could bring the piece to a garage with oxygen and get it off... Does this sound like the most reasonable approach? ...or?
Thanks
unibagel Samba Member
Joined: December 02, 2004 Posts: 529 Location: Bflo, NY
Posted: Fri Mar 17, 2017 12:05 pm Post subject: Re: Front Suspension: how far to go & how to proceed? |
I've always had good luck doing this: heat, quench with liquid wrench, heat, quench, repeat. Then hit with two hammers on opposite sides. It should pop out. |
Posted: Fri Mar 17, 2017 12:10 pm Post subject: Re: Front Suspension: how far to go & how to proceed? |
unibagel wrote: |
I think it is beyond that... I spend hours doing that today and it is just frozen... I think I need to cut it off now > but hesitate to do it - don't want to create a bigger problem. _________________ www.edwardpowell.com |
Posted: Fri Mar 17, 2017 12:43 pm Post subject: Re: Front Suspension: how far to go & how to proceed? |
61Scout wrote: |
Sorry it's being a PITA. That happens sometimes. You'll have to cut off that mushroomed end now. For future reference, leave the nut on the end if you're tapping on it, and try to get the nut flush with the end. Also it's vibration you're going after when tapping on the end, think light rapid taps. There's really no need to wallop on it.
Believe me, for hours I will tapping and tapping, then heating and tapping, and tapping also with the nut as it was supposed to be. The other side responded well, but the dr. side no luck... I only started walloping on it in final desperation.
Of course having the right tools would save the day. I think now I have no choice but to cut it completely off, and replace both TIE RODS.
On the side that came free, the tie rod ball joint is somewhat floppy - this is not go, is it not? The should be very stiff, no? _________________ www.edwardpowell.com |
Posted: Sat Mar 18, 2017 5:10 am Post subject: Re: Front Suspension: how far to go & how to proceed? |
This is how I have been dealing with the STEERING RACK & TIE RODs. I disconnected the steering rack as much as possible > in fact everything except that one frozen tie rod end... Then I loosed the retaining nut on the buggered tie rod end. Then lowered the entire steering rack, supported it, and carefully rotated it 15.5 times until it unscrewed from the fried tie rod end... this way I was able to completely remove the steering rack, and I know how many times I must turn the new tie rod end on (15.5 times.... the other side is 13 times).
Funny thing is that on the buggered tie rod side, the entire tie rod is very new, and the inner tie rod ball joint is nice and firm... however on the pass.side where the tie rod end came out easily, this tie rod and end are very old and both inner and outer tie rod ball joints are toast. [I will take the messed up tie rod end to a shop for extraction]
Next up, the most difficult part (I assume) --- taking out the spring and then the entire LCA+ assembly... _________________ www.edwardpowell.com |
