Erocku Samba Member
Joined: December 31, 2012 Posts: 21 Location: Houston, TX
Posted: Wed Mar 01, 2017 5:34 am Post subject: '74 Baja Bug Ecotec Build |
I purchased this 1974 Beetle 5 years ago. I started to work on it a little bit, but had to put the project on hold for a little while. I was originally going to stick with an aircooled engine, but after researching, I'm going to put in an Ecotec. I just started working on it again, so here's my progress so far.
The day I towed it home.
When I first got it, I cut the back end and installed high clearance fiberglass fenders using nutserts to attach them to the body.
I picked up some slick mirror brackets from Race Ready Products and installed them using some 4mm nutserts.
I just got in my one piece fiberglass front end from Mark V Fiberglass. These pictures are how it lines up right now. I need to trim it up to follow the body lines a little better.
pallen Samba Member
1fastbigguy Samba Member
Posted: Wed Mar 01, 2017 9:45 pm Post subject: Re: '74 Baja Bug Ecotec Build |
Looks like s great start! I look forward to watching your progress. _________________ Cheers!
59 Ragtop
61 Ragtop Baja
69 Squareback
@Dustydrone
#Ohibaja
Our Build
http://www.thesamba.com/vw/forum/viewtopic.php?t=545394 |
Erocku Samba Member
Posted: Thu Mar 02, 2017 4:53 am Post subject: Re: '74 Baja Bug Ecotec Build |
After work yesterday I had some time to work on the fitment of the one piece front end. I had made a mark on the body where the center of the hood should be. I then drew a line for the center of the fiberglass front end. I lined them up and pushed the hood as close to the body as possible. I noticed that I had about a 5/8" gap on the sides where the fiberglass meets the door. I then mesaured off 5/8" from the hood cut on the body to the fiberglass front end at several points on the fiberglass front end. I connected the dots and used my air body saw to trim it up. A little bit of sanding and it's really close.
On my passenger lower trailing arm, I noticed it looks like my torsion spring busted through the arm.
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Mar 02, 2017 5:39 am Post subject: Re: '74 Baja Bug Ecotec Build |
There is just a press fit cap on the end of the arms that must have come off. If it's come out the end, it has either come loose from the retaining screw in the center of the beam, or broken and that half has worked its way out. |
dustymojave Samba Member
Posted: Mon Mar 06, 2017 9:11 pm Post subject: Re: '74 Baja Bug Ecotec Build |
Loosen the locking nuts on the grub screws at the center and at the trailing arms on both sides. Then tap the ends of the torsion leaves to tap them into place. Then re-tighten the grub screws and jamb nuts. The cap can be replaced with a washer or a slug of flat stock tack welded in place. _________________ Richard
SoCalBajas Member
Erocku Samba Member
Posted: Mon Mar 13, 2017 6:23 pm Post subject: Re: '74 Baja Bug Ecotec Build |
I started drilling out the welds to remove the headliner tabs since there won't be a traditional beetle headliner.
I started mounting the fiberglass front end with dzus fasteners. I used some cleco fasteners to keep everything lined up. They worked great. I finished the 3 on the passenger side and completed the top one on the driver side.
Erocku Samba Member
Posted: Thu Mar 16, 2017 5:53 pm Post subject: Re: '74 Baja Bug Ecotec Build |
I finished up securing the fiberglass front end to the body using dzus fasteners. I trimmed up the part where the hood line dips down to where it cuts back to the door frame. I made it follow the body line. I still have a little bit more sanding/shaping to do.
Stingray250 Samba Member
Posted: Fri Mar 17, 2017 6:23 pm Post subject: Re: '74 Baja Bug Ecotec Build |
Nice fit... Just a suggestion, you may want to give that lip at the windshield area a tiny bit of a gap...
I originally set mine up like you have yours and found that it wore the paint a little thin from being too tight and in continuous contact with the windshield cowl...
Just mt 2 cents...
Didn't mean to hijack your tread...
If you have any questions, hit me up... I have a Fiat X1/9 I'm cramming a Turbo Eco into at the monent plus this Turbo Eco VW... Ain't a whole lot I don't know about these little monsters!
I just realized, we're neighbors! I'm out in Spring just north of Houston... Good luck with the build... Once you Eco you'll NEVER go back to air cooled....
Erocku Samba Member
Posted: Sat Mar 18, 2017 6:05 am Post subject: Re: '74 Baja Bug Ecotec Build |
Nice ride! I'm a little more north than you. I'm up in Cleveland. I'll definitely hit you up with any questions on the conversion.
When I fastened the front end, i did leave 1/8" or so gap between the fiberglass and metal. I had it right up against it in the picture when I was shaping it to the contour of the body. |
Erocku Samba Member
Posted: Tue Nov 28, 2017 4:25 pm Post subject: Re: '74 Baja Bug Ecotec Build |
I'm back to working on this again. I removed the front beam and extended it as detailed here: https://www.thesamba.com/vw/forum/viewtopic.php?t=365665
I ordered some 3" lifted spindles that add 1/2" per spindle so I extended the beam 5". I used some angle iron and a ratchet strap to hold everything together tight while I tacked everything in place with my little MIG welder. I then handed the beam over to my dad to have him weld it up with a better welding machine.
I've cut my torsion leaves in half, but I still need to re-dimple them. I'll be moving the beam brackets, steering stop, and steering damper mount this weekend (hopefully). I also need to drill out and weld the rod into the beam for the hook and rod stop. |
Team T&A Samba Member
Posted: Mon Dec 04, 2017 7:52 pm Post subject: Re: '74 Baja Bug Ecotec Build |
Looking good, I'm getting back on mine too. |
Erocku Samba Member
Posted: Fri Dec 08, 2017 8:13 pm Post subject: Re: '74 Baja Bug Ecotec Build |
I just received my shocks. Bilstein F4-BOA-0000304 6100 Series.
Erocku Samba Member
Posted: Sun Dec 10, 2017 5:13 pm Post subject: Re: '74 Baja Bug Ecotec Build |
I removed the beam brackets, steering stop, steering box bracket stops, and the steering damper bracket. I tacked in the rods for the hook and rod stops. I haven't welded in the beam brackets in their new positions yet. They're a little rusty on the inside so I need to get them cleaned up first.
Erocku Samba Member
Posted: Wed Dec 20, 2017 6:00 pm Post subject: Re: '74 Baja Bug Ecotec Build |
I received my column back from being powdercoated gloss black. I reinstalled the ignition cylinder. I had told the powdercoater to please leave the center of the column alone (I taped over it with red electrical tape) so the bearing would re-install without a problem, but they didn't. I had to scrape/sand the powdercoat out of that area. The grease had dried and hardened on the bearing. I cleaned it up and re-greased it. I'm awaiting a new bushing and a few other parts.
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Wed Dec 20, 2017 11:42 pm Post subject: Re: '74 Baja Bug Ecotec Build |
Nice build project. ...looks like you have made some good progress so far...I was wandering where those side mirrors came from. ...now I know. ...I visited their website but they are out of stock. ...good thing cuz I would have bought some for my Fiat 500 baja build, but I think I'll just build my own...what size ecotec are you doing?...I have a new 2.4 adapter that I never used still in the box from Kennedy....decided to just stay AC.
VeeWeeman |
Erocku Samba Member
Posted: Thu Dec 21, 2017 5:18 am Post subject: Re: '74 Baja Bug Ecotec Build |
Those mirrors never showed an add to cart button even when in-stock. I had to call race ready to order them. I did plan on going with a 2.4 Ecotec. |
Posted: Thu Dec 21, 2017 8:33 am Post subject: Re: '74 Baja Bug Ecotec Build |
Erocku wrote: |
If you're interested in my adapter from kennedy send me a PM, I'll give you a good price. |
mk7kyle Samba Member
Joined: September 18, 2017 Posts: 1 Location: New York
Posted: Thu May 10, 2018 10:32 am Post subject: Re: '74 Baja Bug Ecotec Build |
How do the vent windows work with those mirrors. Can you still open them most of the way? |
Dose Samba Member
Joined: September 09, 2017 Posts: 35 Location: Mammoth
Posted: Fri May 11, 2018 10:11 am Post subject: Re: '74 Baja Bug Ecotec Build |
nice start, this will be a fun build to watch |
