BN4 Fuel Pump Tee-Piece - Where from?
coopster
coopster is offline
PostPosted: Thu Mar 02, 2017 8:06 pm    Post subject: BN4 Fuel Pump Tee-Piece - Where from? Reply with quote
Anyone know where i can get the tee-piece that goes between the fuel tank / eberspacher pump and main fuel line.
The intake for the fuel pump seems smaller the 5.5mm standard rubber fuel hose
thanks in advance
Chris
ldj1002
ldj1002 is offline
PostPosted: Fri Mar 03, 2017 6:34 am    Post subject: Re: BN4 Fuel Pump Tee-Piece - Where from? Reply with quote
thanks in advance
Chris
You can buy a T many places, hardware store, Building materials store, auto store, and others. I got mine at auto supply along with the fuel hoses needed. The fuel hoses or the T probably aren't the exact original size but they work good.
EDIT, I just noticed you are in UK so all bets off. At any rate that is where I would start. Good luck.
