aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Mar 03, 2017 12:02 pm Post subject: Original 1971 Carburetor part number |
Guys,
I'm trying to take my bus all the way back to stock engine wise. I just received a nice rebuilt 205Q distributor and now I'm planning to have Tim@volksbitz build be the correct 34PICT-3 for it. Problem is that there are several different 34's out there. The Old Volks Home has a nice list for distributors but I haven't been able to find a similar list for the carb. Post a pic of it too if you have one.
TIA _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
vwed Samba Member
Joined: August 07, 2004 Posts: 127 Location: United Kingdom
pittwagen Samba Member
Joined: November 08, 2005 Posts: 766 Location: North of the 49th parallel
Posted: Fri Mar 03, 2017 12:43 pm Post subject: Re: Original 1971 Carburetor part number |
You will need the original engine code as well as any M codes associated with it. I assume you have the info from your M code plate.
So I gazed into the crystal ball and here is what I found. Scroll down to the 34 PICT-3 info:
http://www.oemepc.com/vw/part_single/catalog/vw/ma...359/lang/e |
Posted: Fri Mar 03, 2017 1:11 pm Post subject: Re: Original 1971 Carburetor part number |
Thanks guys. I'm away from the vehicle right now but I do have the VIN, just not the M-plate. Looks like there were two carbs installed on the dual port 1971. Either a 211 129 031F or a G. Looks like the F was on AD engines and the G was on AE engines. So now I need to see what the difference between those engines is.
VIN: 221217257 _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
busdaddy Samba Member
Posted: Fri Mar 03, 2017 1:20 pm Post subject: Re: Original 1971 Carburetor part number |
Andy (Glutamodo) told me that base numbers VW 280-1, VW 327-1 or VW 327-2 were all 71 bus only carbs, Tim hooked me up with a 327-2 and it works great. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Mar 03, 2017 1:25 pm Post subject: Re: Original 1971 Carburetor part number |
So Mark,
Yours is correct in your 1971? Got any pics of it installed? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Mar 03, 2017 1:41 pm Post subject: Re: Original 1971 Carburetor part number |
Best one I have at this time, it's from the fuel pressure thread (much has changed since, but the carb remains):
As for correctness I trust Andy's information, and it plays well with the 205Q, can't recall the Pn# on the tag, Tim may have some of that info as well. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Fri Mar 03, 2017 1:45 pm Post subject: Re: Original 1971 Carburetor part number |
I was pretty sure my first 1971 bus purchased around 1979 had the dash pot like yours does. Tim sold you the carbs with dash pot and positioner? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Mar 03, 2017 1:47 pm Post subject: Re: Original 1971 Carburetor part number |
I suspect there may be some correlation between engine code and carb #.
In my small world sample my 73 beetles (one standard and one super) were made approximately 2.5 months apart. Both engine codes are AK and engines are 60,000 numbers apart. Both use the 377-2 carb.
FYI. |
wcfvw69 Samba Purist
Posted: Fri Mar 03, 2017 2:07 pm Post subject: Re: Original 1971 Carburetor part number |
I didn't think the dashpots were installed on the 34-3 solex carbs until 1972-1973?
The 1971 VW bus owners manual shows the dual port engine with a Solex 34-3 without a dash pot.
Anyone know for sure? _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Fri Mar 03, 2017 2:34 pm Post subject: Re: Original 1971 Carburetor part number |
The M Code info specific to the vehicle will tell all. |
Posted: Fri Mar 03, 2017 2:38 pm Post subject: Re: Original 1971 Carburetor part number |
I just looked at the Bentley service manual. It says all 1971 buses had the dash pot.
EDIT- I wonder why? They were also delivered with the altitude throttle positioner on 1971 buses as well.. Both the dash pot and throttle positioner are holding the throttle from slamming closed. Why do you need two systems for the same thing?
As Johnny Carson would say "I did not know that".. _________________ Contact me at [email protected]
Posted: Fri Mar 03, 2017 4:20 pm Post subject: Re: Original 1971 Carburetor part number |
Tim supplied that dashpot, I already had the TP on the old carb as well as another sketchy dashpot. 17 years ago when I was undoing the hodgepodge of PO supplied parts the Bentley showed a dashpot so I put one on, can't say if it belongs but I parted a couple of fairly OG 71's for that project and they had them too. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Fri Mar 03, 2017 5:36 pm Post subject: Re: Original 1971 Carburetor part number |
My '71 originally had the dashpot and the altitude adjustment. I was young and stupid and tossed them along with the OG distributor..... _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Fri Mar 03, 2017 6:46 pm Post subject: Re: Original 1971 Carburetor part number |
TomWesty wrote: |
My '71 originally had the dashpot and the altitude adjustment. I was young and stupid and tossed them along with the OG distributor..... |
I'm dumb too _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Mar 03, 2017 7:50 pm Post subject: Re: Original 1971 Carburetor part number |
Yea, thanks again Gary and Mark.. I just dropped more money on a new dashpot to make my 71' German Solex carb correct.. _________________ Contact me at [email protected]
Posted: Fri Mar 03, 2017 8:16 pm Post subject: Re: Original 1971 Carburetor part number |
Where and how much? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Posted: Fri Mar 03, 2017 8:29 pm Post subject: Re: Original 1971 Carburetor part number |
aeromech wrote: |
Where and how much? |
There was one NOS one for sale in the classifieds. I grabbed it. I paid.......$50 bucks!
Being a purist isn't cheap! I also googled around and didn't see anything else. Gary, I'd check with Tim, I bet he has a bucket of good used ones. _________________ Contact me at [email protected]
Posted: Fri Mar 03, 2017 8:45 pm Post subject: Re: Original 1971 Carburetor part number |
Waiting to hear back from Tim. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
VolkzBitz Samba Member
Joined: April 30, 2009 Posts: 300 Location: Washington State USA
Posted: Fri Mar 03, 2017 10:43 pm Post subject: Re: Original 1971 Carburetor part number |
My ears were burning.
Yes, I have lots of old but good dashpots and throttle positioners, even some new dashpots. I can include a used one or both with a restored carburetor no charge, or I can sell if you need one. _________________ http://volkzbitz.com
Quality VW Solex carburetor restoration
[email protected]
Der Vergaser Meister |
