Tom Powell Samba Member
Joined: December 01, 2005 Posts: 4855 Location: Kaneohe
Posted: Fri Mar 03, 2017 6:12 pm Post subject: When do I run out of fuel? |
I know that the Bentley says my Vanagon fuel tank holds 16 gal. and the reserve is 2.5 gal. I also know that when the fuel level gets low the gauge readings change with acceleration, deceleration, uphill and downhill driving. I also know that the engine will starve with low fuel on long right hand turns. I've never had to fill more than 13 gal. to top off the tank. Today my gauge needle went down to absolute zero and back up above the reserve red line before I put in 13.5 gal. I've never driven until the engine quit from lack of fuel. Aircraft fuel tanks capacities are described as a total fuel quantity and usable fuel quantity.
What is the usable fuel quantity in a Vanagon tank and what will be the gauge reading/behavior nearing the end of usable fuel?
Aloha
tp |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Fri Mar 03, 2017 6:48 pm Post subject: Re: When do I run out of fuel? |
I think this will vary a bit from one van to the next. What I did was start with an empty tank, then add 1 gallon at a time taking a photo of the gauge each step of the way:
What I need to do sometime is drive until the gas runs out and see what the gauge says then as I doubt I get to use all of that last gallon or two. |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Mar 03, 2017 6:58 pm Post subject: Re: When do I run out of fuel? |
I happen to know that I have exactly 2 gallons at the top of the red reserve mark,
indicating 40 miles to stalling from lack of fuel (at which point the right edge of
the needle is below but still just touching the left edge of the reserve mark)
Ask me HOW I know...???
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Terry Kay Banned
Posted: Fri Mar 03, 2017 6:59 pm Post subject: Re: When do I run out of fuel? |
You have a trip gauge, about 200 miles start looking for a pump pretty quick, leisurely at 180-190 miles.
I never have relied on that gauge alone.
I have never seen identical vehicles that get the same reading on the gas gauge. _________________ T.K. |
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Fri Mar 03, 2017 7:21 pm Post subject: Re: When do I run out of fuel? |
Terry Kay wrote: |
I have never seen identical vehicles that get the same reading on the gas gauge. |
Same here, although i push it to 220-240 in my 2wd, 240-260 in my syncro. I never rely on the gauge |
Zeitgeist 13 Samba Member
Posted: Fri Mar 03, 2017 7:53 pm Post subject: Re: When do I run out of fuel? |
I recently serviced an '80 Westfalia with a tank that showed several significant impacts to the tank. These impacts pushed the bottom upwards and appear to have reduced the interior volume by up to a gallon or so. I looked at my own fuel tank which is currently out of the van, and it too shows signs of experiencing impacts that reduce the interior volume. The point being that even the literature on factory interior volumes may not be correct any longer. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Fri Mar 03, 2017 8:52 pm Post subject: Re: When do I run out of fuel? |
My gauge goes from full too beyond E in a 75 mile span. Never do I go more than 100 w/o filling cause I have no idea what's left in there. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Posted: Fri Mar 03, 2017 9:03 pm Post subject: Re: When do I run out of fuel? |
AZ Landshaper wrote: |
My gauge goes from full too beyond E in a 75 mile span. Never do I go more than 100 w/o filling cause I have no idea what's left in there. |
I guess you won't be driving I-70 from Green River to Salina - unless they have built a gas station along there since the last time I went through.
Seriously, what sort of mileage are you getting? I know gas is cheap in AZ but if you're in single digits you might want to know why.
Apparently they have not.
http://www.deseretnews.com/article/865586821/No-bull-no-service-for-106-miles.html |
dyldebus Samba Member
Posted: Fri Mar 03, 2017 9:13 pm Post subject: Re: When do I run out of fuel? |
My Van's gauge stops right at the top line when full and is buried below the line when completely empty.
My friends Van (which I found out the hard way) is the opposite. His gauge is off the charts when full and completely empty just in the red.
That said, don't trust other peoples gauges. Your best bet is to carry a gas can on your next fill up and drive it like you normally do until you run out and get an idea of where your gauge sits.
OBVIOUSLY don't do this if your drive is on busy highways or in jam packed cities. I've run out of gas more times than I like to admit in my stupid Jeep but somehow I always seem to be in the right spot to safely pull out, even in southern CA. |
atomatom Samba Member
Joined: May 15, 2012 Posts: 1867 Location: in an 84 Westy or Bowen Island, BC
Posted: Fri Mar 03, 2017 11:57 pm Post subject: Re: When do I run out of fuel? |
...when the engine stops! _________________ 84 Vanagon Westy, 1.9L, California raised but defected to Canada. |
andrewvwco Samba Member
Joined: February 23, 2017 Posts: 298 Location: Estes Park colorado
Posted: Sat Mar 04, 2017 12:05 am Post subject: Re: When do I run out of fuel? |
atomatom wrote: |
...when the engine stops! |
Beat me to the punch. Yes you run out of gas when the tank is empty and the van goes a no more go-go.
You could carry a gas can just in case.
I would Fill her up and calculate roughly the millage before your next fill up. You can see you mpg and have a idea. Never trust the gauge could be way off.
Could be the gauge itself is done it's a old van look for the part.
Or could be this too the voltage stabilizer.
http://www.busdepot.com/357919803 |
Robw_z Samba Member
Posted: Sat Mar 04, 2017 12:09 am Post subject: Re: When do I run out of fuel? |
Sometimes I feel like it's good for everybody to run their van out of fuel just once. Gives you a new respect for the gauge, I listen to it when it tells me it's low now.
-Rob |
Posted: Sat Mar 04, 2017 8:01 am Post subject: Re: When do I run out of fuel? |
andrew163980 wrote: |
...carry a gas can just in case... |
I did this the first year I had the van... "Experience is the best teacher."
"The WonderVan"
MaineRich Samba Member
Posted: Sat Mar 04, 2017 8:02 am Post subject: Re: When do I run out of fuel? |
Or you can add an aux gas tank!
Disregard the PS lines, those are getting replaced in 2 weeks. |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2331 Location: Southeast Kentucky
Posted: Sat Mar 04, 2017 8:44 am Post subject: Re: When do I run out of fuel? |
My 83 Air-cool -
I purchased it in early 1985 for a trip in Alaska in 1986. To determine real world fuel capacity and what my gauge reflected, with a five gallon container of gasoline on board, I drove it until it ran out..... observing the gauge which was basically correct. As best I can remember, it actually held over 16 gallon.
Fast forward to 1993 to our 2nd trip to Alaska. We did a side excursion to Yellowknife. On the way back to the Alaska Highway the only service station between Providence, NWT and Liard was boarded up. The fuel was getting so low that I would allow the Van to coast down hill with the engine off.
.... as best I can remember, it took over 16 gallon to fill it at Liard (well over 300 miles, just under 19 mpg)
FWIW, it seems the pick-up tube on the new after market tank on my 84 is not very close to the bottom. It has allowed air to be sucked in with three gallons in the tank... not good for a diesel. EDIT >>> when going through curves on a hill, etc.... _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003.
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Sat Mar 04, 2017 8:45 am Post subject: Re: When do I run out of fuel? |
I am PARANOID about running out of gas, especially when I travel West into large expanses without many services.
I tend to travel at night sometimes and I've altered my planned path to enable me to pass through larger population areas for I know that tiny towns with a local station will most likely not be open at midnight.
I now carry two (2) one gallon jugs in my roof rack when I travel. I've never used them but the peace of mind they give me is well worth the expense/hassle/risk of carrying them.
The one gallon jugs are small and the caps fit tightly with zero leaks. I don't fill them completely and collapse them a little by squeezing them as I tighten the cap giving the tank room to expand without blowing a cap seal.
But what I do, not all would be comfortable doing.
IMHO
Whatever engineer designed these vehicles that get such "poor" fuel mileage with such a small fuel tank had his head stuck somewhere where the Sun don't shine!
Ghia
Vanagon
Beetle
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Robw_z wrote: |
-Rob |
Likewise - Dixie starts to sputter at 185 miles. _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Terry Kay Banned
Posted: Sat Mar 04, 2017 8:51 am Post subject: Re: When do I run out of fuel? |
I don't know why you would really push your luck trying to squeeze the last mile out of a tank of gas.
I just pull a low fuel economy number outa the back of my head, and try and load up between 180-200 miles.
No, I don't care much for running out of gas, running the fuel pump dry.
Not healthy for the pump, not healthy for me on the hoofmobile, and I don't carry gas in the van, or bottled propane.
200 miles is OK with me to stop for gas doing mostly in town driving.
Highway driving is a different story, you could probably squeeze 240 miles a tank load.
Whatever trips your trigger. _________________ T.K. |
