xoo00oox Samba Member
Joined: February 11, 2010 Posts: 2672 Location: East Nassau, NY
Posted: Sat Mar 04, 2017 5:35 am Post subject: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Stay tuned for more soon!
Wellington Samba Member
Joined: September 21, 2004 Posts: 1890 Location: Montreal
Posted: Sat Mar 04, 2017 7:09 am Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Awesome...as usual.
You've got this nailed, and 4 wheel drive is fabulous.
Now if you could just get that Allroad European transmission imported to get a really low range you talked about, you would monopolize the Syncro crowd.
Do you ever sleep? |
Posted: Sat Mar 04, 2017 10:10 am Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Thanks Wellington
Believe it or not, I didn't even have to remove the engine to do this. All the SAH parts are still in place. Right now I have a 012 2wd 5 speed (The transmission used in Boxsters, Passats, and 2wd Audi cars) bolted to this, the axles bolted right up.
A parts Syncro is on its way to give up its front suspension and fuel tank, the plan is to bolt up a 01A 5 speed transmission from and Audi A4 Quattro. |
Birdcage Samba Member
Joined: November 06, 2013 Posts: 203 Location: Collins of fort
Posted: Sat Mar 04, 2017 10:34 am Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Very cool,
I was wondering With the 1.8t conversions your doing. Are you going to do a air/water system opposed to the air/air?
Dai, _________________ @syncrostyle
@optoverland |
Posted: Sat Mar 04, 2017 11:10 am Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Birdcage wrote: |
Very cool,
Dai, |
I have no plans for air/ water. Things seem fine with air/air and I like the simplicity if it.
Andrew- |
Posted: Mon Mar 06, 2017 10:15 am Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Here's the line-up
from left to right.....
1. the stock Vanagon 4 speed
2. a 012 5 speed 2wd
3. a 01A 5 speed Quattro
4. a 01E 6 speed Quattro
Now that I have the engine running CCW, any one of these later transmissions will bolt up to the 1.8t and turn the wheels in the right direction.
That six speed would be interesting! |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9618 Location: Western WA
Posted: Mon Mar 06, 2017 10:29 am Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
This is a great pic, thanks. Like "the usual suspects" . Too bad you don't have an 094 for the lineup... With the 6 speed, is the spread wide enough such that a short R&P can make 1st like a granny?
This was probably asked long ago but curious how you get the turbo to spin the other way. _________________
....KTMs, GasGas, SPOT mtb |
Posted: Mon Mar 06, 2017 10:48 am Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
there are a few of these on ebay right now for $300
Manual transmission 6 Speed 01E All Wheel Drive (AWD)
Code letters GBE, FYF
Production from 04.01
to
Allocation Model A4 from 2001
Engine 3.0 liter - 162 kW
Ratio Final drive 35 : 8 = 4.375
Z2 : Z1 = i 1st gear 28 : 8 = 3.500
2nd gear 34 : 18 = 1.889
3rd gear 33 : 25 = 1.320
4th gear 30 : 29 = 1.034
5th gear 30 : 35 = 0.857
6th gear 27 : 37 = 0.730
Reverse gear 38 : 11 = 3.455
What do you think of this gearing SODO?
Just because I happen to have these laying around all over the place,
here's the line-up with a syncro transmission at far right
Posted: Mon Mar 06, 2017 10:55 am Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Sodo wrote: |
This was probably asked long ago but curious how you get the turbo to spin the other way. |
Simple, just reverse the battery teminals. |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Mon Mar 06, 2017 1:15 pm Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Just thinking evil thoughts out loud .. there wouldn't happen to be a 2WD 6-speed 01E, would there?
(aiming for fire-up/test-drive of my CCW 1.8t Bay on Friday...) |
Jon_slider Samba Member
Posted: Mon Mar 06, 2017 1:42 pm Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
xoo00oox wrote: |
Audi
Final drive 4.375
1st gear 3.500
Syncro
Final drive 4.86
1st gear 3.78
I compared those using the derek drew spreadsheet and stock tires
audi R&P is 11% taller than Syncro
audi 1st is 8% taller than Syncro
combined R&P and 1st, the Audi box is geared 20% taller than the syncro. Plus any additional tallness from larger than stock 819 rotation per mile tires.
iow, the gearing on the Audi is MUCH taller, even taller than a Subaru tranny (iirc it comes out to 6% tall after the reversed 4.86 R&P is installed)
unless Im totally confused, which of course never happens.. LOL! _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Posted: Mon Mar 06, 2017 3:14 pm Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Here are a few other options. One could play mix and match with the gears and ring/pinions but your not ever going to get it down to a granny gear level.
I think the stock 4cyl Audi transmission would be fine as long as the tires are close to stock Vanagon size. It works ok for light off road use, not for the hard core off road guys.
Tristessa. Search the 01x transmission. They do show up on eBay at times for. Dry little money. |
Posted: Mon Mar 06, 2017 3:45 pm Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
xoo00oox wrote: |
Here are a few other options. |
thanks, this is fun for me, and your comment that the tires need to be stock size makes a lot of sense.
Also that this is not relevant to a Syncro granny gear in any way. We are talking about a road car setup with tall gearing, that benefits from more than 4 forward gears.. and small tires with low ground clearance.
fwiw, the closest R&P you've listed is the 4.375 that is 11% tall
your latest list shows a 3.778 1st, that is essentially identical to a Vanagon 1st.
So with mix and match, the closest to a Van tranny would be a gearing with the audi box and stock tires that comes out 11% taller than stock overall.
this is 1-2% taller than a typical 215x75x15, or 205x70x16 BFG tire swap makes a stock tranny
and certainly a 1.8t is perfectly comfortable with ~10% taller than stock gearing.. so it comes down to Tire Size preference..
the Audi box sounds perfectly capable for a 2WD roadcar configuration.. nothing to do with a Syncro offroad
now when you get your dual range AWD setup going.. That is going to create a whole new ball game.. _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Zeitgeist 13 Samba Member
Posted: Mon Mar 06, 2017 3:56 pm Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
I doubt the rock-crawler crowd understands, but there are many many more of us who want AWD capability on pavement and dirt logging roads and not much more than that. Taller gearing really isn't a negative issue for these folks. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Mar 06, 2017 4:31 pm Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Zeitgeist 13 wrote: |
I doubt the rock-crawler crowd understands, but there are many many more of us who want AWD capability on pavement and dirt logging roads and not much more than that. Taller gearing really isn't a negative issue for these folks. |
Exactly this. There are plenty of times where you want 4wd but don't need a granny low gear.
The granny low is very cool to have, I love having it in my all stock syncro westy, but the fun you can have with a Quattro box that you can get for $200 is really great, and you get the low RPMs for the highway use. |
Posted: Mon Mar 06, 2017 4:42 pm Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
xoo00oox wrote: |
What size tires are your running on your Stinkro? _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Mon Mar 06, 2017 4:45 pm Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
xoo00oox wrote: |
the fun you can have with a Quattro box that you can get for $200 is really great |
wow!
So if Im willing to give up the rear locker, granny, and 28" tires in a Syncro, I could just bolt in an Audi box for $200?
any other costs involved?
and
What would it cost to get my stock 85 2wd westy to be AWD? (it has stock size tires) _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco |
Posted: Mon Mar 06, 2017 5:54 pm Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Christopher Schimke wrote: |
xoo00oox wrote: |
What size tires are your running on your Stinkro? |
215/75/15 |
Posted: Mon Mar 06, 2017 6:06 pm Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Jon_slider wrote: |
xoo00oox wrote: |
wow!
and
What would it cost to get my stock 85 2wd westy to be AWD? (it has stock size tires) |
John, I'm just putting out to this community that this is an option. Obviously it's not for everyone. These Audi transmissions can work in the Syncros and they're durable and inexpensive. Show me what other options we have.
Andrew- |
All4You Samba Member
Posted: Mon Mar 06, 2017 6:27 pm Post subject: Re: A new spin on a SAH 1.8t conversion, 5 speed!, Quattro!! |
Keep up the good work Andrew. Very innovative! I love how you make this an open access endeavor. Why not offer a patented reverse running engine kit? Would probably serve a lot of VW and Porsche lovers.
Btw, agree with the granny gear and locker. I use them more as insurance and peace of mind in case I just happen to get cought up in something. Otherwise 99.9% of my driving has been on pavement and highway at that - hands down the weak point of my syncro. _________________ 86' Syncro, EJ25
Build Thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=647477&postdays=0&postorder=asc&start=0 |
