andre b Samba Member
Joined: August 10, 2004 Posts: 806 Location: San Jose C.A.
Posted: Fri Apr 21, 2017 6:23 am Post subject: Re: 1960 Postal Yellow Double cab find |
ronjonlasvegas wrote: |
62DoKaGuy wrote: |
That tailgate before picture tells the tale (see what I did there) of how I feel when people draft behind me in my double cab...
The effort you're putting into uncovering the layers is admirable - you are patient! |
Thanks. I decided the logos on the gates will be eliminated, it will be too hard to keep them as they are not on the original paint. They are on the 4th repaint color. They will be saved in photos on this site.
Before
Afternice,,looks like the wheel wels are later style with the lip!
ronjonlasvegas Samba Member
Joined: October 08, 2004 Posts: 900 Location: Las Vegas, NV
Posted: Fri Apr 21, 2017 6:44 am Post subject: Re: 1960 Postal Yellow Double cab find |
Quote: |
After nice,,looks like the wheel wells are later style with the lip! |
Yes, the wheel wells are wrong. They were cut out at sometime and replaced later in life, but with the wrong 63-67 later style. They will be cut out again and replaced with the correct no lip sections. I need to get some paint mixed up so I can blend in that area. The tail light were also cut to the later 62-67 style and will also have replacement metal welded in place. _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Posted: Fri Apr 21, 2017 6:47 am Post subject: Re: 1960 Postal Yellow Double cab find |
Yes, the wheel wells are wrong. They were cut out at sometime and replaced later in life, but with the wrong 63-67 later style. They will be cut out again and replaced with the correct no lip sections. I need to get some paint mixed up so I can blend in that area. The tail light were also cut to the later 62-67 style and will also have replacement metal welded in place. |
right on..good luck..cool truck for sure! |
Cuñado Wear Samba Member
Joined: December 10, 2006 Posts: 1142 Location: The "O"
Posted: Fri Apr 21, 2017 9:42 am Post subject: Re: 1960 Postal Yellow Double cab find |
Bulli Klinik wrote: |
I may be a little late to the party, but what the hell is Cunado Wear? |
Looking for front kick panels for late 63' Deluxe Basalt Gray
60' Double Cab
63' 15 Window Deluxe |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Sun Apr 23, 2017 5:05 pm Post subject: Re: 1960 Postal Yellow Double cab find |
Very impressed. This bus went to the right person _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
Posted: Sat May 06, 2017 6:21 am Post subject: Re: 1960 Postal Yellow Double cab find |
For those of you following along here are a few more progress photos. The rear gate turned out pretty good
Before
After
The front nose section is not completely stripped yet, but it is not looking good. That section has a lot of bondo and was sanded down to bare metal before the bondo was applied. I started on the passenger side lower rear quarter and that area was also sanded down to bare metal and skimmed with bondo.
Nose about midway (crazy paint).
As it looks today.
The front nose top layer and roof had crazy pink flames, here are a couple before shots.
I am not sure what to do at this time. I was hoping that more original paint remained under all the layers. _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
VWDC62 Samba Member
Posted: Sat May 06, 2017 3:37 pm Post subject: Re: 1960 Postal Yellow Double cab find |
I love this thread. Can someone decode the Mcode plate for me? So what would this truck have been used for originally? Post, utilities? I've seen a single cab yellow but not a double. _________________ Rob
1967 13 Window Bus🚫
1969 Beetle🚫
1962 Double Cab✅ |
Posted: Sat May 06, 2017 4:43 pm Post subject: Re: 1960 Postal Yellow Double cab find |
VWDC62 wrote: |
I love this thread. Can someone decode the Mcode plate for me? So what would this truck have been used for originally? Post, utilities? I've seen a single cab yellow but not a double. |
Hi Rob,
Thanks for the interest. I really have no way to tell what it was originally used for. The truck was special ordered by someone, it could have been a business or an individual. The m code plate says it was originally delivered to Portland, OR. It wound up in Las Vegas, NV and has been here for at least 20 years based on my research. It does not mean it was necessary used by the Post Office because it was Postal yellow. That was just a special order color and was not listed on the brochures at the time as a standard color. There are other examples of Postal Yellow on non-commercial buses. One is a 23 window bus that was special ordered in this color. It is pretty rare, but not unheard of. Most of the Postal yellow buses are single cabs and panels. I do know of one other double cab bus in Northern CA that is postal yellow, but that is all I have found so far.
Here is the decipher from the M code website.
Model Type 2 (T1) mod. 265 :
- Double-cabin pick-up
- Passenger door right
- LHD
Chassis number 518204
Serial number 26518204
Modelyear 1960
Planned production date October 02 ,1959
Paint color ??? - Postal Yellow
Interior color (doorpanels and seats) *** Unknown ***
Destination USA, Portland
017 Rear brake and taillights combined -
176 Overriders all models Pick-up and Double Cab
181 Chrome hubcaps -
207 Tarp and bows Double Cab
361 Collection of M-Codes: M 168/181/192/199 -
168 88 ampere/hour battery (6V) -
192 Body ready to be outfitted as a camper -
199 Seat belt mounting points -
199 Swivel driver's seat Panel Van, Camper, Kombi. Also used on Flipseat Westfalia campers
544 "Kundendienstwerkstatt", (i.e. "service room", special place for conversions made by Volkswagen itself). - _________________ September 1964 Standard Sunroof walk through SWR/BG original paint. |
Posted: Sun May 28, 2017 1:24 pm Post subject: Re: 1960 Postal Yellow Double cab find |
I had some free time this weekend so I went back at it stripping the paint off. I was able to finish the back of the cab area and the driver side gate.
Before
During
After
western auto Samba Member
Posted: Sun May 28, 2017 3:46 pm Post subject: Re: 1960 Postal Yellow Double cab find |
with the amount of og paint gone I think id just throw in the towel and restore it |
Posted: Sun May 28, 2017 4:33 pm Post subject: Re: 1960 Postal Yellow Double cab find |
western auto wrote: |
Eventually it will get restored, but for now I just want to finish stripping the paint down to original and get it together and driving. I kind of like the character of a well used truck like this one owned by Earl.
I have had a perfectly restored car and when it was done it was so nice I was hesitant to drive it.
Malokin Martin Samba Member
Posted: Sun May 28, 2017 6:22 pm Post subject: Re: 1960 Postal Yellow Double cab find |
I have had a perfectly restored car and when it was done it was so nice I was hesitant to drive it. ] |
This ^. Trucks (especially) are so much more useful without perfect paint. That way you're not stressing every time you throw a bicycle back there. It's a different beast than a kombi. Plus I kind of feel it's not that bad. Have you looked into blending the really big spaces? Looking back... I sometimes wish I had gone this route.
Random bit of advice: go with the rivets (rather than the screws) for the wood slats. |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Sun May 28, 2017 6:41 pm Post subject: Re: 1960 Postal Yellow Double cab find |
I'm on this boat. Save my dough for practical things, not pretty paint that's door dinged at a show, scratched by branches Christmas tree shopping, or scratched up loading up stone or rock.
It's a truck, use it. It's already awesome, practical in its own right, keep it alive not on life support (garage kept all but three days a year). _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Tue May 30, 2017 5:23 pm Post subject: Re: 1960 Postal Yellow Double cab find |
Malokin Martin wrote: |
Thanks for the positive comment. I am going to try to have some paint mixed up and blend the really bad spots. We will see how it turns out as I have never done anything like that before.
I had a little more time this weekend and stripped the grey paint off the dash and parcel tray, it came out pretty good. The parcel tray has some rust and someone spilled something sticky on it. I need to bust out the heat gun and try to heat it and scrape it off.
**Does anyone have a postal yellow ashtray in their stash? My truck was missing the ashtray**
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Tue May 30, 2017 5:35 pm Post subject: Re: 1960 Postal Yellow Double cab find |
Great job on the paint stripping! I've stripped parts of a couple of buses but not an entire bus (yet).
An og paint Postal Yellow ash tray is probably hard to come by. Place a WTB ad in the classifieds here, you never know. Someone may have one in their stash. _________________ Brandon |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Tue May 30, 2017 5:57 pm Post subject: Re: 1960 Postal Yellow Double cab find |
Wow, that dash turned out awesome. That is the most important area to have look nice.
Nice work. |
Posted: Tue May 30, 2017 6:48 pm Post subject: Re: 1960 Postal Yellow Double cab find |
X2 _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Tue May 30, 2017 7:13 pm Post subject: Re: 1960 Postal Yellow Double cab find |
campingbox wrote: |
Nice work. |
that's right, this is what YOU see when you drive. Get a nice set of interior panels, and clean up the fresh air box, done on the inside _________________ regards
Uli
Posted: Tue May 30, 2017 9:49 pm Post subject: Re: 1960 Postal Yellow Double cab find |
dash looks awesome! |
