Torpedo Samba Member
Joined: March 05, 2017 Posts: 4 Location: El Cajon, CA
Posted: Mon Mar 06, 2017 3:49 am Post subject: 71 Super beetle not starting |
Hey guys, new user here and also 1st time bug owner.
I had recently purchased a 71 super beetle that has been running absolutely great up until the last couple days. The PO did not have a radio installed so naturally I went to get one out in by a car audio place around the corner from my house. The first couple days were fine and had absolutely no issues. The other day on my way home from work the radio shut off and the generator light on the dash started blinking and the car just died. I tried to restart it and I turned the key and none of the lights on the dash turned on. No generator or oil light or anything. Now mind you the car was running great before I got the radio in and I think bad wiring is the issue and there's a short somewhere. When I try and start it now I get absolutely nothing. No dash lights when the key is in the on position, not even a click from the starter. I checked the batter and it's fully charged. So I'm at a loss rightnow. Any help would be greatly appreciated. |
DeathTrap Samba Member
Joined: February 26, 2004 Posts: 1757 Location: Sacramento/Vermont
Posted: Mon Mar 06, 2017 4:24 am Post subject: Re: 71 Super beetle not starting |
How did you check the batter?
just take your test light or electric meter and trace from batter back to and through ignition switch to ignition coil and starter motor (both source and trigger)
there are schematics available on this site. |
Posted: Mon Mar 06, 2017 5:56 am Post subject: Re: 71 Super beetle not starting |
Checked it with a multimeter, read 12v exactly. Also forgot to mention that my head lights, brake lights etc. All work fine. Not sure if that helps |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Mon Mar 06, 2017 7:01 am Post subject: Re: 71 Super beetle not starting |
12v exactly = dead battery.
Needs to be 12.6v to be fully charged. That would be at rest with no electrical load. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Mon Mar 06, 2017 7:08 am Post subject: Re: 71 Super beetle not starting |
Hmm. I'll go ahead and charge it up and see what's happens. Will report back. Thanks guys |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Mon Mar 06, 2017 8:29 am Post subject: Re: 71 Super beetle not starting |
Torpedo wrote: |
I tried to restart it and I turned the key and none of the lights on the dash turned on. When I try and start it now I get absolutely nothing. No dash lights when the key is in the on position... Any help would be greatly appreciated. |
Torpedo wrote: |
These statements are the clues to me. If the headlights work, then there's plenty of battery power for the dash lights to work if all was OK.
I think the electrical part of the ignition switch needs to be tested, to make sure that there's voltage getting to it (red wire), and that voltage is coming out of it when the key is switched to run (black wire) and to start positions (red wire with black stripe). The wiring diagrams are in the Tech Section here. At this point I'm suspecting a bad electrical part of the ignition switch.
_________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297
rockerarm Samba Member
Joined: December 16, 2009 Posts: 3552 Location: Los Angeles
Posted: Mon Mar 06, 2017 8:35 am Post subject: Re: 71 Super beetle not starting |
Hi. WELCOME.
A fully charged up battery is 12.5v to 12.6v. The parts stores (O'reilly and AutoZone) will charge it up and load test it for you. If they say it is bad don't buy a $125 battery just yet. Reasoning is you may have some other issues with the car's electrical.
A couple of basic checks you can do visually are the red wires that are hot, 12v, all the time, circuit term #30. Follow from the battery pos post to the voltage regulator (left side under rear seat) and verify a solid connection there. Do you know if this car has been fitted with an alternator? As the oem regulator may still be there or some hack job wiring could exist. Once this checks out, verify the battery ground is secure on the battery and its mounting spot.
At this point you will probably need to access a wiring schematic from technical link at the top right of the page here, unless you have a Bentley manual with the color wiring schematic.
Now, under the front hood you. You should look for the thick red wire as it connects to the fuse box and see if you have 12v there. If you don't have any electrical items that work you will need to study the colored wiring and see where the wiring goes from this point dependent on what works and what doesn't work.
A tip here is to have the battery negative cable on a bit loose. Reasoning is if the radio installer possibly knocked off a wire somewhere and you poking around creates a short to ground on a non-fussed circuit like the red term #30 it will burn til you can interrupt the short. You gonna have to look around the fuse box area and above/below the radio location.
If this doesn't find your fault you will have to see if you are getting 12v towards the ign switch and 12v out on the black #15 wire and the yellow/black X wire, if equipped.
Hope this helps, Bill. |
Posted: Mon Mar 06, 2017 9:27 am Post subject: Re: 71 Super beetle not starting |
Well I swapped the battery for one I know for sure is charged up and still the same problem. Ill go ahead and look around the fuse box again to see if I can spot anything and see if the ignition is getting power. And I do still have a generator not an alternator. Thanks for the replies guys I really appreciate the help. |
awreed Samba Member
Joined: January 14, 2010 Posts: 1268 Location: Kirkland, WA
Posted: Mon Mar 06, 2017 9:31 am Post subject: Re: 71 Super beetle not starting |
x2 on what Cusser said- I'm gonna guess the electrical part of the ignition switch.
I've also had a broken spade connection at the fuse box where it was still touching and making a connection, but would occasionally move while driving, and kill the engine periodically. That one freaked me out, but was easily diagnosed and fixed. |
sb001 Samba Member
Posted: Mon Mar 06, 2017 9:39 am Post subject: Re: 71 Super beetle not starting |
Torpedo wrote: |
You say when you turn the key there are no dash lights and your starter doesn't even try to turn over, correct?
I think you might have an issue in line BEFORE your ignition switch, but to be sure, please double check EXACTLY what lights are you getting right now. You said you are getting headlights and brake lights--but are you SURE you are not just getting PARKING LIGHTS and TAILLIGHTS? Please double check on this and report back--thanks _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Starbucket Samba Member
Posted: Mon Mar 06, 2017 9:55 am Post subject: Re: 71 Super beetle not starting |
Gently give each wire (both sides of the fuses) to see if one is not connected. Also spin each fuse to make sure it's making good contact and look closely at each fuse especially the one going to your new radio to make sure its not blown. Does the radio work? |
jovanybg Samba Member
Joined: January 02, 2016 Posts: 150 Location: Houston, TX
Posted: Mon Aug 14, 2017 9:57 pm Post subject: Re: 71 Super beetle not starting |
As mentioned above, have a good look at the fuses. I've had a lot of oxidation between the fuses and the contacts, resulting on starting problems!
A good clean-up and lightly covering with dielectric grease solved the issue! _________________ 1971 Karmann Ghia Autostick
Solex 34 Pict 3
DVDA Bosch 113 905 205 AH distributor |
