driftman11 Samba Member
Joined: August 01, 2012 Posts: 141 Location: little rock,ar
Posted: Mon Mar 06, 2017 10:24 am Post subject: Loose crank pulley bolt cause damage???? |
Ok so I received my engine back from the rebuilder and installed it. did a few test runs prob. running 2-3 minutes at a time, total of no more than 15 minutes of run time. afterwards I noticed the crank pulley bolt was only hand tight, I could literally take it off with my hand. Will this cause any issues with internals of motor or any issues at all I need to be concerned with? I'm wondering if I need to go back to my rebuilder on the issue or if I can torque it and move on with my life. ????? |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1184 Location: Richmond, Va
Posted: Thu Mar 09, 2017 11:20 am Post subject: Re: Loose crank pulley bolt cause damage???? |
hey driftman11,
I'd think as long as it didn't sling the bolt and the pulley you should be fine.
Those crank pullys are pressed on/or heated and put on so they fit tight.
usually you need a crank pully tool to remove.
So you should be ok, if the nut was hand tight, it shouldn't have given it much room to move even if it did.
I'd tourqe it down and test it out.
Anyone else any suggestions for driftman11 here?
Hope all is well with it,
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
Posted: Thu Mar 09, 2017 2:54 pm Post subject: Re: Loose crank pulley bolt cause damage???? |
Thank you for taking the time to reply. This is exactly what I was hoping and it wouldn't hurt my bearings or any internal seals or anything. I'm really not too familiar with how the engine goes together internally.
Again Thanks! |
ldj1002 Samba Member
Posted: Wed Mar 15, 2017 7:46 am Post subject: Re: Loose crank pulley bolt cause damage???? |
driftman11 wrote: |
Again Thanks! |
I would worry about what else he didn't do right. I would go have a talk with him. |
Keith Samba Member
Joined: August 15, 2005 Posts: 3635 Location: Brodheadsville, PA
Posted: Fri Mar 17, 2017 11:01 pm Post subject: Re: Loose crank pulley bolt cause damage???? |
ldj1002 wrote: |
driftman11 wrote: |
Again Thanks! |
Willing to bet he left it loose so that it was easy to remove the pulley to put the engine tin in that goes behind the pulley and bolts to the case. _________________ Formerly known in the forums as "OVALTEEN"
"I firmly believe that some villagers from Botswana could probably build a better road than PennDot."- Splitty
"If you do anything to your car someone will hate on you for it. People absolutely love to complain and find fault with others. Don't let it bother you. Just live and have fun."- Lind |
