krowe4 Samba Member
Joined: September 12, 2016 Posts: 5 Location: Seattle
Posted: Mon Mar 06, 2017 1:10 pm Post subject: Eurovan winter camping issues |
Hello,
I'm the new owner of a 2000 Eurovan Camper. The last two weekends I've taken it to ski resorts in WA to get a couple days of skiing in without paying for lodging (one of the primary reasons we bought the van!) and have had a few issues that I'm curious if the Samba community can help me out with. For what it's worth, the temps have been around 15-25 at night, and getting close to 32 F during the day; and the parking lot is at about 4200 ft. Here's the issues that have come up, I'm interested in any solutions/ideas/preventative measures you all have for them:
1. Both weekends the water pump has frozen
2. Both weekends the drain in the sink has frozen
3. Just this weekend the sliding door froze
4. Both weekends the furnace wouldn't blow hot air, despite it working before and after when in warmer temps
Thanks in advance for the advice!!
Best,
Kyle |
Scottn59c Samba Member
Joined: December 22, 2016 Posts: 308 Location: Northern CA
sdunn35 Samba Member
Joined: September 05, 2008 Posts: 38 Location: Concord, CA
Posted: Mon Mar 06, 2017 3:15 pm Post subject: Re: Eurovan winter camping issues |
The furnace problem also manifested in my 2000 EVC the one time I overnighted in sub-freezing weather. It *may* be lack of vapor pressure in the line when the tank gets really cold, or something similar, but have never had an opportunity to troubleshoot.
IMHO the EVC as-built is a 3-season camper. I think some mods are indicated if you will regularly camp in truly cold weather _________________ 99 EVC
ex-03 Weekender |
DenverB Samba Member
Joined: July 23, 2012 Posts: 704 Location: Denver, Colorado
Posted: Mon Mar 06, 2017 8:32 pm Post subject: Re: Eurovan winter camping issues |
see below _________________ -------
'77 Transporter/camper (Bussy - Reef Blue/Pastel White)
'67 bug (Santos - VW Blue)
'84 Vanagon Westfalia (Pink Flamingo - Pastel White/Pink)
'88 Vanagon GL Westfalia (Frankie Says - Wolfram Gray)
'02 Eurovan Weekender (Green Apple)
'95-'03 Eurovan full campers and weekenders (rental fleet)
'84 -'91 Vanagon full campers and weekenders (rental fleet)
'72 Porsche 914 (Greta - RIP)
www.RockyMountainCampervans.com
Posted: Mon Mar 06, 2017 8:35 pm Post subject: Re: Eurovan winter camping issues |
congrats, you just bought the best ski chalet ever. I love ski camping in the EVC.
on to your issues: the water system should be drained in the winter - it is not designed to function in freezing weather. Water expands when it freezes and can cause some major damage to your pump, water lines and plastic fittings -- many of which are hidden in the recesses of your van. the pump itself is mounted basically to a steel support beam at the rocker panel (in a really cold spot).
You won't notice the leaks until it's too late and the subfloor of your van becomes mushy and wet. If you keep the inside of the van warm, you can *cautiously* use the gray water -- but even then just dump water outside.
trust me, next time it's warm enough and your van isn't frozen: dump your fresh and gray water tanks. I'm re-doing a rotten subfloor right now and while I enjoy the work, it's a major pain in the ass to do. Four hours plus just to remove the thing.
Your furnace could be facing a few problems. It's not altitude or extreme cold, as my furnaces work fine here up to ~9000 feet and well below zero.
it sounds likely that there's water in your tank and your regulator is freezing up. Find a propane service shop and have them inject methanol into your tank. The owner's manual for the Winnebago talks about the process and why the regulator freezes up. This doesn't happen much out here in Colorado with our dry air, but a few times this winter we've had some wet storms and I had two renters experience the same thing in the same night in different vans in Telluride because of this. Where you live, I can imagine this could be a more constant issue.
also: try replacing your thermostat (http://www.thesamba.com/vw/forum/viewtopic.php?t=613043&highlight=)
Finally, check your aux battery. if the charge gets too low your fan will still run, but the failsafe for the propane will go and you won't ever get it lit. This *almost* sounds like your problem, except for the part about how your heater will work in warmer temps.
Regardless: if the battery came with the van, probably time you get a new one. you can step up to a size 31 DC marine battery from the 27dc it likely has in there, that should help.
If those don't help, it may also be time for you to service the heater itself (or have it serviced). They are relatively easy to pull out (I'll have a write up on it in a few days here) and commonly the exhaust/intake vents are clogged up with things like hornets nests, etc. it's worth checking out.
I agree that as a camper, they need some tweaking to be a four-season rig, but with a little prep they work great even in zero degree temps.
Just a few things like pulling panels and insulate behind them (ever notice how cold your closet gets?), getting a quilted liner for the tent top, putting insulated covers on the front three windows and wearing a pear of sweatpants goes a long way though. _________________ -------
www.RockyMountainCampervans.com |
krowe4 Samba Member
Posted: Tue Mar 07, 2017 11:32 am Post subject: Re: Eurovan winter camping issues |
Hey DenverB,
Thanks a bunch! I appreciate the advice. You're right in that our winters are much wetter than Colorado's, so maybe that's the issue.
The battery hasn't reached anywhere near low the last couple weekends so I don't think that is the issue. I think I'll start by having some methanol injected into the tank and see if that fixes the issue.
Thanks for the other tips... I like the idea of insulating the van a little better to make the best use of the heat we have.
Best,
Kyle |
Richardginns Samba Member
Posted: Thu Aug 01, 2019 6:43 pm Post subject: Re: Eurovan winter camping issues |
Regarding the heater issue, A full tank or near full of propane really helps in cold weather with "that heater", Well worth doing, |
1961tbird Samba Member
Joined: July 21, 2018 Posts: 291 Location: Halifax, Nova Scotia
Posted: Fri Aug 02, 2019 6:17 am Post subject: Re: Eurovan winter camping issues |
BTW - Fancher's in Michigan makes a nice insulated tent insert. |
MrPulldown Samba Member
Joined: September 08, 2020 Posts: 649 Location: Truckee
Posted: Fri Feb 26, 2021 11:28 am Post subject: Re: Eurovan winter camping issues |
The fresh water tank and the pump are both located inside the cabin correct? If I am driving in freezing temps, and the cab is warm, I would not be risking the fresh water system freezing.
I have all my water currently drained as the van sit in freezing temps regularly.
I store gallon water jugs in the fridge (turned off) and it works great as an insulation box to keep them from freezing. I do not use the gray tank, but if I needed too I have a bottle of RV anti freeze that I would pour in. A trick my RV'ing father-in-law taught me.
I am taking off for the coast soon and would like to have a tank of fresh mountain water. MY plan is to fill it right before I leave and to drive straight there. However I will be traveling for many hours in low temp mt regions.
Prior to my return I will drain the tanks. Does anyone see a problem with my plan. _________________ 2002 EVC |
Blaque Jacques Samba Member
Posted: Sat Feb 27, 2021 8:38 pm Post subject: Re: Eurovan winter camping issues |
yes the tank is in the left rear under the closet and the pump is behind the cabinet under the sink. As long as you have the heat on while driving I think that you should be fine! _________________ 86 2wd Westy GW2200. 97, 99 02 EVC. Lots and lots of bikes |
Posted: Sun Feb 28, 2021 8:13 pm Post subject: Re: Eurovan winter camping issues |
Blaque Jacques wrote: |
yes the tank is in the left rear under the closet and the pump is behind the cabinet under the sink. As long as you have the heat on while driving I think that you should be fine! |
Yep, turned out to be fine. Was about 20 degrees when I filled the tank 1/3 the way full. Then drove for about an hour in the sub freezing temp. Did not seem to have any issue.
How when I went to cook lunch, no water came out the faucet. Remembered that I have left the drain nozzle in the open position. I did not want to do this, guess I forgot. Anyways after boiling and cooking my ramen, I filled my clear water bottle up. I noticed floating flakes. Poured it out and filled again with the same. Uhgg. Did I get some algae growth in my tank. Was this due to having the drain valve opened. Figure I need to do some rinses and soak with some chlorine. ANy tips on this.
In other news the EVC did great on the 8 hour trip I just made. Purred like a kitten rolling down the highway turning 4K RPM. _________________ 2002 EVC |
