shorepig Samba Member
Joined: November 30, 2005 Posts: 516 Location: Vancouver, B.C.
Posted: Tue Mar 07, 2017 6:05 pm Post subject: Rebuilt auto tranny lurches forward in cold start-ups |
I have a new (rebuilt) auto tranny, torque convertor, diff, and LSD in my 85 westy mated to a 2.3 GW motor. The motor has 100,000 km on it but the rest was installed recently. Also had new drive shafts and cv's installed recently.
PROBLEM:
If the van is cold when started it lurches forward when the engine starts. Not much, but there is a noticable forward motion of a few inches. This only happens on occassion (about 1 in every ten start ups). It has never done this when the van has started when it was warm.
As well, when the van is decellerating and slowing down gradually (imagine coasting to a stop) the downshifts seem a bit harsh (not a smooth shift but rather harsh). When accellerating slowly, the van also has a rough shift when shifting into a higher gear. These shifting issues are intermittent and only occur on slow shifts or when the van is accellerating or decellerating gently. Also, if I tap the gas pedal abruptly there is a definite clunk sound/feeling. BTW engine mounts were replaced recently.
Westfalia gurus, what could be causing this? Is something out of adjustment? Someone else mentioned an issue referred to as "drain back issue" but didn't elaborate. Any insight would be great! cheers! _________________ 85 Westy
92 Mitsubishi Mighty Max 4x4 V6
74 Honda CB500T cafe racer
2013 ktm 690r
Sector nine pintail |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Wed Mar 08, 2017 6:17 am Post subject: Re: Rebuilt auto tranny lurches forward in cold start ups |
Hello, are you saying that when you start the van, it lurches forward in park or when you select drive? _________________ ☮️ |
Posted: Wed Mar 08, 2017 8:17 am Post subject: Re: Rebuilt auto tranny lurches forward in cold start ups |
MarkWard,
It lurches forward when I start the van in park. _________________ 85 Westy
2013 ktm 690r
Terry Kay Banned
Posted: Wed Mar 08, 2017 8:40 am Post subject: Re: Rebuilt auto tranny lurches forward in cold start ups |
If this is do, there is something amiss with the park pawl, along with some more items from your description.
Better get it repaired pretty quick. _________________ T.K. |
Posted: Wed Mar 08, 2017 8:46 am Post subject: Re: Rebuilt auto tranny lurches forward in cold start ups |
Thanks TK
Another thing I've noticed but figured wasn't an issue is shifting between gears is more difficult. It takes more arm strength to shift the selector. Bit of a clunk too when shifting between park, drive, and reverse. This clunking is typical though correct? _________________ 85 Westy
2013 ktm 690r
pablum Samba Member
Posted: Wed Mar 08, 2017 9:01 am Post subject: Re: Rebuilt auto tranny lurches forward in cold start ups |
Yeah the pawl or the dentitions it falls into. Have you been throwing it into park while the van is still moving? Or maybe you did what I tried and ran through the gears while the axles were removed with the motor running? Don't put it back in park if you try that. _________________ The wise man learns from history, the fool from experience.
I see [a cat] in the street and i aim for the pest with my car. -- bluebus86 |
Terry Kay Banned
Posted: Wed Mar 08, 2017 9:25 am Post subject: Re: Rebuilt auto tranny lurches forward in cold start-ups |
Get it back to the trans shop asap.
Let them figure it out. _________________ T.K. |
Pablum,
No. I stop before putting the van in park someone else did the install so I'm not sure if they ran through the gears without the axles installed. _________________ 85 Westy
2013 ktm 690r
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Wed Mar 08, 2017 11:42 am Post subject: Re: Rebuilt auto tranny lurches forward in cold start ups |
shorepig wrote: |
MarkWard,
It lurches forward when I start the van in park. |
There is a lot of slop by design in the parking pawl. I do not think that is your problem.
The problem is your forward clutch pack is not released. In park or neutral it should not be engaged. If it is..then the transmission is trying to move forward hard, in park.
As an experiment..try starting in neutral and see if the transmission is moving the Vanagon forward like it was in gear?
Some slight drag in the forward clutch is normal...just slight though...but not like you are describing. |
Posted: Wed Mar 08, 2017 6:57 pm Post subject: Re: Rebuilt auto tranny lurches forward in cold start-ups |
I should add..if your idle speed is too high..the transmission will behave the same way too. Idle speed should be less the 1000 rpms |
Terry Kay Banned
Posted: Wed Mar 08, 2017 7:10 pm Post subject: Re: Rebuilt auto tranny lurches forward in cold start-ups |
I have been thinking the same on this phenomenon.
What actually is a lurch?
If the idle is cranked up too high, I would be more prone to describe it as a "Bang" _________________ T.K. |
amwaj Samba Member
Joined: February 18, 2017 Posts: 68 Location: the desert
Posted: Wed Mar 08, 2017 11:30 pm Post subject: Re: Rebuilt auto tranny lurches forward in cold start-ups |
he said it lurches forward when in park
could that be idle speed? _________________ the best way to make a small fortune in life, is to start with a big one, and become afflicted with Vanagon-itis |
Terry Kay Banned
Posted: Thu Mar 09, 2017 7:50 am Post subject: Re: Rebuilt auto tranny lurches forward in cold start-ups |
As mentioned the idle should be under 1000 rpm.
850-900 would be good.
What is your van idling at? _________________ T.K. |
