Torsion bar
ldj1002
ldj1002 is offline
PostPosted: Wed Mar 08, 2017 6:03 pm    Post subject: Torsion bar Reply with quote
Where the bar comes through the plate it looks off center, see image at about 10 o'clock position compared to 4 o'clock. Would that be where squeaking comes from?
Is the bushing wore out?
74 Thing
74 Thing is offline
PostPosted: Wed Mar 08, 2017 8:57 pm    Post subject: Re: Torsion bar Reply with quote
Yes, there are two bushings on either side that you need to replace. Search for rear spring plate bushing replacement steps or something along those lines to see what is involved. Prob some vids on the internet as well.
http://www.vw-resource.com/rearaxle.html
citroen
citroen is offline
PostPosted: Thu Mar 09, 2017 4:53 pm    Post subject: Re: Torsion bar Reply with quote
When you remove the cap with that much wear you will also need to replace the cap it more than likely worn out also check for a lot of rust in the cap.
helowrench
helowrench is offline
PostPosted: Sat Mar 11, 2017 9:25 am    Post subject: Re: Torsion bar Reply with quote
You can also transpose the caps side to side if they have minor/medium wear.
Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser
helowrench
PostPosted: Sat Mar 11, 2017 9:31 am    Post subject: Re: Torsion bar Reply with quote
ldj1002,
Yes,
It is time for trailing arm bushings.
If I am going that far in, I change the diagonal arm bushing, rear soft brake lines, clean/inspect the rear bearings, clean/inspect rear brakes, and clean/inspect the cv joints.
None of these are expensive, or very complicated, and once you are done, its good for a long time.
I would recommend buying/borrowing a Torque Tool for the rear axle nut.
It makes the process much easier to get the drum off.
Current VWs:
73 914 1.7
ldj1002
ldj1002 is offline
PostPosted: Sat Mar 11, 2017 10:35 am    Post subject: Re: Torsion bar Reply with quote
helowrench wrote:
ldj1002,
Yes,
Thanks very much. I have already done the brakes when bringing it back to life. However from what I have read I don't want to tackle the bushings. Hoping to locate someone in Waco that can and will do it for me.
74 Thing
74 Thing is offline
PostPosted: Sat Mar 11, 2017 10:47 am    Post subject: Re: Torsion bar Reply with quote
Since you are re doing the whole rear end replace the body to suspension pads as well if needed...
http://www.thesamba.com/vw/forum/viewtopic.php?t=672129
