jrp916 Samba Member
Joined: November 29, 2010 Posts: 23 Location: Sacramento, California
Posted: Thu Mar 09, 2017 10:28 am Post subject: what tires are people using for 4" rims |
Hello all,
I have 4" front rims for my off-road buggy and I see a lot of off-road rims in 4". What tires are people using? The only option I see for dirt is the Mickey thompson mini mag. Is there anything else available?
mickey thompson tire- https://www.summitracing.com/parts/mtt-2551/overview/
I feel like I've seen 215 mud-terrains on 4" wheels? |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5415 Location: Holland, MI
Posted: Thu Mar 09, 2017 11:08 am Post subject: Re: what tires are people using for 4" rims |
Pretty much any 7.00x15 also works...29-30 inches tall and only slightly wider than the mini mags. Most are pretty tough, but a bit on the heavy side for how big they are. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
jrp916 Samba Member
Brian Samba Moderator
Posted: Thu Mar 09, 2017 5:00 pm Post subject: Re: what tires are people using for 4" rims |
I have the BFG KO2 on 215/75-15 on stock 4J rims. The BFG mud tires aren't too different so you'd be fine I'd say. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
jrp916 Samba Member
Posted: Fri Mar 10, 2017 9:47 am Post subject: Re: what tires are people using for 4" rims |
Brian wrote: |
I have the BFG KO2 on 215/75-15 on stock 4J rims. The BFG mud tires aren't too different so you'd be fine I'd say. |
Thanks! How long have you been running them? I like this look, I think that's what this buggy has below. Tire calls for a 5.5" rim, but I think for off-road only where your not putting alot of lateral side wall stress (no hard cornering) on the tire it'd be fine.
Looking at the charts more, I've been running a 31x10.5 ko2 on a 6" wheel for along time and its suppose to have a 7" wheel. I have had dirt get in the bead a couple times and the tire going flat, but I think thats just part of being off-road. |
dustymojave Samba Member
Posted: Sat Mar 11, 2017 9:56 pm Post subject: Re: what tires are people using for 4" rims |
My Baja has 7.00-15s on Centerline 15 x 3.5" wheels. Works fine. A great many Bajas have a similar setup. So do most 5-1600 race Baja Bugs.
Most white spoke wheels used for fronts are 5" wide. That's what you see on the front of my Hi Jumper race car in my avatar.
And if you think offroading doesn't put a lot of side loads on a tire, you haven't been up close to a desert offroad race. Even playing can strain them pretty hard too. Driving on the street is NOTHING in comparison.
Look at this Baja I've raced in.
Or this one.
Both of those have 7.00-15s on 3.5" wide Centerlines. _________________ Richard
SoCalBajas Member
jrp916 Samba Member
Posted: Mon Mar 13, 2017 2:07 pm Post subject: Re: what tires are people using for 4" rims |
Thanks! Any recommendations on where to buy those tires? The ones I've seen so far look like they are more like for a jeep (tread patterns). |
Posted: Mon Mar 13, 2017 2:20 pm Post subject: Re: what tires are people using for 4" rims |
Many VW supply shops sell 7.00-15s. Most tire shops can get them. All Terrain or Mud Terrain tires of many brands in sizes from 215-75 x 15 to 235-75 x 15 will also work.
The tires can be 'P' - passenger series, or LT - light truck in load range B or C. The ones you see on the front of my Baja are Yokohama. The ones on my buggy are Cooper. LOTS of brands will work well. There are a huge number of options for you. _________________ Richard
SoCalBajas Member
mr_bill Samba Member
Joined: February 19, 2006 Posts: 1008 Location: City of Orange, CA
Posted: Sun Mar 19, 2017 2:06 pm Post subject: Re: what tires are people using for 4" rims |
215/75R-15 BFG's on 4.5.....stock "VW" Marathon wheels....just say'n _________________ see ya' on the trail........
"Mr Bill"
Dos Perros Motorsports
Orange, CA
1972 Class 11x/Stock Bug
'60's era "vintage" Tunnell-Buggy
"...no one here....get's out ALIVE...."
Motor = electric
Engine = internal combustion
www.facebook.com/groups/DosPerrosMotorsports
www.alrchapter132.org
www.DAV.org |
Posted: Sun Mar 19, 2017 6:50 pm Post subject: Re: what tires are people using for 4" rims |
Bill has a great setup there. In fact my plan for the next pair of tires for the front of my Baja is 215-75 all terrains. Which ones I choose depends on what tires are available at good deals when the time comes. My tire brand choice is not cast in stone. _________________ Richard
SoCalBajas Member
jrp916 Samba Member
Posted: Mon Mar 20, 2017 4:26 pm Post subject: Re: what tires are people using for 4" rims |
Thanks guys. I have decided to go with a 30" x 9.5" front tire for my rail. I can either go with a 4" or 7" btr front rim. The 4" rim will make a little more narrow tire which will make it easier to turn and also help narrow my front width (which is almost wider than the rear). I think it'll look a little better for a rail too. But the center of the tire will wear faster.
Not sure which rim to go with yet.
Also fyi 4wheelparts has a great deal on all-terrains and mud-terrains right now. |
Posted: Mon Mar 20, 2017 7:41 pm Post subject: Re: what tires are people using for 4" rims |
Those are pretty wide tires up front there buddy. Any particular reason you are going that rout? Honestly, the buggies I have drove that drove the west were ones with skinny tires up front. Just something to think about. _________________ 1800 Type 4 Berrien 295
jrp916 Samba Member
Posted: Mon Mar 20, 2017 9:16 pm Post subject: Re: what tires are people using for 4" rims |
Vanapplebomb wrote: |
Those are pretty wide tires up front there buddy. Any particular reason you are going that rout? Honestly, the buggies I have drove that drove the west were ones with skinny tires up front. Just something to think about. |
Good question- I test drive some 235s on the front and I like how well they bite the dirt (we have a dirt track out here) and also with the flexing side wall they absorb bumps well. 235s and 30x9.5 have the same tread width they are just taller. I'm going with 33's in the back so I want something not too far off from that for the fronts.
I also like the look of the mud terrains and am looking forward to the white lettering sticking out.
I think I'm going with 4" front rims to give a more "skinny" front tire look.
For a lot of the buggies out here that drive in the desert the skinny tire may "dig" deeper into the soil for the fronts, but I think these will be a good balance for our dirt track.
For a car that drives on the street a 4" wheel would be too small on a 9.5" tire as you wouldn't get a very flat tread pattern. |
Posted: Tue Mar 21, 2017 4:01 pm Post subject: Re: what tires are people using for 4" rims |
The bigger the tires on the front of a buggy, the greater the forces on the suspension components.
Yes...you can put 30 x 9.50-15 tires on a 15 x 4" wheel. But you would be asking an AWFUL LOT of stock spindles, linkpins, links and kingpins. Probably be OK with Combo Links.
Lots of desert offroad racers use 33x10.50s on the front of Class 5-Open, Class 12 (any width beam front end, limited engine buggy) and Class 10. (similar to 12, but with a-arm front). But their front ends cost many thousands of dollars to build. _________________ Richard
SoCalBajas Member
jrp916 Samba Member
Posted: Wed Mar 22, 2017 8:37 am Post subject: Re: what tires are people using for 4" rims |
dustymojave wrote: |
Lots of desert offroad racers use 33x10.50s on the front of Class 5-Open, Class 12 (any width beam front end, limited engine buggy) and Class 10. (similar to 12, but with a-arm front). But their front ends cost many thousands of dollars to build. |
Thanks, that is a good thing to consider. Luckily I do have combo spindles.
Btw, where do all the racers post? I don't feel like I see much of that activity here. Are they just too busy racing ??? |
69 DEWD Samba Member
Joined: September 28, 2013 Posts: 31 Location: California
jrp916 Samba Member
Posted: Sat Mar 25, 2017 12:51 pm Post subject: Re: what tires are people using for 4" rims |
Here it is! 30s in the front and 33s in the back! I think it looks great but I'm a little disappointed at the width of the 10.5 km2s my old all terrains (31x10.5) were over 3/4" wider on the tread.
jrp916 Samba Member
Posted: Tue Mar 28, 2017 10:46 am Post subject: Re: what tires are people using for 4" rims |
So to provide a little more information. I did some measuring last night the 30x9.5 KM2 mud terrains on 4" rims had a 1.5" tire side bulge past the rim. The exact same amount of side bulge my old 31x10.5 all terrains had on my old centerline 5.5" wide rims. I would admit if this was a street car I would have a little too much crowning on the tire tread surface, but for dirt it seems a good fit.
The 33x10.5 km2 mud terrains on 7" BTR wheels have a 1.25" tire side bulge, I was surprised the front and rears had such a similiar bulge.
This is a picture of the front tire side bulge.
nate3923 Samba Member
Joined: November 08, 2016 Posts: 49 Location: cincinnati, ohio
Posted: Fri Mar 31, 2017 8:11 pm Post subject: Re: what tires are people using for 4" rims |
I run baja pros and love them
chappy89 Samba Member
Posted: Mon May 29, 2017 4:03 pm Post subject: Re: what tires are people using for 4" rims |
hope im not digging up to old of a thread but here is my setup, front 215/75R15, rear 30X9.5R15 Hankook Dynapro M/T
