modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Fri Mar 10, 2017 7:28 pm Post subject: Lightweight engine hardware |
Should be a topic!
Today I noticed that some 2.5 subaru rod nuts fits VW, and it's lighter and stronger, 12mm head and flanged, so now I have to get some of those because.....(well, I guess it won't actually make any REAL difference but it'd be cool.) ah.... Will help stroker clearance!
Another one, is toyota 22r lash adjusters are NEARLY same as vw, and have 12mm jam nuts, so I'm going to start collecting those too.
Bell metric sells 12x1.5 flanged 18mm head nuts that work great on the main studs, they also sell extra thick big 8mm washers that work great on the head studs, trans side covers, ect.
Hondas use lots of 8x1.25 12mm head flanged nuts that work great everywhere.
Happy nut hunting |
Floating VW Samba Member
Joined: April 28, 2015 Posts: 1596 Location: The South Zone
Posted: Fri Mar 10, 2017 8:05 pm Post subject: Re: Lightweight engine hardware |
I used to tell my old man that my VW was better than his Chevy because my emergency tool kit basically only required a 13mm wrench to remove about 90% of all the bolts on the car. But man, those oddball 8 X 1.25's with a 12mm head sure do come in handy sometimes, especially in those hard to reach places like the manifolds. I guess having to throw an extra wrench in the tool kit just to take them off and put them back on isn't such a bad trade. _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
modok Samba Member
Posted: Fri Mar 10, 2017 8:19 pm Post subject: Re: Lightweight engine hardware |
Very often if I take a bolt out OFF the car, I usually replace it with a better one, if I have a better one.
The subaru rod nut has a part number: #802009010
How much lighter will the car be if every 13mm was 12mm?
For emergencies; vise-grips! |
esde Samba Member
Joined: October 20, 2007 Posts: 5966 Location: central rust belt
Posted: Fri Mar 10, 2017 8:33 pm Post subject: Re: Lightweight engine hardware |
I love these for intakes and exhaust, and any tight to get to spot
https://www.belmetric.com/hex-with-flange-c-3_51_5...1vhsmaots7
M8-1.25 10mm wrench, class 10 _________________ modok wrote:
oprn Samba Member
Joined: November 13, 2016 Posts: 12714 Location: Western Canada
Posted: Fri Mar 10, 2017 9:18 pm Post subject: Re: Lightweight engine hardware |
Thanks! I have been looking for those! |
slalombuggy Samba Member
Posted: Fri Mar 10, 2017 9:57 pm Post subject: Re: Lightweight engine hardware |
modok wrote: |
I remember Lexus adds from years ago saying they shaved 30lbs off their cars by using bolts with partially hollow heads.
I have a stash of oddball hardware including a bunch of 8 and 10mm aluminum bolts used on BMW belhousings. They have male TORX heads. I use them for top bellhousing bolts and in a couple of other places
brad |
Posted: Fri Mar 10, 2017 10:59 pm Post subject: Re: Lightweight engine hardware |
slalombuggy wrote: |
modok wrote: |
brad |
30lbs? That's impressive! I recently started a campaign to replace most of my hardware with SS allen head bolts because they don't rust and I think the allens look better, and they're easier to wrench on. The fact that the hollow head might be lighter never even occurred to me. Bonus! _________________ "It's time you started treating people as individuals, rather than mathematically predictable members of an aggregate set, regardless of how well that works." |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4341 Location: Los Angeles, CA 90016
Posted: Fri Mar 10, 2017 11:07 pm Post subject: Re: Lightweight engine hardware |
There's M12x1.5 15mm (15mm if memory serves) 12-point nuts. I keep a few sets at all times. |
Posted: Fri Mar 10, 2017 11:09 pm Post subject: Re: Lightweight engine hardware |
I use the steel and stainless steel oned for the exhaust. Didn't know copper was available. |
Howard 111 Samba Member
Posted: Sat Mar 11, 2017 2:32 am Post subject: Re: Lightweight engine hardware |
The copper nuts are either solid copper, or steel covered with copper. Copper is soft compared to steel. I like the factory nuts and bolts which excludes copper or copper plated. Do everything just like built at the factory. _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
esde Samba Member
Posted: Sat Mar 11, 2017 6:45 am Post subject: Re: Lightweight engine hardware |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
Posted: Sat Mar 11, 2017 1:06 pm Post subject: Re: Lightweight engine hardware |
Floating VW wrote: |
I recently started a campaign to replace most of my hardware with SS allen head bolts because they don't rust and I think the allens look better, and they're easier to wrench on. The fact that the hollow head might be lighter never even occurred to me. Bonus! |
That's not a great idea. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sat Mar 11, 2017 7:43 pm Post subject: Re: Lightweight engine hardware |
UK Luke 72 wrote: |
X2
Unless they are aerospace quality 440 or better stainless that have been hardened....or are way oversized for the apllication. they are quite a bit weaker. About the average class 8.8 bolt (approx grade 5)....or less. They are also quite stretchy.
Also...allen heads for high torque bolts are the absolute weakest and worst system. I only use them when i must......or when I cannot find a Torx bolt if the low diameter head of an Allen bolt is required. Or better yet...Torx-Plus......which blows away any internal males type bit on the market for strength. Google those ane check them out. Ray |
Busstom Samba Member
Joined: November 23, 2014 Posts: 3844 Location: San Jose, CA
Posted: Sat Mar 11, 2017 11:33 pm Post subject: Re: Lightweight engine hardware |
X3. The stainless will be great for holding fenders and running boards on, holding the body on the pan maybe, and many other non-critical apps, but do NOT use them on any steering, suspension or axle retention applications. Prolly shouldn't use them in most tranny and engine mounting situations either...proper torquing can strain the soft threads and put you in a pinch sometime. _________________ My name's Steve and it's pronounced "Bust 'em" (cuz people think I'm Tom) 😏 |
ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Sat Mar 11, 2017 11:57 pm Post subject: Re: Lightweight engine hardware |
modok wrote: |
Back in the early 80's I washed cars for summer employment when i was in college.
I worked at a Datsun dealership, the summer before I had worked at an used car lot that sold American cars.
Datsun 310 a front wheel drive car was the first car I remember being light weight by design, not just by size.
All the hardware was smaller than VW hardware, and they used less of it.
The CV joints only had 3 bolts securing them to the drive flange, compared to VW's 6.
Compared to a Datsun 310, a Beetle was built like a battleship. _________________ Good Luck
Al |
modok Samba Member
Posted: Sun Mar 12, 2017 1:20 am Post subject: Re: Lightweight engine hardware |
It's slightly hard to find the 12mm head flange nuts
Search for "M8-1.25 JIS Flange Class 10 B1190"
if used with the big washers from bell metric they can even hold on the heads, so then you have the head nuts leftover, use those to hold on the rocker shafts. |
Posted: Sun Mar 12, 2017 2:04 am Post subject: Re: Lightweight engine hardware |
[quote="ach60"
Compared to a Datsun 310, a Beetle was built like a battleship.[/quote]
How many Datsun 310s are left now though |
