vwfye Samba Member
Posted: Fri Jan 03, 2020 9:11 pm Post subject: Re: Black is the new black... or, building my Tie Fighter. |
Finally... everything worked... for 10 minutes. But at least the car runs and drives again. But again no right side signal lights.
The 10 minutes they worked were awesome! _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22407 Location: Kimball, Mi
vwfye Samba Member
Posted: Sat Jan 04, 2020 10:47 am Post subject: Re: Black is the new black... or, building my Tie Fighter. |
It must be in the steering column.
My smoke and no start under the dash was a melted signal relay caused by my new to me right front turn signal housing base. Well, not exactly that... I installed said signal base with bulb that was in it. Ompketely my fault for not inspecting it first. The bulb that was in it was a single element and was causing a direct short! It makes me wonder if that is why the donor ended up in the parts yard. I didnt even think to look at the bulb that was in the housing since it was clean and i could see an element. Doh! Dual element should be in there. _________________ 64 No'back Speedster "Pearl"
Posted: Sat Jan 04, 2020 11:10 am Post subject: Re: Black is the new black... or, building my Tie Fighter. |
vwfye wrote: |
My smoke and no start under the dash was a melted signal relay caused by my new to me right front turn signal housing base. Well, not exactly that... I installed said signal base with bulb that was in it. Ompketely my fault for not inspecting it first. The bulb that was in it was a single element and was causing a direct short! It makes me wonder if that is why the donor ended up in the parts yard. I didnt even think to look at the bulb that was in the housing since it was clean and i could see an element. Doh! Dual element should be in there. |
OK, so Jim was right about the wrong bulb up front. Sounds like you might need to replace the switch now that you've let out all of the magic smoke. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sat Jan 04, 2020 11:26 am Post subject: Re: Black is the new black... or, building my Tie Fighter. |
We replaced the melted relay and everything worked. Then it stopped on just the right side only, again. If the issue is in the column, i will just have to live with it. _________________ 64 No'back Speedster "Pearl"
blues90 Samba Member
Joined: March 14, 2009 Posts: 1912 Location: Hollywood ,CA
Posted: Sat Jan 04, 2020 6:18 pm Post subject: Re: Black is the new black... or, building my Tie Fighter. |
vwfye wrote: |
We replaced the melted relay and everything worked. Then it stopped on just the right side only, again. If the issue is in the column, i will just have to live with it. |
If you smoked the relay your are taking about the flasher , usually a fuse blows and if not it's either wired wrong and not fused , if so I would look at the contacts in the fuse box the relay plugs into. What year is this 71. It's either fuse 8 or 10. |
vwfye Samba Member
Posted: Fri Jan 17, 2020 12:55 pm Post subject: Re: Black is the new black... or, building my Tie Fighter. |
Finally got a break in the weather, so back after the electrical gremilns in the car today.
Should be drivong it again this afternoon. Woot! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Fri Apr 10, 2020 2:04 pm Post subject: Re: Black is the new black... or, building my Tie Fighter. |
VWporscheGT3 Samba Member
Joined: September 01, 2006 Posts: 2076 Location: Gardnerville, NV
Posted: Fri Apr 10, 2020 2:16 pm Post subject: Re: Black is the new black... or, building my Tie Fighter. |
wish we could thumbs up posts... nice picture _________________ Schnell, SCHNELL!
I like being wrong, Because, it is another opportunity to learn. If you stop learning from your mistakes than what is the point?
If you have any questions about Forged ICON 4032 VW pistons just shoot me a line. |
QRP Samba Member
Joined: April 27, 2008 Posts: 1710 Location: NORTH HOLLYWOOD,CA
Posted: Fri Apr 10, 2020 4:50 pm Post subject: Re: Black is the new black... or, building my Tie Fighter. |
I LIKE IT |
vwfye Samba Member
Posted: Fri Apr 10, 2020 7:33 pm Post subject: Re: Black is the new black... or, building my Tie Fighter. |
Thanks guys. That was at work today. Had the lot to myself _________________ 64 No'back Speedster "Pearl"
