shoppingshzhang Samba Member
Posted: Sun Jul 30, 2017 8:44 pm Post subject: Vacuum hose not connected to anywhere? |
Hi everyone! New here. We just bought a 82 Vanagon.
It starts but doesn't idle, but we can't pinpoint where to find the issue. I guess the first thing is to figure out what the engine is.
Any ideas?
Thanks
[/img]
Last edited by shoppingshzhang on Tue Aug 08, 2017 1:21 am; edited 1 time in total |
82westyrabbit Samba Member
Posted: Sun Jul 30, 2017 9:02 pm Post subject: Re: What engine is this? |
It's a 2.0 air cooled. If they run but don't idle it is usually a vacuum leak. I can see vacuum leaks in the picture. That engine has points and condenser so you could have problems there to. |
Gauche1968 Samba Member
Posted: Sun Jul 30, 2017 9:03 pm Post subject: Re: What engine is this? |
I am going to go with 2.0L air cooled? _________________ 1984 Vanagon GL
1984 Vanagon Westy |
Microbusdeluxe Samba Member
Joined: July 26, 2003 Posts: 980 Location: Bellingham, WA
Posted: Sun Jul 30, 2017 9:05 pm Post subject: Re: What engine is this? |
It's an air-cooled fuel injected VW 2.0 l engine. Standard equipment in an '82 vanagon. Read up on it in this section as well as in the Bay window forum as this same engine was used in the Bays during their final years (?1978-1980?) _________________ '69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig! |
Thanks guys! I'll read up on it. |
Posted: Sun Jul 30, 2017 11:24 pm Post subject: Re: What engine is this? |
82westyrabbit wrote: |
Would you mind pointing out some potential leaks? |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon Jul 31, 2017 5:47 am Post subject: Re: What engine is this? |
Potential vacuum leaks:
ANY of the multiple hose & mechanical connections to the air flow meter "S"
boot (top R in picture) &/or intake manifold/plenum (top center in picture).
Shortcut: spray carb/choke cleaner at any/all suspect hose connections;
if/when idle surges, you've found an active leak in that area. Fix it.
"Git 'r done!"
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
buspor63 Samba Member
Joined: February 17, 2005 Posts: 1179 Location: Knoxville,TN Where America stops for gas
Posted: Mon Jul 31, 2017 6:24 am Post subject: Re: What engine is this? |
As said, the bay window forum will provide a wealth of knowledge on the engines. The air cooled engine uses Bosch L Jet injection, it's really simple. _________________ Imagine that, theres not an "h" in either Westfalia or Syncro? |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Mon Jul 31, 2017 8:36 pm Post subject: Re: What engine is this? |
Looks like the white plastic fitting headed into your S boot is not fully inserted. I second the use of some starter fluid or other to spot test the junctions and fittings and hose ends for vacuum leaks. Watch out though. That shit it flammable and you could loose your eyebrows or worse. Vacuum leaks are the benign of the aircooled motor.
There is a very informative manual for troubleshooting this setup. Look in the technical instructions manual section for AFC fuel injection manual.
Spend a minute identifying the various components of the system and the whole troubleshooting process will be a lot easier. _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
davideric9 Samba Member
Joined: January 21, 2009 Posts: 1002 Location: Oakland CA
Posted: Mon Jul 31, 2017 10:13 pm Post subject: Re: What engine is this? |
Also looks like the s-boot is not seated onto the throttle body. Clean the inside of the boot and the throttle body where it attaches. if these are oily, the boot can slip off as you tighten the clamp. _________________ 1987 Syncro Westfalia, stock (bought 1994)
1986 Syncro Westfalia SVX, 3 knob (bought 2008)
1987 Westfalia (bought 2010)
1988 Wolfsburg GL (bought 2012) |
Posted: Tue Aug 01, 2017 10:26 am Post subject: Re: What engine is this? |
Thanks guys! I will start looking into it. |
Posted: Mon Aug 07, 2017 11:28 pm Post subject: Re: What engine is this? |
So I connected/tightened the following (first picture) and it seemed to start a little better. It could idled for maybe a second before dying. I am going to drain the fuel tank and give it some fresh fuel and see if that helps.
On one of the hoses (second picture), I couldn't find anywhere to connect. Any ideas?
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
chompy Samba Member
Joined: August 12, 2014 Posts: 400 Location: Cascade Locks
Posted: Tue Aug 08, 2017 10:49 am Post subject: Re: What engine is this? |
See directly below where the hose ends that you circled? The brake booster hose connects to the plenum and that unhooked hose you have there. It looks like they ditched the little Y connector that connects these three hoses together.
See in this shot that was linked earlier the little rubber connector you are missing?
This is the part you are missing: http://www.busdepot.com/022133083d _________________ '81 Westfalia Subaru EJ22
Manual Transmission |
Posted: Tue Aug 08, 2017 2:11 pm Post subject: Re: Vacuum hose not connected to anywhere? |
Change out all the hoses, elbow, and boots and get it over with, if you go with the replace one hose at a time route you will be fighting vacuum leaks for years. These things are 35 years old at this point in time and all the rubber on the rig is rotten and due for replacement. |
Posted: Tue Aug 08, 2017 4:59 pm Post subject: Re: Vacuum hose not connected to anywhere? |
Wildthings wrote: |
Is there a place that sell all these or are they all standard size ones? |
Abscate Samba Member
Posted: Tue Aug 08, 2017 5:06 pm Post subject: Re: Vacuum hose not connected to anywhere? |
You will have to reset your mind a bit to work this one to,daily driver condition
The person who,last worked on it had little idea of what they were doing, so you have to be on the lookout for bizarre things " _________________ .ssS! |
chompy Samba Member
Posted: Tue Aug 08, 2017 8:09 pm Post subject: Re: Vacuum hose not connected to anywhere? |
shoppingshzhang wrote: |
Wildthings wrote: |
Its fairly standard size the main thing to be sure about is the inner diameter of the hose. You'll want the hose to be rated for fuel vapor or even fuel line for the wider hoses so it doesn't deteriorate. There is a little rubber elbow connected to your auxiliary air valve that often cracks too so check that.
Its the 90° bend coming from the right, not the straight hose in the middle of the shot.
This is from a bay window buts it looks the same. _________________ '81 Westfalia Subaru EJ22
