HastaAlaska Samba Member
Joined: November 22, 2012 Posts: 1420 Location: Off Grid
Posted: Sat Mar 11, 2017 11:09 am Post subject: Is my wheel going to fall off (bad Camber and clicking noise) |
Hey guys,
I was wondering what you think about the camber on the rear right wheel. Looks pretty bad huh!
I recently did some work to reduce wheel wobble, replacing the bearing housing, new bearings etc. Although I think that this camber problem is to do with blown our bushings. To be honest I've never worked on adjusting the camber - is this something that can just be adjusted, or is it likely to need new parts when I open it up?
There is a clicking noise coming from the rear and that is the main reason I am seeking advice today. The noise is only under power which leads me to think it is the CV joints.
I've scrolled the forum and tried the advice that I've found. The noise is only audible when driving straight, actually gets quieter turning either way. which is making it hard to know which side to tackle.
I've tried lifting each rear wheel off the ground and putting it in first gear as recommended but there was no noise on either side. I've tried injecting grease down the boots but that did nothing either.
Having trouble finding the CV joints locally and will have to travel to get them (in mexico) so I was just wondering if the noise could be attributed to something else or if it could be related to the camber mention above.
My instinct tells me no, as it only happens under power.
any advice appreciated _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Hasta Alaska Series - https://kombilife.com/hasta-alaska/
World Overland Series - https://kombilife.com/world-overland-travel-series/
Latest Adventures - https://www.youtube.com/@kombilife |
cmonSTART Samba Member
Posted: Sat Mar 11, 2017 11:38 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
Is there any freeplay or wobble when you jack up the rears? Up down, left right, in out?
Are your lug nuts tight?
Personally I think with that much of a camber issue you're probably straining that CV joint pretty hard. Might be the reason for the clicking you described. _________________ '78 Bus 2.0FI
de K1IGS |
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1876 Location: Feeling, Minnesota
Posted: Sat Mar 11, 2017 12:21 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
It looks like the bushing on the diagonal arm pivot split or got crushed. _________________ 1988 Ford Festiva L
1965 Honda 50 "Super Cub"
2016 Miami Sun Trike |
MorkC68 Samba Member
Joined: December 23, 2015 Posts: 610 Location: Nottingham, England
Posted: Sat Mar 11, 2017 12:47 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
Part of the camber problem may be from replacing the bearing housing, the four bolts which hold the housing to the spring plate have some camber adjustment to them. The method of adjustment is in the Bentley manual.
It may be a case of a simple adjustment to bring it back into line. _________________ Major; 1977 Westfalia Campmobile
- Subaru EJ20
- Koni Classic adjustable dampers & Empi Heavy Duty Anti Roll Bar
- 180W Solar System
My blog: https://twolatebays.wordpress.com/ |
Starbucket Samba Member
Posted: Sat Mar 11, 2017 1:42 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
Did you torque the big nut? It might have worked loose and your brake drum splines might have stripped. |
Manfred58sc Samba Member
Posted: Sat Mar 11, 2017 4:03 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
My super high mileage Bus is the same way, I'm guessing the trailing arm bushing answer is correct (crushed ) if you can't get any play out of it jacked up. Clicking is CV, take it off, grease it up, re-insert (wait ..that sounded wrong) or ..maybe parking brake lever moving about in drum?? _________________ Fat chick owner/operator |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Sat Mar 11, 2017 7:17 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
isn't this going to be the new owners problem, or are you fixing it before you give the bus away? _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Sat Mar 11, 2017 7:27 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
skills@eurocarsplus wrote: |
isn't this going to be the new owners problem, or are you fixing it before you give the bus away? |
Nah, just another offhand attempt to get the community to fund/donate for the repairs. Or even a way to get you to boost traffic to his site(s). _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
stwesty Samba Member
Joined: May 10, 2015 Posts: 128 Location: Vancouver, Canada
Posted: Sat Mar 11, 2017 7:54 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
TDCTDI wrote: |
Nah, just another offhand attempt to get the community to fund/donate for the repairs. Or even a way to get you to boost traffic to his site(s). |
That's some pretty ugly cynicism. _________________ 1974 Westfalia, automatic, dual-carb |
Posted: Sat Mar 11, 2017 8:21 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
He's got enough seat time & wrench time (unless it was all staged) in this rig to know the basic fundamentals to at the very least jack the vehicle up, check for play in the rear hub and or trailing arm or to see if it's a bent trailing arm. If not, then he should stay far away from a wrench and a vintage anything. This feigned noob question is just another attempt at getting some attention. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sat Mar 11, 2017 8:29 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
TDCTDI wrote: |
right on. just checking, that's all. thought that was the case so thanks for the confirmation _________________
Jake Raby wrote: |
Brian wrote: |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22461 Location: Escondido CA
Posted: Sat Mar 11, 2017 9:12 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
TDCTDI wrote: |
right on. just checking, that's all. thought that was the case so thanks for the confirmation |
Isn't that like saying.... Shouldn't you be bastardizing some pure unmolested stock cream puff with a Jap motor?
Or what has the site come to when a simple question is answered with tripe cynicism from the brow beating NAZI program?
Just saying is all. There is always another side to the coin dickheads. Sorry, I know Im an asshole.... bejesus did it again, Im sorry.
Look my post caused several more people than usual to look! _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
wcfvw69 Samba Purist
Posted: Sat Mar 11, 2017 9:50 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
Ben, try what the other posters have suggested. Loosen the torsion plate bolts and follow the Bentley procedure to gain as much positive camber as you can.
Check the bushing on that radius arm to see if it's worn out.
Question, When you changed the rear wheel bearing housing, did you get the rear aligned? I'm going to say no or they would have caught the negative camber and tried to get it adjusted out as much as possible. If you didn't, you need to get it checked. When you loosened up and removed the bearing housing, it will change not only your camber but also your toe in/out and tracking.
If it's off a fair amount, you will incur tire wear, poor handling and tracking. The bus won't go straight down the road in extreme examples. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sun Mar 12, 2017 1:21 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
wcfvw69 wrote: |
Ben, try what the other posters have suggested. Loosen the torsion plate bolts and follow the Bentley procedure to gain as much positive camber as you can. |
This adjustment affects toe in/out not camber. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Sun Mar 12, 2017 4:55 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
TDCTDI wrote: |
wcfvw69 wrote: |
This adjustment affects toe in/out not camber. |
Maybe you should get out your Bentley and do a little reading before posting? |
Posted: Sun Mar 12, 2017 6:43 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
TDCTDI wrote: |
wcfvw69 wrote: |
It does both though there's not a tremendous amount of camber to be gained there. _________________ Contact me at [email protected]
Posted: Sun Mar 12, 2017 7:18 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
notchboy wrote: |
yes....it's exactly like that. and you fine folks out there in sambaland are going to have a fucking stroke on my next build thread _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Mar 12, 2017 9:23 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
notchboy wrote: |
yes....it's exactly like that. and you fine folks out there in sambaland are going to have a fucking stroke on my next build thread |
And Ill be the first one to tell the a-hole that makes a comment that any bus on the road is better than no bus Reguardless of its shit welds, diesel motor or battery door _________________
t3kg wrote: |
1964 1500 S
Posted: Sun Mar 12, 2017 9:33 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
notchboy wrote: |
or battery door |
pfft....battery doors are sooo 2014. battery corner hinged at the belt line is where it's at. and all this time I thought you were so in tune with what's hot _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Sun Mar 12, 2017 9:35 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
notchboy wrote: |
or battery door |
pfft....battery doors are sooo 2014. battery corner hinged at the belt line is where it's at. and all this time I thought you were so in tune with what's hot |
Be on the lookout for neon speed holes. Im putting my stock in those _________________
t3kg wrote: |
1964 1500 S
