Joined: August 31, 2013 Posts: 12854 Location: North Carolina
Posted: Wed Mar 22, 2017 2:36 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
You can also use the hammer & chisel to peen the outer edges of the CV bolts to give the vicegrips an area to bite into. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12722 Location: on a bike ride somewhere
Posted: Wed Mar 22, 2017 2:39 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
I also had a pair of vise-grips slip on a CV bolt once, but the combination of vise-grips AND the (mostly stripped out) hex bit worked enough to break it free.
You could also grind down two opposing sides of the bolt to get much more surface area free.
KentPS also had these amazing Channel-Lock brand pliers that could break rusted hardware free that I couldn't get with any wrench. I do not know why they worked so much better than anything else:
https://www.amazon.com/Channellock-410-8-Inch-Capacity-2-Inch/dp/B000189GQK
Good luck! _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
cmonSTART Samba Member
Posted: Wed Mar 22, 2017 4:10 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
asiab3 wrote: |
Good luck! |
+1 on those channel lock pliars - those things are amazing! _________________ '78 Bus 2.0FI
de K1IGS |
captincanuck Samba Member
Joined: August 13, 2014 Posts: 730 Location: The Great White North
Posted: Wed Mar 22, 2017 5:52 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
cmonSTART wrote: |
asiab3 wrote: |
Good luck! |
+1 on those channel lock pliars - those things are amazing! |
Don't know if it would work the same as the mini channel-lock above, but I have used a mini pipe wrench in the past and it worked great _________________ 1979 Westfalia "FireFly" Subaru 2.2 with Subaru gears 5spd.
Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=634777&postdays=0&postorder=asc&start=0 |
HastaAlaska Samba Member
Joined: November 22, 2012 Posts: 1420 Location: Off Grid
Posted: Thu Mar 23, 2017 9:30 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
I'd be interested to hear if you think that tool is better than vice grips for this type of task?
I'm heading to a VW Mechanic to get some help with the CVs. I have 100 miles to drive with holes in the boots.
Do you think that the CVs will make it without significant damage? Grease is already starting to fly out of the boots. _________________ Around The World in a VW - Follow the Docuseries
2011 - PRESENT
Hasta Alaska Series - https://kombilife.com/hasta-alaska/
World Overland Series - https://kombilife.com/world-overland-travel-series/
Latest Adventures - https://www.youtube.com/@kombilife |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Thu Mar 23, 2017 9:44 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
Duct tape or a plastic bag/duct tape will keep crap out of the joints. Thats more important than keeping grease in. _________________ .ssS! |
Posted: Thu Mar 23, 2017 10:03 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
HastaAlaska wrote: |
I'd be interested to hear if you think that tool is better than vice grips for this type of task? |
Unless it's already stripped, the proper tool for the fastener is always better than Vicegrips. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Clara Samba Member
Posted: Thu Mar 23, 2017 9:10 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
Abscate wrote: |
Duct tape or a plastic bag/duct tape will keep crap out of the joints. Thats more important than keeping grease in. |
Yes.. duct tape. Make sure you tape it around the axle in the direction where the wind does not unwind the tape.
I on my bug and never replaced the boot. It is a perfect fix. That was in the nineties. It might have been before you were born. I should probably add more tape. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20275 Location: Sandpoint, ID
Posted: Thu Mar 23, 2017 10:09 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
Clara wrote: |
I should probably add more tape. |
_________________ nothing |
Posted: Fri Mar 24, 2017 2:42 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
Clara wrote: |
Abscate wrote: |
I on my bug and never replaced the boot. It is a perfect fix. That was in the nineties. It might have been before you were born. I should probably add more tape. |
Just tie it off with the spool from an 8 track of the Doobie Brothers _________________ .ssS! |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Mar 24, 2017 7:19 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
Back to the bolt for a minute-- Try some 80 grit wet n dry round the bolt and tight vice grips- sometimes that will do the extra grip it needs to come loose- and tap gently with BFH to shake it a little- last resort is a mini torch with hammer and vice grips- finally - die grind the head off and most will be finger tight upon removal of the joint. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Fri Mar 24, 2017 11:37 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
TDCTDI wrote: |
Unless it's already stripped, the proper tool for the fastener is always better than Vicegrips. |
I think we learned this a few pages ago. _________________ Learn how your vintage VW works. And why it doesn't!
Posted: Fri Mar 24, 2017 11:53 pm Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
That channel lock has a huge mechanical advantage as well as being made of good steel. That's why they are 5x the cost of the HF ones _________________ .ssS! |
Posted: Sat Mar 25, 2017 12:25 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
asiab3 wrote: |
TDCTDI wrote: |
I think we learned this a few pages ago. |
you'd think wouldn't you! |
But then he pops up with this.
Thanks - I did try this method but am holding off messing up the teeth on the bolt on the slim chance than there might be someone with the correct 12point bit to get the bolt out. |
Posted: Sat Mar 25, 2017 12:29 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
TDCTDI wrote: |
asiab3 wrote: |
TDCTDI wrote: |
I say suspected because I wasn't able to finish the job as two of the bolts wont come out (Stripped) |
Keep playing the game it's fun I love when threads go on and on because there's only one way to get out of a sticky situation when the right tools aren't available.
Seriously though, some of the mechanical punts I've kicked in sticky situations would make professional mechanics shit themselves. But that's why I drive my bus everywhere and they don't…
Posted: Sat Mar 25, 2017 12:44 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
Posted: Sat Mar 25, 2017 12:51 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
asiab3 wrote: |
... because there's only one way to get out of a sticky situation when the right tools aren't available. |
Keep playing stupid until everyone pays someone to do it for you?
Posted: Sat Mar 25, 2017 4:53 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
You've got 24 bolts on your CVs and that's 48 uses of the correct tool to lube them properly. Using anything but the correct tool here is causing your own malaise. On a prolonged trip, you would also carry a spare set of 6 new bolts and replace any heads that look weak. _________________ .ssS! |
Posted: Sat Mar 25, 2017 6:44 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
Abscate wrote: |
You've got 24 bolts on your CVs and that's 48 uses of the correct tool to lube them properly. Using anything but the correct tool here is causing your own malaise. On a prolonged trip, you would also carry a spare set of 6 new bolts and replace any heads that look weak. |
Also a good reason to carry a spare of that same tool, just in case you wear it out, shear it off, or lose it in the dirt. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
hidude208 Samba Member
Posted: Sat Mar 25, 2017 9:37 am Post subject: Re: Is my wheel going to fall off (bad Camber and clicking noise) |
TDCTDI wrote: |
asiab3 wrote: |
I keep up with all of ben's posts on the samba....not because there is a lot of value to me for working on my bus, not because he is entertaining, but because I love how much some of you hate him while still giving him advice, watching him ignore your advice for the most part, and trying to drum up more clicks on his videos.
TDCTDI, Abscate, Robbie.... keep up the good(and totally entertaining) work _________________ 1969er, nothing finer
http://www.vw-mplate.com/mplate-37955.htm
SGKent wrote: |
it is called rust. You either cut pieces off a donor or make the parts. Welcome to owning a VW |
