mkeyser1 Samba Member
Joined: February 02, 2015 Posts: 6 Location: Missouri
Posted: Mon Mar 13, 2017 8:54 am Post subject: Floorpan Prep for Media Blasting |
Hello - I am working on my first bug (1960) with the body off and wanting to get the pans media blasted. I have removed the beam/suspension on the front and the trans/transaxle/suspension on the rear. What prep do I need to do on the pans before having them blasted? Specifically, I want to minimize the amount of media getting into places I don't want it. I worry about the tunnel and sand getting in there. What is the best method of plugging the openings in the tunnel? Some of the openings are round where a grommet would work but others are odd shaped so a plug is not available. Any advise would be appreciated. Thank you. _________________ 1960 Beetle |
c21darrel Samba Member
volksbug70 Samba Member
Joined: August 22, 2005 Posts: 126 Location: Tallahassee, FL
Posted: Fri Mar 17, 2017 9:25 am Post subject: Re: Floorpan Prep for Media Blasting |
I too plan on blasting my chassis very soon! My brother and I have it torn down pretty good so far.
I have some additional comments and questions that I think are worth contributing to this discussion:
I actually want to blast inside the tunnel. There is some rust in there around the front of the chassis (where the pedal assembly bolts up), but it is not rusted completely through. I plan to blast it and do my best to protect and paint it in there afterward. I will probably have to get creative. Luckily, the area of rust is isolated and not all the way down the tunnel. Anybody care to comment on their experience with the tunnel?
My main concern is around the spring plates. I will be rebuilding them (at least taking them out and replacing the bushings, and the diagonal arm bushings). The question is, do I blast them first, then disassemble and rebuild? Do I disassemble, blast, and then rebuild? (covering the holes in absence of the spring plates) Or do I disassemble, rebuild, and then blast?
_________________ ~Dave (Brother of Matts70Bug)
1970 Beetle
Undergoing Full Restoration as of February 2017! |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Sun Mar 19, 2017 7:25 am Post subject: Re: Floorpan Prep for Media Blasting |
It will take hours to clean out all of the media when you are done. Hours.
It took 4 or 5 hours with a wire wheel on a grinder and a wire brush by hand in the tight spots to get me to bare metal all over on this one.
I applied Ospho all over to convert any residual rust. Primed and painted with Rustoleum after pans installed. Even this is way more than the factory ever did.
I would wet inside the tunnel with Ospho and then go on to something more important. You can paint inside if you want to. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Sat Dec 12, 2020 2:17 pm Post subject: Re: Floorpan Prep for Media Blasting |
Hi everyone. Hope your day is going smoothly. Question, so I'm going to be media blasting my chassis w/ play sand. Is this too much crap build up or will the sand eat through it? Thanks
_________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Evil_Fiz Samba Member
Joined: May 06, 2011 Posts: 1045 Location: Jacksonville, FL
Posted: Mon Dec 14, 2020 7:24 am Post subject: Re: Floorpan Prep for Media Blasting |
Thanks for the response! The first two time i blasted media, my lugs took an impact so now i use a respirator, gloves, googles, long sleeves, and ear plugs. Sounds funny to some but if its what keeps me safe i dont care.
It looks like before using play sand, i should sift it, and make sure it's dry.
I will remove for of the gunk, this is what i found out yesterday, using black beauty mix from summit,
'66 RIP
'69 RIP
johnnyvw164 Samba Member
Joined: July 27, 2020 Posts: 572 Location: South of Raleigh
Posted: Mon Dec 14, 2020 9:44 am Post subject: Re: Floorpan Prep for Media Blasting |
You can get 80 lb bags of black beauty for under $50 from McMaster-Carr industrial supply. Do yourself a favor and stay away from using play sand for something that large. Put out a huge tarp to reclaim and reuse it if you feel the need. |
Dibaltic Samba Member
Joined: May 06, 2007 Posts: 564 Location: Chambersburg, Pennsylvania
Posted: Mon Dec 14, 2020 10:46 am Post subject: Re: Floorpan Prep for Media Blasting |
This looks like a good option. How many bags do you reckon I need? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'66 RIP
'69 RIP
Posted: Mon Dec 14, 2020 10:57 am Post subject: Re: Floorpan Prep for Media Blasting |
Chickensoup wrote: |
This looks like a good option. How many bags do you reckon I need? |
I'm not sure. I have never reused it once I run it through the pressure pot. If you're just doing the pan and not reusing it I'd guess three or four bags. |
misterh Samba Member
Joined: May 03, 2018 Posts: 23 Location: Central Texas
Posted: Mon Dec 14, 2020 1:51 pm Post subject: Re: Floorpan Prep for Media Blasting |
That's what I use. It works well and it's cheap. |
Posted: Mon Dec 14, 2020 3:01 pm Post subject: Re: Floorpan Prep for Media Blasting |
I built an enclosure out of PVC pipe and plastic sheeting. It cost me about $200 but I was able to reclaim the glass bead media and get away with two 50 Lbs. bags. I blasted my entire pan and about 1/2 of the body on my convertible Ghia.
The enclosure will also serve as a paint booth so I spread the cost out.
Emil _________________
It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Tue Dec 15, 2020 5:28 am Post subject: Re: Floorpan Prep for Media Blasting |
misterh wrote: |
I've used something similar it works great but has to be sifted through a window screen. The bigger bits can clog in the nozzle.
Commercial grade fine sand works the best for me. And as said before. always wear a respirator. _________________ 71 vert build. http://www.thesamba.com/vw/forum/viewtopic.php?t=572951&highlight=dead |
