ach60 Samba Member
Joined: May 14, 2001 Posts: 4139 Location: Santa Maria
Posted: Mon Mar 13, 2017 10:57 pm Post subject: All the Oil Leaked out while It was sitting in garage! |
I kid you not, all the Oil Leaked out while It was sitting in garage over winter!
So I pushed it out of the garage, clean up the quarts of Oil on the garage floor,
and spent a goodly amount of time looking for the leak.
Valve covers where not leaking, drain plate not leaking, pressure relief plugs not leaking, no visual leak from pushrod tubes.
You'd think leaking out 2 quarts of Oil would leave a mark on the engine somewhere but I haven't found.
I'd like to find the leak before pulling the motor next week, as anybody had this happen to them? _________________ Good Luck
Al |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Mon Mar 13, 2017 11:02 pm Post subject: Re: All the Oil Leaked out while It was sitting in garage! |
Put more oil in, start it up and watch. If no leaks, place a piece of cardboard under the engine and check it out the next day.
My guess is the sump plate.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
eashc Samba Member
Joined: April 10, 2012 Posts: 340 Location: Ventura County
Posted: Mon Mar 13, 2017 11:07 pm Post subject: Re: All the Oil Leaked out while It was sitting in garage! |
I drove from California to Texas once. When I hit Palm Springs the oil light flickered then came on solid. Pulled over oil drained out. Had dinner, while wondering what to do. Filled it back up started it up and no more leaks.
After 5 minutes of idling we drove off, keeping an eye on the oil light. Made it to Houston and not a drop was lost.
Fill it and keep an eye for leaks.
Good luck |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6595 Location: Houston, Texas
Posted: Tue Mar 14, 2017 5:17 pm Post subject: Re: All the Oil Leaked out while It was sitting in garage! |
Waldo sometimes hides in those leaks. Just keep an eye on it and check the fluid level before you start. A piece of cardboard is nice to keep below it as well. |
Tom Butler Samba Member
Joined: October 03, 2016 Posts: 287 Location: Bay Area, California
Posted: Tue Mar 14, 2017 7:11 pm Post subject: Re: All the Oil Leaked out while It was sitting in garage! |
eashc wrote: |
Good luck |
this is an amazing post _________________ 1971 Super Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?t=674120
Proud Member Pata De Perro Vw Club
iowegian wrote: |
Instead of converting your car to a different color, why not just buy one that is a color you like? |
ach60 Samba Member
Posted: Tue Mar 14, 2017 7:19 pm Post subject: Re: All the Oil Leaked out while It was sitting in garage! |
kawfee wrote: |
My next step is to remove sled tins, fill it, and see what happens where it happens on the cardboard.
Seems silly I can't find this leak yet. _________________ Good Luck
Al |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15982 Location: North Florida, USA
Posted: Wed Mar 15, 2017 2:22 am Post subject: Re: All the Oil Leaked out while It was sitting in garage! |
The 2qts needed to reach the FULL mark on the dip stick is not enough to reach the valve covers. The rocker valley and the pushrod tubes fill when the engine is running, but should drain once the engine is stopped. Actually running the engine will nearly drain the crank case of all oil. While running, most of the oil is moving around the engine. Since your problem happened while it was sitting you should refill the engine and let it sit. Unless your case is cracked (in which case it could be leaking from ANYWHERE) you want to focus on the case split below the camshaft/oil pump line and around the drain plate. These are the common leak spots. It wouldn't take a large leak at the case split or drain plate to empty your engine over the course of the entire Winter season. More than a few drops a day at the bottom of the case might just do it. _________________ AshMan40
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Mar 15, 2017 7:17 am Post subject: Re: All the Oil Leaked out while It was sitting in garage! |
Tom Butler wrote: |
eashc wrote: |
Good luck |
this is an amazing post |
Indeed.
It makes one wonder what he had for dinner, doesn't it? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31362 Location: Hot Arizona
Posted: Wed Mar 15, 2017 8:17 am Post subject: Re: All the Oil Leaked out while It was sitting in garage! |
ach60 wrote: |
Seems silly I can't find this leak yet. |
Too much work, cut some cardboard and slide in above the tins. Write a note and place on driver seat so you don't forget that you did this. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Volks Wagen Samba Member
Joined: February 13, 2013 Posts: 2926 Location: Germany
Posted: Wed Mar 15, 2017 11:49 am Post subject: Re: All the Oil Leaked out while It was sitting in garage! |
iowegian wrote: |
Tom Butler wrote: |
eashc wrote: |
Good luck |
Indeed.
Perhaps he ate Schrodinger's Cat? _________________ 1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile. |
vamram Samba Member
Posted: Wed Mar 15, 2017 12:08 pm Post subject: Re: All the Oil Leaked out while It was sitting in garage! |
Volks Wagen wrote: |
iowegian wrote: |
Tom Butler wrote: |
eashc wrote: |
Good luck |
Indeed.
Perhaps he ate Schrodinger's Cat? |
_________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
