measurement needed from door post to door post
Tim MacDonald
Tim MacDonald is offline
PostPosted: Tue Mar 14, 2017 5:27 am    Post subject: measurement needed from door post to door post Reply with quote
I have a 53 beetle and the bottom of the door pillars on the strike side is rusted free on both side. I want to remove the body off the pan but before I do I would like to know the measurement from the inside of the drivers door pillar to passengers door pillar so I can weld a piece of bar across and it will be the right width
Thank you
61 so34 flip seat
78 automatic champagne Westfalia
84 mint original paint westfalia
57 oval project barn find
88 cabriolet
BotanyBandit
BotanyBandit is offline
PostPosted: Tue Mar 14, 2017 1:12 pm    Post subject: Re: measurement needed from door post to door post Reply with quote
When i replaced the heater channels in my bug, I left the body on the chassis and checked my door gap and general fitment to make sure the pillars were in the correct location. Then, once i was sure that my body was where it should be, I welded a bar from pillar to pillar to ensure that when the body was removed the measurement wouldn't change. Also I used some steel square tubing to weld a removable jig that screwed into the striker plate and hinge plates to maintain the front to rear gap. Once it was all braced and locked into place I was able to cut out both heater channels and some of the pillars and replace them and my measurements were spot on once fitted. Word of caution though. If your bug is soo crusty that the pillars need replaced, your hinge plates may be loose and cause the doors to sag a lot. I know its not a measurement, but I had good luck with that strategy. Good luck!
the best way to get the right answer on the Internet is not to ask a question, it's to post the wrong answer
Tim MacDonald
PostPosted: Tue Mar 14, 2017 7:01 pm    Post subject: Re: measurement needed from door post to door post Reply with quote
Thank you for the reply. My hinge side posts are solid. My issue is the bottoms of the strike side are rusted free and just floating so I don't know if they are spread apart more then they should be. This is the reason I need the measurement so I can cut a piece of steel to the correct length to insure they are the correct width apart
61 so34 flip seat
88 cabriolet
marklee
marklee is offline
PostPosted: Wed Mar 15, 2017 6:32 am    Post subject: Re: measurement needed from door post to door post Reply with quote
The best option for you is to hang the doors. Leave the body on the chassis. Make sure there is weight in the car to replicate engine, trim, driver, fuel, glass etc. Close the doors so they latch. Once latched weld a bar across the door aperture to hold things in position. This will be your start point.
CGLI qualified body repair and refinish tech
CGLI qualified motor repair tech
Qualified automotive Glass installer
Motor Insurance Repair and Research Centre,Thatcham, Advanced Vehicle Damage Estimator.
Police qualified vehicle examiner
Police Class 1 High performance, pursuit trained Advanced driver
