Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Thu Mar 16, 2017 7:17 am Post subject: Re: *Insulation* - 3M Thinsulate - worth it? |
Thanks Greg, I saw this in your thread. Your bus is coming along nicely!
For installation simplicity I think I'm going to go with some of the flexible elastomeric closed cell foam stuff. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
Posted: Thu Mar 16, 2017 7:18 am Post subject: Re: *Insulation* - 3M Thinsulate - worth it? |
flemcadiddlehopper wrote: |
Interesting stuff...
I have been looking for a source of the 3M acoustic thinsulate to put in my bus. Just for the acoustics, although I wonder if it would keep my bus cooler in the summer. That's beside the point.
What I am wondering is, have you found a source for the 3M stuff through a jobber outlet, or are you looking at amazon, Ebay and the likes?
And, my $.02....if it is a camper and stock motor, I would buy the lightest insulation possible.
Gordo. |
I have only seen it for sale on eBay. There a guy who has posted on several forums that is the re-seller of the stuff. His name is Hein or something like that. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Thu Mar 16, 2017 1:08 pm Post subject: Re: *Insulation* - 3M Thinsulate - worth it? |
You could check out the "spaceloft" gel insulation by Aspen aerogels - comes in 57" wide rolls. No idea on cost. R value of R=1 per 0.1" thick, so the 0.4" thick product would be around R=4, which is about as good as it gets. FYI It is not a gel and is moisture and mold proof.
Nothing in the literature says it's applicable to automobiles, but it does say it remains effective up to 390 degrees. These products were developed for NASA (just like the bubblefoil insulation)
http://www.aerogel.com/products-and-solutions/all-insulation-products/
http://inhabitat.com/exciting-advances-in-insulation-with-aerogel/ _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Posted: Thu Mar 16, 2017 1:41 pm Post subject: Re: *Insulation* - 3M Thinsulate - worth it? |
FWIW, it looks like the thinner (0.24" thick, R=2.4) spaceloft is about $4/SF on ebay (about $0.50 more per SF over 3M thinsulate).
EDIT: I emailed their company and they sell the 0.4" (R-4) product direct for $5/SF+shipping, no minimum order. They also said that this material would work well in automobile/RV applications. _________________ Wish List:
Mark Laken
Fort Collins, CO |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Fri Mar 17, 2017 4:05 pm Post subject: Re: *Insulation* - 3M Thinsulate - worth it? |
Thanks for posting the Aerogel info! Been looking for that off and on for a long time since seeing a video on tiny houses that were shown on the Washington DC mall grounds. One structure had Aerogel between panes of glass to make a insulated wall that allowed plenty of light thru.
With a layer of bubble wrap (reflects heat back outward) on the outward side of the Aerogel should do the trick in our Buses. _________________ In Stereo, Where Available! |
Posted: Mon Mar 20, 2017 2:58 pm Post subject: Re: *Insulation* - 3M Thinsulate - worth it? |
I'm not sure any other product would be needed if you went with the aerogel - it looks like it insulates against high temps pretty well
Mark Laken
Fort Collins, CO |
Posted: Mon Mar 20, 2017 3:05 pm Post subject: Re: *Insulation* - 3M Thinsulate - worth it? |
marklaken wrote: |
I'm not sure any other product would be needed if you went with the aerogel - it looks like it insulates against high temps pretty well. |
Yes, but there is still going to be some transfer of heat over time.
Plus want something to allow air flowing between the insulation and the cold metal wall interior. So when moisture that condenses on it will have an avenue to get back out from there. Bubbles of the bubble wrap against the metal should do that spacing for that purpose. _________________ In Stereo, Where Available! |
Posted: Tue Mar 21, 2017 7:11 am Post subject: Re: *Insulation* - 3M Thinsulate - worth it? |
That Space Loft stuff looks pretty cool but they don't say if it retains moisture or not. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
Posted: Tue Mar 21, 2017 7:24 am Post subject: Re: *Insulation* - 3M Thinsulate - worth it? |
Mr. Electric Wizard wrote: |
That Space Loft stuff looks pretty cool but they don't say if it retains moisture or not. |
From the article posted above:
" in fact the material is 99% air. It’s quite thin, breathable, fireproof, doesn’t absorb water, and is very strong considering it doesn’t weigh much." _________________ In Stereo, Where Available! |
Posted: Tue Mar 21, 2017 7:32 am Post subject: Re: *Insulation* - 3M Thinsulate - worth it? |
Eric&Barb wrote: |
" in fact the material is 99% air. It’s quite thin, breathable, fireproof, doesn’t absorb water, and is very strong considering it doesn’t weigh much." |
Thank you. I am illiterate. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
Posted: Tue Mar 21, 2017 7:37 am Post subject: Re: *Insulation* - 3M Thinsulate - worth it? |
Thank you. I am illiterate. |
No worries, we all do that dumb human thing now and then. _________________ In Stereo, Where Available! |
