jz56oval Samba Member
Joined: September 03, 2007 Posts: 375 Location: bay area
Posted: Tue Mar 14, 2017 9:07 pm Post subject: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
Hey all
I'm running a stock 36hp in my 56 bug. I went to check my spark plugs and the 3&4 plugs were black and the 1&2 are tan in color.
My exhaust tips were cleaned out and after 100 miles the right side was tan and the left was dark grey to black in color, same as the spark plugs.
Black is telling me that it's rich and tan is good. It's us a single 28pci.
I figured someone could chime in kn what they think might be an issue here or things to check.
Car runs good. Just has a bit of jumping around at idle. I notice it when I put the timing light to the crank pulley mark. It never stays in one spot.
Thanks in advance for any info or help.
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Tue Mar 14, 2017 9:20 pm Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
Thanks. That seems to make sense. There is only one carb so it all comes from one area.
Guess I'll be spraying the 1 and 2 area for leaks. |
modok Samba Member
Joined: October 30, 2009 Posts: 26785 Location: Colorado Springs
Posted: Wed Mar 15, 2017 1:14 am Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
Maybe vac leak, maybe heads don't match. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12714 Location: Western Canada
Posted: Wed Mar 15, 2017 5:30 am Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
Could it be a worn distributor if the timing is bouncing around?
Just a thought. |
Posted: Wed Mar 15, 2017 5:52 am Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
I'll check for any vac leaks soon. Both of thr heads were rebuilt recently and looks to be the same. |
Posted: Thu Mar 16, 2017 1:00 pm Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
Using starter fluid I checked for vac air leaks today and found one one at the throttle shaft. I could find any around where the manifold mou ts to the heads or exhaust attachments.
The starter fluid made the car bog down instead of increase the rpms when sprayes on the throttle shaft on carb.
Is it possible that a single carb can make the 3 and 4 cylinders rich and the 1 amd 2 side leaner? My thought would that it would be the same on both side unless there was a air leak on the one side.
Thanks
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34003 Location: Conejo Valley, CA
Posted: Thu Mar 16, 2017 2:33 pm Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
Heat riser burnt through into the manifold on one side? |
Posted: Thu Mar 16, 2017 2:47 pm Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
KTPhil wrote: |
Do you mean, does the heat riser have a hole in it? No holes in the heat risers and are not plugged. |
KTPhil Samba Member
Posted: Thu Mar 16, 2017 3:37 pm Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
Sometimes the damp and corrosive exhaust opens a hole connecting the heat riser and the intake runners, inside the weld or encasement where you can't see it. But the engine will see it as a vacuum leak, of course. There was a thread showing this happening a while ago. |
Posted: Thu Mar 16, 2017 3:47 pm Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
KTPhil wrote: |
OK I understand now what you meant. I'm not sure yet until I check it out further.
Thanks for the info. |
Howard 111 Samba Member
Posted: Thu Mar 16, 2017 6:37 pm Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
My guess is it's an ignition problem. Could even be as simple as the ignition wires. The plugs get dark from not firing well on those cylinders. What distributor are you running? _________________ 1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270 |
Posted: Thu Mar 16, 2017 7:08 pm Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
Howard 111 wrote: |
My guess is it's an ignition problem. Could even be as simple as the ignition wires. The plugs get dark from not firing well on those cylinders. What distributor are you running? |
I'll be checking this out as well.
I'm running a bosch 010 with petronix ignition. I have some plug wires on there way to install. |
Posted: Thu Mar 16, 2017 8:59 pm Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
I would get a new distributor cap as well. With a new cap and the wires, that's everything replaced that could give you trouble. The Pertronix is fine. It wouldn't do what you are experiencing. _________________ 1973 Karmann Ghia
Posted: Mon Mar 20, 2017 6:31 pm Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
Just an udate on findings.
I changed my carb to another one I had on hand that was in cleaner condition. The timing stays steady now and not bounce around like before. I still need to drive it a bit to see if the lean and rich issue is still present.
At least one thing is hopefully fixed.
Next, Gonna check compression on each cylinder |
Posted: Tue Mar 21, 2017 10:20 pm Post subject: Re: Running rich on cylinder 3 & 4 and perfect on 1 & 2 |
So after drivimg her for 45 minutes the idle seems to stay steady with the new carb and different jetting. Timing doesn't jump around like it use to and stays steady. Need to drive a bit more to see if my jetting is close.
Jetting now is
135 main
180 Air correction
23.5 mm venturi (down from the 24.5mm)
I did do a compression test on all cylinders
#1 - 100
#2 - 95
#3 - 106
#4 - 106
Are these numbers way off. Mayne this is why there is a leaner burn on 1 and 2 side and richer burn kn 3 and 4 side?
What do you guys think. |
