txasylum Samba Member
Joined: December 15, 2004 Posts: 389 Location: Boyers, PA
Posted: Thu Mar 16, 2017 1:56 pm Post subject: Painting Tins to Match Car |
I've searched this forum but did not find what I was looking for. I have my motor out and tins off. I will sand blast them and repaint. The question is what color.
1. I'm considering painting them to match my car color (GM Sunset Orange). It is a base/clear. I talked to the local paint shop and they said enamel should work fine and they can mix it up in a spray can. Same color.
2. Or should I stick with the stock black. Advantage is easier to obtain paint and certainly cheaper.
What is everyone's thoughts about painting the tins to match the car? Please let's not discuss the possibilities of black minimizing heat. That is not what I want to talk about.
Thanks and looking forward to your thoughts/comments.
1966 Beetle
nogoodwithusernames Samba Member
Joined: November 10, 2014 Posts: 599 Location: CA, USA
Dan Hiebert Samba Member
Joined: July 14, 2016 Posts: 169 Location: Northern Maine
Posted: Thu Mar 16, 2017 5:19 pm Post subject: Re: Painting Tins to Match Car |
I've read in many places that VW painted the tins black because that dissipated heat the best. Having lived in the southwest most of my life, I can tell you that aint so, just leave something black in the sun for a bit and see if you can pick it up. Silver is the same. I'd take "black" with a grain of salt, basic black is one of the cheapest colors, VW leaned towards economical, 'nuff said. Looking around, lots of folks paint their tins body colors and even install chromed tins. They report no issues. Folks that report overheating issues are where it's hot. You are in Pennsylvania, I don't think you'd have anything to worry about, other than if you want an original looking engine bay, or want what pleases you. "Whatever floats your boat." |
Joseph DR Samba Member
Posted: Sat Mar 18, 2017 6:38 am Post subject: Re: Painting Tins to Match Car |
Take 'em to get powder coated or better yet, ceramic coated. _________________ 1964 Beetle |
EverettB Administrator
Joined: April 11, 2000 Posts: 69827 Location: Phoenix Metro
Posted: Sat Mar 18, 2017 9:11 am Post subject: Re: Painting Tins to Match Car |
My opinion:
Pretty much every car I have seen, that gets driven, has dirty tin.
Black tin still looks pretty good when dirty.
When I've seen driver cars with painted tin, it looks like crap.
Of course, there is a good chance that a lot of the painted tin engines I have seen were done with crappy prep work and crappy spray paint. _________________ How to Post Photos
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Wed Mar 22, 2017 2:40 pm Post subject: Re: Painting Tins to Match Car |
I have seen plenty of nice tin paint jobs get ruined over time on the cylinderhead tin from high heat destroying the paint over time, keep in mid that you have a real several hundred degree chunk of aluminum directly under them... If you do want to paint the tin use a high-heat paint that is made for engine blocks or exhaust, as most standard automotive body paint can be damaged over time if you actually drive your car.
Your tin will tend to look nasty over time unless you take the time to keep it clean every now and then.
Black always looks good, if a little bland. On a stone stock engine I like black best.
On your car I personally think that some of the basic Chevy Orange engine block paint would match pretty nicely, and look better than an exact match to a metallic body color...
On my next set of tin I'm going with a purple to match my steelies, but I have a beige car so it sort of works with the body color surprisingly, the tins just black for now... _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Mar 22, 2017 5:06 pm Post subject: Re: Painting Tins to Match Car |
Original black & grey looks/stays looking best on VW's.
_________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
