Bobnotch Samba Member
Posted: Sat Jan 20, 2018 12:39 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
KollynnBlackpaw wrote: |
Oh, also I was noticing an issue on that Portland drive - occasionally when shifting into first from a stop, it will grind a bit. And yes, I do have the clutchall the way in, at a complete stop. Didn't seem tragic, but sometimes it also won't shift down to second or first from third, not sure about fourth. Very rarely does it happen, but it does. I have to shift back into whatever gear I was in to shift down usually, or be stuck in that gear even. |
Check the transmission fluid level, as it might be low. To do that you'll need a 17mm Allen wrench. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KollynnBlackpaw Samba Member
Joined: October 19, 2016 Posts: 528 Location: Hubbard, Oregon
Posted: Sun Jan 21, 2018 12:40 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Bobnotch wrote: |
Check the transmission fluid level, as it might be low. To do that you'll need a 17mm Allen wrench. |
Wouldn't that be for an Automatic? I have a manual still. _________________ '71 Shantung Yellow AT/FI Squareback |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sun Jan 21, 2018 8:54 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Manual transmissions also have 80-90 weight gear oil in them up to the 17mm plug on the side or they will burn up. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sun Jan 21, 2018 9:16 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Mike Fisher wrote: |
Manual transmissions also have 80-90 weight gear oil in them up to the 17mm plug on the side or they will burn up. |
Ohhh, okie dokie! I'll check it out tomorrow at lunch at work. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Mon Jan 22, 2018 3:25 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Yes, and if the fluid level is low, it can make for hard shifting, and whining. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Tue Jan 23, 2018 12:43 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
So, having another issue here. Took a drive to Portland last night and had my first REAL breakdown. On the drive, about 55-60mph, I started getting surges. I pulled off into Tigard and the car shutoff entirely at the stop. I barely started again and limped over to a Taco Bell parking lot, shut off the car, and he'd not start again. The oil was full, as I'd given him a change the other day ago, and the battery connections are fairly clean and well tightened. After setting for a while, checking spark plugs, adding just a bit extra oil, checked the fuses, etc, the car still wouldn't start. I couldn't even get the parking lights or lights to work. I sat longer, about 20 min total, and he started again, but continuing the trip I still felt the surges.
On the way home from the trip, I felt none, utterly fine with an extra person and some luggage in the car. What might be wrong? _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Tue Jan 23, 2018 1:11 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
You might have crud/rust in your fuel tank and/or fuel filter causing fuel starvation. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Wed Jan 24, 2018 1:55 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Run the Voltage Regulator tests outlined in Bentley. You could also have a worn brush in the generator. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Jan 28, 2018 6:16 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Well with those last few issues fixed, I've moved on and gotten those Huls camping hinges out of the 70, however I'm wondering how and if you can place them on a 72 seat, or perhaps I'm missing parts. They look strange, to me, and the 72's hinge pins are hollow, which makes me wonder how to get them out and if they'll fit the huls pins.
Pics of the hinge area and seat bottom for reference. They're confusing looking and I didn't see a ton of info on setting em up. If they won't transfer over to a 72, I'll end up selling them at this year's Bug Run or Bug In.
Edit: On that note, if I do need an earlier seat for these, does anyone nearby-ish (Oregon or very south WA) have a decent, white, earlier model seat and seat cables for sale? _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Mon Jan 29, 2018 1:32 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Contact Toby Erikson, he's in the Portland area, and has those same camping hinges in his Orange 72 Square. He's also got a write up on installing them, but I don't have a direct link available to it.
I hope this helps. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Jan 29, 2018 3:29 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Bobnotch wrote: |
I hope this helps. |
Thank you Bob, as always everything helps I'll try and contact him soon, I did see an old Post with a website for installing them, and i believe it said I had to use an early model seat due to the cable mount difference. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Sat Feb 03, 2018 11:53 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Does anyone have reccomendations for removing the carpet glue? I see a lot of answers for Rabbit stuff and wanted to know what y'all think I should do, as I'm ordering new carpet here with the money I made off the Automatic square I sold.
In other news;
Where is the inline fuse for the rear defroster and backup lights located? I had realized they have fuses somewhere back there while looking at the wiring chart for fun, and neither work, so I'm hoping that's the issue.
I'm working on sourcing an earlier model rear seat bottom for those hinges to go into. I'll be keeping my stock one and original hinges in case I ever want to sell off the hinges and seat.
I got the roof rack on! I don't have the slats in as they're being redone by my mother, but it still looks great up there and doesn't fit half bad. As he told me, you do have to pull on the legs a little to get it just right, but for a New Beetle rack it seriously fits well, and the emblem's paint is a perfect match to mine.
Cars and Coffee has been great fun! Got a lot of attention today, lots of nice cars there with me.
And as I said I sold the automatic square I had bought for what I feel was a fair price. Also sold some spare parts I had, including that bug beam from when I owned Oliver. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Mon Feb 05, 2018 2:08 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Does anyone have reccomendations for removing the carpet glue? I see a lot of answers for Rabbit stuff and wanted to know what y'all think I should do, as I'm ordering new carpet here with the money I made off the Automatic square I sold. |
Either 3M adhesive remover, or GOOF OFF. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Feb 05, 2018 2:27 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Bobnotch wrote: |
Either 3M adhesive remover, or GOOF OFF. |
Alrighty! I had seen both suggested a few times but a lot of other stuff too, so I'll try these out first. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Mon Feb 05, 2018 11:13 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
With the money from selling the AutoSquare, plus taxes coming in finally, I've ordered a buncha stuff just to make Blue a little nicer! New back seatbelts since mine don't want to come out of their rollers, chrome handbrake handle for fun, new carpet kit, a new ebrake boot, an antenna for when I get a radio sorted, new sun visor clips, caps for the windshield wipers that I didn't even know existed, stainless steel trim kit from ISPWest, and I'll be ordering some mesh headlight covers soon!
Enjoy some photos. I really need to get a nicer camera!
Donnie strickland Samba Member
Joined: December 21, 2009 Posts: 2403 Location: Moody, AL
Posted: Tue Feb 06, 2018 4:36 am Post subject: Re: "Blue" '72 Square build from a newbie. |
Bobnotch wrote: |
Alrighty! I had seen both suggested a few times but a lot of other stuff too, so I'll try these out first. |
This has also been suggested with good results:
https://www.amazon.com/dp/B005RNGN8I?tag=viglink129040-20 _________________ 71 Elm Green FI A/T Squareback |
Posted: Tue Feb 06, 2018 7:40 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Noticed something today - occasionally at speeds over 50ish (usually 53-60) I'll get shaking in the steeringwheel. NOTE: The front doesn't shake side to side, it's perfectly stable and honestly the car practically drives itself, it seems to ONLY be the steering wheel. Could this be due to the earlier model steering wheel? Can this lead to issues? Again, there's NO signs of the actual wheels turning at all when this occurs, it just happens in the steering wheel.
Also some squeaking up front at low MPH driving in suspension-y areas, like the train tracks in town. Probably not anything important but only started occurring recently, or at least is only now noticable. _________________ '71 Shantung Yellow AT/FI Squareback |
andybla Samba Member
Posted: Wed Feb 07, 2018 3:38 am Post subject: Re: "Blue" '72 Square build from a newbie. |
Maybe that could be the steering damper |
Posted: Wed Feb 07, 2018 5:06 am Post subject: Re: "Blue" '72 Square build from a newbie. |
Likely the upper torsion arm needs adjustment:
BSQUARE Samba Member
Joined: November 05, 2004 Posts: 1876 Location: Feeling, Minnesota
Posted: Wed Feb 07, 2018 6:19 am Post subject: Re: "Blue" '72 Square build from a newbie. |
Noticed something today - occasionally at speeds over 50ish (usually 53-60) I'll get shaking in the steeringwheel. NOTE: The front doesn't shake side to side, it's perfectly stable and honestly the car practically drives itself, it seems to ONLY be the steering wheel. Could this be due to the earlier model steering wheel? Can this lead to issues? Again, there's NO signs of the actual wheels turning at all when this occurs, it just happens in the steering wheel. |
Check the entire front end/steering.
Sounds like a loose tie rod end, to me,but could also be the steering damper or upper bar adjustment, as Donny and Andy mentioned.
Quote: |
Also some squeaking up front at low MPH driving in suspension-y areas, like the train tracks in town. Probably not anything important but only started occurring recently, or at least is only now noticable. |
I had the same issue after driving in the rain. Turned out that water had gotten to the front shocks, spraying some penetrating lube up onto the rods shut them up. You might also want to grease the front beam, the squeaking might be a sign that it's due. |
