"Blue" '72 Square build from a newbie.
Page: Previous  1, 2, 3 ... 17, 18, 19 ... 22, 23, 24  Next
Boogievan
Boogievan is offline
PostPosted: Fri Mar 30, 2018 9:36 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
KollynnBlackpaw wrote:
3 and 4 show 80 and 2 shows... 20!? can't be right.
Did you have a chance to check your valve clearances? If they are too tight, it can certainly cause low compression. Not saying that's the problem for sure, but it needs to verified as correct or adjusted.
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Mar 30, 2018 10:42 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Your fouled spark plugs & low compression indicate you need a set of new pistons/rings/cylinders. They are sold as a set for VW's pretty reasonable. Might as well rebuild the heads as needed too as they are usually part of the problem. Good time for a new clutch too if needed. Can you drive your bus to work now?
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
KollynnBlackpaw
KollynnBlackpaw is offline
PostPosted: Fri Mar 30, 2018 12:07 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Unfortunately no - both to the bus and the valves. Been way too busy to do a whole lot, and I only fixed that durring work anyways.
The bus won't hold a charge on the battery still and is leaking oil worse than before. I was planning on getting Blue going well enough to be driven while I rebuild Frau's engine and do some wiring fixes.
'71 Shantung Yellow AT/FI Squareback
Bobnotch
Bobnotch is offline
PostPosted: Fri Mar 30, 2018 12:09 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
And this is the reason why Tram and I go thru the entire car before trying to drive it. Every time something little comes up, it makes the owner want to get rid of it, because it's "nickle and dimeing" the owner. It's more than nickles and dimes though, but it 's the constant screwing around with the car, rather than enjoying it and just doing scheduled maintenance that gets to them.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
KollynnBlackpaw
PostPosted: Fri Mar 30, 2018 12:14 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Ah it's less I wanna get rid of it for money he's using, I'm just getting upset with him. I don't think I'd wanna get rid of him for a long time to be honest. But I get what you're sayin.
W1K1
W1K1 is offline
PostPosted: Sat Mar 31, 2018 9:12 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
I hear it all the time, some guy buys a 40 year old car that's been sitting in a field and says he's going to drive it. Sure it fires up and drives, but then all the systems that have been neglected over the years start to break down ,and then the whining starts. The last "Clean it up and drive it" took me 18 months to drive it.
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
Bobnotch
Bobnotch is offline
PostPosted: Sat Mar 31, 2018 11:07 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Yup. Exactly. A buddy of mine dropped off a truck that had "only" been sitting for 10 years. It "only" need a trans to get it going again, BUT, it needed a bunch of other repairs, along with some metal added. By the time we were done doing it on the "cheap" (out of pocket), he had 10K into it, and 14 months of time spent. And even then after 4 months, we removed the FI off it and swapped the induction system to a 4 barrel carb as it had something going on with the EFI, and everything tested good on it (tested by several people using multiple testing devices). It's been good to go since then and he's been using it the last 5 years with just regular maintenance (oil changes, plugs, cap and rotor, air filter, fuel filter etc).
One of the absolute worst things to do to a vehicle is "park it". Things that worked before suddenly stop working. This is especially true of electrical items. Then the rodents move in, and eat the wiring, the stuffing in the seats and carpet underlay, and finally the rodent wizz. That last takes real work to get rid off.
Tram wrote:
Tram wrote:
KollynnBlackpaw
PostPosted: Thu Apr 05, 2018 6:16 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Guys, it's not like I bought him out of a backyard. He was a Portland driver, sold as a Portland driver, and is now a Hubbard/Wilsonville/Woodburn/Silverton driver. If I pulled him out of somewhere there's no way I'd try and just drive him. That's why my beetle (check my signature!) isn't just getting a battery thrown in and the wires twisted together to try and start it.
In other news: Just got new brake shoes I'll be putting on tomorrow. I know Blue's were worn when I did the cylinders. He's also firing much more often now and likely just needs his plugs cleaned from running when he still wasn't exhausting quite right. I also started to wax more of him! He's also going to get his bumper on soon, I'll be taking it in on Monday and seeing if someone can't help me with holding and bending.
This weekend at home will be that work, plus clearing a space out in the garage to drop Eiche the Bug's engine and start working on it. He'll be my first rebuild to work on. Frau's will have to come later, as she runs but her electrical is shot, and Blue's will come much later just because he runs fine and I can't be bothered. And it'll be a little more difficult and expensive getting parts for FI, anyways , I'm sure.
Mike Fisher
PostPosted: Fri Apr 06, 2018 6:51 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
I Would put a battery in Eiche to see if it will run. Eiche might have better compression then Blue that is fouling out its plugs every week. Drive Eiche while you rebuild the engine in Blue or Frau. Idea
KollynnBlackpaw
PostPosted: Fri Apr 06, 2018 10:03 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
I'd take a look at the topic if I were you! Eiche isn't going anywhere, lol! He needs a full rebuild unfortunately. Siezed engine, both of em, plus no rear window or floors!
Mike Fisher
PostPosted: Fri Apr 06, 2018 11:11 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Do you have How to Rebuild Your Volkswagen Air-Cooled Engine by Tom Wilson from Amazon etc, so you even have a clue how to rebuild it? I might rebuild the Bus engine first?
KollynnBlackpaw
PostPosted: Fri Apr 06, 2018 11:12 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Mike Fisher wrote:
Do you have How to Rebuild Your Volkswagen Air-Cooled Engine by Tom Wilson from Amazon etc, so you even have a clue how to rebuild it? Wink
I do! I bought it when I owned t he first bug, Oliver, way back when. It'll be a fun learning experience for sure, then all that will go into doing Blue's and Fraus engines.
Mike Fisher
PostPosted: Fri Apr 06, 2018 11:19 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
If the Bug needs floors/glass/engine etc it might be cheaper/easier to rebuild the panel Bus.
KollynnBlackpaw
PostPosted: Fri Apr 06, 2018 11:21 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Oh the bus will be fully rebuilt, but the bug's engine is getting rebuilt just because it'll need it all gone through and done anyways. If nothing else I have the spare block already out to work on, so I don't have to drop anything right this second. Eiche will be a long term project, I wanted to save him from ending up a parts car as, besides the obvious, he's quite a nice car and I got him very very cheap.
Clatter
Clatter is offline
PostPosted: Fri Apr 06, 2018 11:42 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Funny story..
Years ago I had a girlfriend that needed a car.
We bought a 'great driver' from some clown old man off of the paper.
It had fairly low miles, like 85,000 OG on the clock.
Had all of those typical little issues, rubbery-feeling clutch pedal, spongy brakes that pulled to one side, inelegant cold-start routine, etc.
We drove it up to my friend Charlie's house, who is an Ace wrench, after work Friday.
Had the motor out/apart/clean late on Friday night, and our shopping list made.
Saturday AM we bought everything we thought we would need;
Motor mounts, trans mount, axle boots, engine gasket set, master/wheel cylinders, clutch kit, ignition kit, carb kit, exhaust, etc. etc.
We flogged late into the night Saturday night...
Sunday we made the shop owner go to work and open up, to sell us the rest of the little stuff we forgot.
By sunrise on Monday morning, we were headed to try and shower before work.
The car had gone all the way to long-block for a cleaning and head torque,
and all sub-systems were rebuilt.
The thing ran/drove/sounded like a 100% brand-new car,
And was great for daily driving for years to come.
The parts cost was around $1200 back then.
Likely about $2K now.
So,
Let it be said,
That two people in a well-equipped shop can do a 100% mechanical refresh on an aircooled VW in one weekend.
Bus Motor Build
What’s That Noise?!?
KollynnBlackpaw
PostPosted: Wed Apr 11, 2018 6:34 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Say, what's the right procedure for lifting a Type 3 just a bit? I'd really like to use those centerlines, and now that I got a flat (damn bolts laying around at work!!!! Evil or Very Mad ) I'm thinking about mounting them. The fronts fit fine, and I'll be swapping a front to the back as a spare right now, but the rears will rub with any weight in the car.
Bobnotch
Bobnotch is offline
PostPosted: Thu Apr 12, 2018 11:03 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
Look in the lowering thread, and do the opposite of the lowering part in it. By that I mean instead of re-indexing the trailing arm up (to lower) you re-index the trailing arm down. By trailing arm, I mean the spring plate.
Tram wrote:
Tram wrote:
Mike Fisher
PostPosted: Thu Apr 12, 2018 1:31 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
It is not that easy, but tear it apart if you don't have to drive it for 1-2 weeks? Shocked I believe you have 3 aircooled engines that need to be rebuilt too. Twisted Evil
KollynnBlackpaw
PostPosted: Thu Apr 12, 2018 8:13 pm    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
I plan on it! The spare engine for Eiche is torn apart down to the block needing split, but I gotta have a running car. The plan is to buy a new wiring harness for Frau, get that running, tear apart Blue's, get him running again, get Eiche running, rebuild Frau's engine.
Mike Fisher
PostPosted: Fri Apr 13, 2018 11:09 am    Post subject: Re: "Blue" '72 Square build from a newbie. Reply with quote
I'm just concerned that you're putting off too long rebuilding the engine in Blue that only has 20 lbs compression in one cylinder!
Page 18 of 24
