Bobnotch Samba Member
Posted: Fri Apr 13, 2018 1:20 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Mike Fisher wrote: |
I'm just concerned that you're putting off too long rebuilding the engine in Blue that only has 20 lbs compression in one cylinder! |
Yeah, you could do a quick cylinder swap (buy a set of 4 AA pistons and cylinders), pull the heads swap out the P&C's, put it all back together and run it. It might not be the best thing to do, but it'll get you back on the road.
It's either that, or find a cheap Toyota Corolla to run around in. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
KollynnBlackpaw Samba Member
Joined: October 19, 2016 Posts: 528 Location: Hubbard, Oregon
Posted: Fri Apr 13, 2018 1:36 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Bobnotch wrote: |
It's either that, or find a cheap Toyota Corolla to run around in. |
I can't have more cars!.... Ok, to be honest there's another squareback nearby that runs and drives that I might look at buying.
But! The quick swap isn't a bad idea. I might go through with that and request a extra day on a weekend *just* in case things go awry.
What's the set I need to buy for him? _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Fri Apr 13, 2018 1:48 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
KollynnBlackpaw wrote: |
Bobnotch wrote: |
What's the set I need to buy for him? |
Look on CIP's web site, as they offer sales on that sort of stuff every now and then. You want a set of 1600cc flat top pistons. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Boogievan Samba Member
Joined: October 15, 2007 Posts: 152 Location: Port Orchard, WA.
Posted: Fri Apr 13, 2018 2:19 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Bobnotch wrote: |
It's nice to have commuter bucket that you can actually get off the shelf parts for. You can easily find yourself cutting corners if you have to rush every job so you can drive to work the next day.
I have a 21 year old Volvo that's been my daily driver for seven or eight years. Best 600 dollar car ever! |
Posted: Sat Apr 14, 2018 12:02 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Yes those are what you want. I'd also add 1 of these too.
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D111%2D198%2D007%2DAF
The first pic is the charcoal canister. You can leave it alone, or remove it since it's not doing anything (it's currently disconnected).
This pic is of the cool air mixer tube for the heater system. Plug the end of the hose off unless you have a 100% complete STOCK exhaust system. For them to work, you need every part of the stock exhaust to be in place. This means stock muffler, upper pre-heaters, the 2 "C" shaped end pieces, the rubber connector joints, and the 2 steel tubes that run under the upper engine tin and ALL of the clamps. I say that, as those flexible tubes connect to the metal tubes (under the engine tin), which connect to the "C" pieces on the ends of the big cool shroud.
If you're running a header, just plug them off, to help keep dust and rodents out of the car. I think a film canister, or diabetic testing strip bottle fits perfectly as a plug. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Sat Apr 14, 2018 1:17 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
There is another charcoal canister up on the left front fender. It accumulates dirt etc and causes the inner fender to rust out! I would remove both of them. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Posted: Sat Apr 14, 2018 2:15 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Good plan! I'll do both in that case. What were they originally for?
Also will do on the gasket set - I already have a good baggie of em but I'm rebuilding the bug too so. Speaking of I just got back from my parts trip - lots of good parts for 130$! Two 40hp cases, two sets of heads and one spare, lots and lots of stuff. I'll take pictures soon. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Sat Apr 14, 2018 3:49 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Parts pickup day! He threw in some other stuff he had and took a 36HP manifold he didn't realize was in there, and lowered the price to 130 without me even asking. Very nice guy, thank you Mark!
Two crankshafts.
Rods.
Conrod set one.
Conrod set two.
Camshaft.
One head,
Two seperate sets of heads.
One set of pistons.
Three frontal tins.
Two manifolds.
Generator stand.
Cylinder tins.
Fuel pump and misc tin.
Two fans.
Two 40HP blocks and two flywheels.
Block one.
Block two.
A good haul I'd say! What can be re-used here? I'd like to try and put together something from spares while saving money and slowly getting parts for the new-parts rebuilt engine. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Sun Apr 15, 2018 8:52 am Post subject: Re: "Blue" '72 Square build from a newbie. |
Boogievan wrote: |
Bobnotch wrote: |
I've got a 92 Geo Prizm (Toyota Corolla clone) that I've been driving for 8 years now (according to the plate stickers) that I gave 500 for. Granted I've probably put another 500 into it over the last 8 years (2 exhaust systems, fuel tank, 4 tires, it adds up quickly). One of these days I might eventually do a tune up on it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Apr 15, 2018 9:58 am Post subject: Re: "Blue" '72 Square build from a newbie. |
Also will do on the gasket set - I already have a good baggie of em but I'm rebuilding the bug too so. Speaking of I just got back from my parts trip - lots of good parts for 130$! Two 40hp cases, two sets of heads and one spare, lots and lots of stuff. I'll take pictures soon. |
The charcoal canisters were to trap smog causing vapors/emissions. California started requiring it but it's nationwide now on new cars. You don't have to have them functional now on old cars. Put new pistons & cylinders on Blue and it should run a lot better/further. It would be nice to rebuild Blue's heads too while you had them off, but not mandatory if you have to drive Blue to work on Monday. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Sun Apr 15, 2018 11:45 am Post subject: Re: "Blue" '72 Square build from a newbie. |
The charcoal canisters were to trap smog causing vapors/emissions. California started requiring it but it's nationwide now on new cars. You don't have to have them functional now on old cars. Put new pistons & cylinders on Blue and it should run a lot better/further. It would be nice to rebuild Blue's heads too while you had them off, but not mandatory if you have to drive Blue to work on Monday. |
That's a good point too, the heads. What does rebuilding a head include? _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Sun Apr 15, 2018 12:27 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Our local Carquest & NAPA etc will steam clean & grind or replace the valves & valve guides etc. You can use that 40HP stuff on your Bug? _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Sun Apr 15, 2018 2:28 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Our local Carquest & NAPA etc will steam clean & grind or replace the valves & valve guides etc. You can use that 40HP stuff on your Bug? |
Yep! The stock engine and spare are 40HP 1200CC's. I'm not sure what's good and what's not, so I'm hoping some of y'all and the folks on the bug topic will be able to point me to what's good. I'll be building one engine with whatever I have laying around, to learn, and the second with 90% new parts while slowly collecting them. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Wed Apr 25, 2018 10:36 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Noticed something a little funky today - he's spitting oil back out his filltube again. He hasn't done that in quite a while (since I first mentioned it and it just went away randomly) and with the engine getting as bad as it has been I'm worried about it. I'm buying the harness and installing it for the bus this weekend since I have the extra money finally (gas is killing me!.) At that point I'll drop and quickly rebuild Blue's engine - as long as I have something to get me around. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Sat Apr 28, 2018 1:36 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Sounds like a good plan to get the Bus running before taking Blue apart!
P.S. Take down about 18 of your 23 40hp pictures as we really don't want to download/see them Every time we open your Type 3 Build Thread. _________________ https://imgur.com/user/FisherSquareback/posts
Posted: Sun Apr 29, 2018 8:00 am Post subject: Re: "Blue" '72 Square build from a newbie. |
Noticed something a little funky today - he's spitting oil back out his filltube again. |
That's called blow by. It's caused from your rings not sealing against the cylinder walls. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Sun Apr 29, 2018 10:38 am Post subject: Re: "Blue" '72 Square build from a newbie. |
Bobnotch wrote: |
That's called blow by. It's caused from your rings not sealing against the cylinder walls. |
Ah, well good thing I'm getting new everything for him soon then. The bus' harness comes first but hopefully next paycheque I can grab the pistons and cylinders for this, and have the bus up and operational. _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Tue May 08, 2018 12:24 am Post subject: Re: "Blue" '72 Square build from a newbie. |
So, turns out the bus just need a fuse that fell out for the lights to work. Who'da thunk
I'll still get a new harness eventually, but since she's driving good now I'll focus this next cheque on Blue instead. I'd much rather be driving him just due to... Well, he looks less like sh!t. I'm less likely to get pulled over for some minor issue than the bus is, cause it looks a bit like a crack van! _________________ '71 Shantung Yellow AT/FI Squareback |
Posted: Tue Jun 05, 2018 9:21 pm Post subject: Re: "Blue" '72 Square build from a newbie. |
Had fun on Saturday at the Bug Run! It was great to see you at the show, Mike! Unfortunately Blue sits right now, the next to be taken to a friend for diagnosis and hopefully fixing. If it turns out the FI is crap, then it goes. I hate to have it go, but I'd hate to let it set longer too. DON'T WORRY! He'll get fixed and driven once again! _________________ '71 Shantung Yellow AT/FI Squareback |
