Oil bath air fliter cleaner mod for dual 28PCI intakes/carbs
Joseph DR
Joseph DR is offline
PostPosted: Thu Mar 16, 2017 8:28 pm    Post subject: Oil bath air fliter cleaner mod for dual 28PCI intakes/carbs Reply with quote
I was inspired by Peter_Plade 's oil bath/filter mod so I decided to do it for my build:
https://www.thesamba.com/vw/forum/viewtopic.php?t=349628&start=60
Peter_Plade wrote:
What did you change in the air cleaners?
If you take a look at the bottom of the filter you can the flange that goes over the carb is of center, that of course to move the filter back towards the fan shroud on the stock motor otherwise it would hit the decklid.
But not having that problem I moved the carb flange so it is centered with the inside pipe, and almost works as a stack now. I can take some pics if that explains it better?
Can't tell if it's the filter or carbs, but I have less carb "noise" now than I used too.
Btw it wasn't the best day cutting up 2 original filters Confused But the end result was good!
So here is a 1959 oil bath air cleaner filter
Yes, the clip is installed wrong on one side. It will come off for powder coating.
If I use the air cleaner as is, it looks goofy because of the factory offset.
Below, I already measured, made a template and cut the filter flange on one of the oil baths.
I'll show the process I did to do this.
1964 Beetle
Joseph DR
PostPosted: Thu Mar 16, 2017 9:54 pm    Post subject: Re: Oil bath air fliter cleaner mod for dual 28PCI intakes/carbs Reply with quote
I used a postcard to make a template of the curve of the flange. Then I transferred it to the outside edge of where the flange will be moved.
With an angle grinder and wire brush attachment, I took it down to bare metal.
I traced the template with a Sharpie.
I cut it with a Dremel and cut off wheel. It's small enough to go carefully in a circle. Not perfect but I'll shape it with a body hammer. Also, I was off by 2 or 3 mm. I'll fix it.
Before: Air flow restricted.
After: Breaths a little easier.
Now I'm ready to weld r up. The one on the left is a '58. The one on the right (with a dimple) is a '59. Eight months apart.
Tack weld and body hammer to make sure both pieces are flush/even.
Finished welding the '59. I still need lots more practice.
Here's the '58 air cleaner welded up.
Grind the welds with an angle grinder. And sand even with sanding wheel thingy.
Cleaned up.
Centered. This pic was taken before I welded it.
Success! Looks cool now.
I don't want to chase pinholes, so I put a skim coat of JB Weld on it. This will ensure a seal. Tomorrow I will sand it and then it's off to the powder coater! JB Weld will withstand up to 500 F and the powder coating process.
Hope this was helpful to you. Let me know if I missed something.
1964 Beetle
Peter_Plade
Peter_Plade is offline
PostPosted: Thu Mar 16, 2017 11:10 pm    Post subject: Re: Oil bath air fliter cleaner mod for dual 28PCI intakes/carbs Reply with quote
Good job!
I'm happy to see that my previous work inspired you to do this modification 😊
Original 1954 3 fold oval
http://vw-bluehats.blogspot.com/
Lingwendil
Location: Oakley, behind enemy lines in communist California
Lingwendil is offline
PostPosted: Fri Mar 17, 2017 3:59 pm    Post subject: Re: Oil bath air fliter cleaner mod for dual 28PCI intakes/carbs Reply with quote
Cool
I'm doing this on my next dual solex build.
I actually gave one of those exact oil bath filters away a few months ago, since I was unable to find a match to it! I plan on doing up a pair with dual 40 horse oil baths, but will be replacing the snorkels with the 1500/1600 style for more breathing, and of course, the look.
73 super beetle thread!
http://www.thesamba.com/vw/forum/viewtopic.php?t=649622
How to- Modify your Kadrons for SVDA!
http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Joseph DR
PostPosted: Fri Mar 17, 2017 10:03 pm    Post subject: Re: Oil bath air fliter cleaner mod for dual 28PCI intakes/carbs Reply with quote
Thanks guys, it was a fun little project. Here's what they look like after I sanded the JB Weld:
1959 filter:
1958 filter
1964 Beetle
