DSweinhagen Samba Member
Joined: July 30, 2002 Posts: 382 Location: Phoenix, AZ
Posted: Wed Mar 29, 2017 12:03 pm Post subject: Re: 1952 Deluxe |
Thanks for the compliments, I really appreciate it. It's nice to document the car, share the work and hopefully it helps others out in the future. I know I've learned things by seeing others work on here.
So on to the cargo rocker. First I had to repair this damaged jack-point...
For whatever reason, we had never sourced a cargo rocker for this project. I ordered a W.W. one when I got the battery tray and C-pillar as they've been good lately. But I wasn't happy with the way the cargo doors were fitting up to it when latched. I had an NOS one that had an inch or so cut off each side, so I tried that and it seemed to work better. Rather than messing with the rod catches on the WW one, I fabbed some ends for the original one and used that. Here's the rocker I started with...
Here it is with the ends repaired and fit. I also smoothed out the drain dimples as I'm pretty sure an early '52 should be that way? At least I hope so.
Inner areas primed and then installed...
_________________ David S |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Wed Mar 29, 2017 2:16 pm Post subject: Re: 1952 Deluxe |
the tires make the bus. good work on the rocker _________________ regards
Uli
Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 878 Location: Cornwall, UK
Posted: Thu Mar 30, 2017 12:32 am Post subject: Re: 1952 Deluxe |
Nice. Good work!
I believe whether or not 52's had cargo dimples is still a grey area. 51 didn't. 53 did.
We just need a pic of the hornbecker sill. _________________ 1951 Samba 20-017894
1952 Samba 20-028952 |
Posted: Thu Mar 30, 2017 5:44 pm Post subject: Re: 1952 Deluxe |
Thanks LDR. I'm going to say I'm almost certain a '52 doesn't have the cargo rocker dimples... At least an early '52. It would be nice to narrow down that down some more.
Dogleg repair... There's an older repair that I'm afraid I may have had something to do with when I started on this car years back. Kind of weird fixing something I did almost 20 years ago. Anyway, it could have been cleaned up okay, but I felt it was better to make some new pieces.
wcfvw69 Samba Purist
Posted: Thu Mar 30, 2017 7:57 pm Post subject: Re: 1952 Deluxe |
Beautiful metal work right there. _________________ Contact me at [email protected]
The Samba member since 2004.
glideking Samba Member
Joined: February 02, 2013 Posts: 990 Location: California
Fifty-Eight Rag Samba Member
Joined: September 07, 2011 Posts: 936 Location: St. Louis, MO
Lazaa Samba Member
Joined: January 03, 2011 Posts: 228 Location: Voiron, France
Posted: Fri Mar 31, 2017 11:52 pm Post subject: Re: 1952 Deluxe |
Lowdown Dirty Rat wrote: |
Nice. Good work!
We just need a pic of the hornbecker sill. |
Here is it, photo of it by Gene L :
We can see the drain recess on the far left and i'm pretty sure the 52s i've had, had them as well.
Also, I think it shouldn't have the inner reinforcement between outer and inner sills.
Great bodywork though, and these NOS panels ! Wow !!
Look forward to see the next step |
Posted: Sun Apr 02, 2017 7:50 am Post subject: Re: 1952 Deluxe |
Lazaa wrote: |
Nice. Good work!
Yes, I reached out to Brendan who put me in touch with Gene and he got me a few pics including that one. Huge thanks to those guys for getting that figured out. Looks like one more thing to fix. _________________ David S |
Posted: Sun Apr 02, 2017 1:33 pm Post subject: Re: 1952 Deluxe |
So here's the original 1952 rocker detail. I wanted to make sure it was okay to post these publicly before doing so. Big thanks again to Gene for helping figure this out!! Hope this helps some others out there also.
Posted: Mon Apr 03, 2017 7:59 am Post subject: Re: 1952 Deluxe |
Finishing the right side dogleg repair. I'm treating the inner panels as best I can and coating them with epoxy and/or weld thru primer.
Checking the door for fit again and just about done with the metal work on the right side below the rain gutter...
Malokin Martin Samba Member
Posted: Mon Apr 03, 2017 8:46 pm Post subject: Re: 1952 Deluxe |
The amazing metal work aside, I admire that this thread doesn't have some long winded 10 word title about what the bus is. Just '1952 deluxe'. Classy. Keep up the great work! |
Posted: Wed Apr 12, 2017 7:50 am Post subject: Re: 1952 Deluxe |
Thanks agin for the compliments!!
So time to turn the bus around and start on the left side...
There were a few issues to sort out before I could install hardware and check the front door for fitment.
Hardware installed and door gaps are good.
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
BUCIOBATISTI Samba Member
Joined: April 17, 2002 Posts: 6956 Location: San Diego, California, USA
Posted: Wed Apr 12, 2017 8:37 am Post subject: Re: 1952 Deluxe |
EverettB wrote: |
DSweinhagen wrote: |
This is a weird area to crack, I can't remember seeing that area damaged on any other Bus. |
The exact same crack happened in the exact same spot on Rafferty's old 1954 that is over at KCW right now...
http://kustomcoachwerks.com/forums//viewtopic.php?...;start=945 _________________ Please check us out on Instagram at @holygrailgarage
That's the best place to see the latest things we are up to as well as catch an occasional sneak peek of our latest car and parts listings! |
sled Samba Member
Posted: Wed Apr 12, 2017 8:52 am Post subject: Re: 1952 Deluxe |
very nice work Dave!
with the kind of metalwork you do, you should pick up a bead roller and some quality tipping dies. Those curved flanges would be quick and easy with a set, much less work and cleaner than the welded seam method.
either way, this bus is getting the work it deserves! cant wait to see more. _________________ drive your split. |
Posted: Wed Apr 12, 2017 11:27 am Post subject: Re: 1952 Deluxe |
sled wrote: |
either way, this bus is getting the work it deserves! cant wait to see more. |
Thanks, I do have those tools... I guess I need to mess with them some more. For one off smaller pieces I usually find it's less time consuming and the fit is better doing it this way. I can fit all the pieces, weld on the flanges and go. There's some additional time in making the patterns when using the tipping die, at least for me. Whatever imperfections there are from the welded flange are usually filled in the first coat of primer. _________________ David S |
Posted: Wed Apr 12, 2017 11:40 am Post subject: Re: 1952 Deluxe |
Left side dogleg and B-pillar repair. Similar to the right. Note more of those screwdriver-punched holes...
vwhelmot Samba Member
Joined: May 04, 2006 Posts: 617 Location: united kingdom
Posted: Thu Apr 13, 2017 6:39 am Post subject: Re: 1952 Deluxe |
Nice metalwork, cudos.. |
Posted: Thu May 04, 2017 10:26 am Post subject: Re: 1952 Deluxe |
Moving along with some misc. welding, hammer and dolly work...
