1952 Deluxe
Page: Previous  1, 2, 3 ... 6, 7, 8 ... 17, 18, 19  Next
DSweinhagen
DSweinhagen is offline
PostPosted: Fri Oct 20, 2017 4:39 pm    Post subject: Re: 1952 Deluxe Reply with quote
I got the undercarriage painted. I ended up adding a little more red to the front wheel wells after I took these pics...
David S
zuggbug
zuggbug is offline
PostPosted: Fri Oct 20, 2017 5:28 pm    Post subject: Re: 1952 Deluxe Reply with quote
Looks great
SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy
EA57RHD
EA57RHD is offline
PostPosted: Fri Oct 20, 2017 8:08 pm    Post subject: Re: 1952 Deluxe Reply with quote
Absolutely beautiful work Dave. Your attention to detail is superb!
----VW's in my garage----
March 1959 Mango Standard
November 1958 Single Cab
********WANTED********
Whittier Lee Wood VW dealer license plate frame
notchboy
notchboy is offline
PostPosted: Sat Oct 21, 2017 10:28 am    Post subject: Re: 1952 Deluxe Reply with quote
Dave,
I've been loosely following this build and it looks great.
Are you restoring it to the truest sense? Like leaving over spray under and what not? I ask as it looks like it - and love it when people shoot for "as factory done".
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
djfordmanjack
djfordmanjack is offline
PostPosted: Sat Oct 21, 2017 11:04 am    Post subject: Re: 1952 Deluxe Reply with quote
Lovely! looks like this bus could have left the factory exactly that way. Very well possible. Great choice to vote against the all common resto rule and go for what the bus was really delivered!
62 Dickholmer, custom color Seeblau L360
DSweinhagen
PostPosted: Sun Oct 22, 2017 7:10 am    Post subject: Re: 1952 Deluxe Reply with quote
Yes, trying to match the original colors and overspray as it would have been done originally. I know the overspray varied widely but hopefully it's close. Once you get into the '60s there seemed to be more body color underneath and I understand if someone doesn't like the overspray look and prefers to paint the entire underneath body color. It wouldn't have seemed right on this bus though.
Thanks again guys!
David S
notchboy
notchboy is offline
PostPosted: Sun Oct 22, 2017 8:07 am    Post subject: Re: 1952 Deluxe Reply with quote
Thanks again guys!
Excellent. Good to hear it. Not enough done like this IMHO. Cool
1964 1500 S
Peter_N
Peter_N is offline
PostPosted: Sun Oct 22, 2017 9:22 am    Post subject: Re: 1952 Deluxe Reply with quote
Great attention to detail doing that overspray!
Btw, is that bodyfiller applied to the bellypans? That’s next level restauration man Applause
My 1958 PGSG project topic
DSweinhagen
PostPosted: Sun Oct 22, 2017 9:02 pm    Post subject: Re: 1952 Deluxe Reply with quote
Thanks! Yeah, I had to use body filler. While the original belly pans were solid they were pretty beat up. I pushed down what I could from the topside while the floor was out, but I was working around the heater tube, cable tubes, etc. Once on its side I used the nail puller to pull and had to do a bit of shrinking. I got it straightened out but needed filler to smooth out all the metal work. It was fairly time consuming but I'm glad we saved the pans with the original spot welds and gas welds in tact. The lower transmission tube was beat up too and took some time to straighten out.
David S
djfordmanjack
PostPosted: Mon Oct 23, 2017 1:47 am    Post subject: Re: 1952 Deluxe Reply with quote
Did you literally straighten out the transmission cradle or is this an early bus/1952 thing ? yes the cradle almost always has dings and dents from using jacks but all of my 4 53 and 54s had a bow shape to them, none as straight as yours looks now.
here's my 53 SC for comparison
Lowdown Dirty Rat
Lowdown Dirty Rat is offline
PostPosted: Mon Oct 23, 2017 2:02 am    Post subject: Re: 1952 Deluxe Reply with quote
It’s an early thing.
See http://barndoor.dk details and changes, engine suspension.
1951 Samba 20-017894
1952 Samba 20-028952
djfordmanjack
PostPosted: Mon Oct 23, 2017 2:14 am    Post subject: Re: 1952 Deluxe Reply with quote
my bad, thanks for pointing out !
DSweinhagen
PostPosted: Tue Nov 07, 2017 2:53 pm    Post subject: Re: 1952 Deluxe Reply with quote
The body is down off the rotisserie...
Starting body work on the front doors. They were clean enough I was able to metal prep and go over the old media stripping. Note the last three digits of the VIN on the doors and window frames...
David S
Lowdown Dirty Rat
PostPosted: Tue Nov 14, 2017 2:55 pm    Post subject: Re: 1952 Deluxe Reply with quote
Looks incredible! Cool
What’s the plan with the splash pan. I was thinking about this today as mines ready for paint to. What colour are they on a 52 deluxe? They are black on microbuses.
mandraks
mandraks is offline
PostPosted: Tue Nov 14, 2017 7:31 pm    Post subject: Re: 1952 Deluxe Reply with quote
how did you treat the backside of the inside pressing?
regards
Uli
DSweinhagen
PostPosted: Thu Nov 16, 2017 7:41 am    Post subject: Re: 1952 Deluxe Reply with quote
I just sanded it by hand and primed it as best I could. It's a pain, but you can in there.
David S
DSweinhagen
PostPosted: Thu Nov 16, 2017 7:49 am    Post subject: Re: 1952 Deluxe Reply with quote
Thanks. Good question on the pedal pan as I've been wondering the same thing... The one I have here is grey but not sure it's original to the car. I thought most I've seen are grey, but you've seen black? The heater baffles are black. So I like the idea of black.
David S
Lowdown Dirty Rat
PostPosted: Thu Nov 16, 2017 10:33 am    Post subject: Re: 1952 Deluxe Reply with quote
Well here is axel’s 50 - restored.
And an original.
Obviously they are not deluxes.
Anyone crawled under the hornbecker 52?
Lazaa
Lazaa is offline
PostPosted: Thu Nov 16, 2017 11:31 pm    Post subject: Re: 1952 Deluxe Reply with quote
I don't see why they would do different on deluxes on a part which is basically not visible... so I will go for black on mine too.
Also I think those black parts on deluxes are great because unexpected. Even the wiper arms, bases and blades were originally black on my 52. Idea
DSweinhagen
PostPosted: Thu Dec 07, 2017 8:17 am    Post subject: Re: 1952 Deluxe Reply with quote
I've been working on the bus, but nothing really exciting in photos... A lot of block sanding and re-priming. Here's the cargo doors and decklid back from the stripper and in primer...
David S
Page 7 of 19
