palmgreen57 Samba Member
Posted: Sat Aug 29, 2020 8:18 am Post subject: Re: 1952 Deluxe |
DSweinhagen wrote: |
RockStock wrote: |
What did you use for the padding? |
It's like a 1/4" felt/jute. I found it in an upholstery shop that was closing years ago. It's pretty close to the stuff that was used early on before they changed to the black tar-like composite. |
HI David
Do you know when they changed to the black later one?
Thanks |
DSweinhagen Samba Member
Joined: July 30, 2002 Posts: 382 Location: Phoenix, AZ
Posted: Mon Aug 31, 2020 7:34 am Post subject: Re: 1952 Deluxe |
palmgreen57 wrote: |
RockStock wrote: |
HI David
Thanks |
Sorry, I don't know when the change was. Here's what's in my '51...
_________________ David S |
Posted: Mon Aug 31, 2020 7:42 am Post subject: Re: 1952 Deluxe |
I have the rear carpet now which gave me more polishing to do and hardware to sort out...
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Mon Aug 31, 2020 9:48 am Post subject: Re: 1952 Deluxe |
So nice! Such attention to details take time and slowly making progress like you are is definitely the only way a fella can keep these projects moving forward. The owner is in good hands. Btw making the effort to post here and make notes and post pics is also a huge effort. Thank you for it, Dave!
I tired doing an update on a thread just this am and my pic landed in the gallery sideways and it was for the Barndoor brakes forum. I got frustrated and deleted the pic and went back to work. _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
EmpiGT Samba Member
Posted: Wed Sep 02, 2020 2:47 pm Post subject: Re: 1952 Deluxe |
I didn't notice did you get the speaker corner supports for the bus? Not that you can see them now. Just curious. |
Posted: Fri Sep 25, 2020 9:23 am Post subject: Re: 1952 Deluxe |
I've got some more assembly done on the '52. Mostly focusing on the undercarriage and mechanical here.
The original lever shocks appear to be in good working order, so I just cleaned and painted them, made new seals and filled with oil...
19mm master cylinder...
I didn't take a lot of pics of the undercarriage, but here's an example. Just about done running brake lines, cables, etc...
The wheels still needed to painted, so I took care of that while they were off...
The bus is back on it's wheels and most hand and foot controls are done...
I'm about as far as I can go inside until the interior guy comes through. Hopefully more on that soon...
I just got the new early pedal from Type29. Looks great, Thanks Mark! Definitely better than the old one...
von_hansel Samba Member
Joined: June 12, 2006 Posts: 635 Location: Inland Empire
Posted: Fri Sep 25, 2020 9:27 am Post subject: Re: 1952 Deluxe |
The attention to detail is impeccable! Very impressive.
I hope this bus makes a guest appearance in So Cal when it is done so I can see it in the flesh. |
Posted: Fri Sep 25, 2020 9:49 am Post subject: Re: 1952 Deluxe |
von_hansel wrote: |
Thanks! That's the plan. I'm sure we'll make it out to an OCTO at some point. _________________ David S |
obus Samba Member
Joined: March 08, 2001 Posts: 11069 Location: just off Garden State Parkway Exit 81
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
Posted: Sat Sep 26, 2020 9:20 am Post subject: Re: 1952 Deluxe |
Wheels look nice. You may want to scrape off the paint at the lug nut seats before installing them. Lug nuts can have the tendency to come loose when tightened against painted surfaces. _________________ Jack Staggs
Actual name |
bathtub57 Samba Member
Joined: August 31, 2004 Posts: 155 Location: Ascot, UK
Posted: Sat Sep 26, 2020 11:46 pm Post subject: Re: 1952 Deluxe |
What a project, this is fantastic. I wish I could be as diligent posting updates! The refurbishment and re-use of original parts is great to see. _________________ Aircooled since 1988 |
House Minutia Militia
Posted: Sun Sep 27, 2020 9:29 am Post subject: Re: 1952 Deluxe |
Thanks for the updates David, I really enjoy seeing the progress of the bus and your beautiful craftsmanship. Hope to see it some day! |
Posted: Tue Sep 29, 2020 8:43 am Post subject: Re: 1952 Deluxe |
Thanks Guys! Yeah, it's time consuming posting updates and sometimes I have to be in the right mood, as I'd usually just rather be working. I'm making a push here to get closer to the end and will do my best to keep it updated.
I got the cab door frames assembled and installed. I forgot about the latches back during the painting process, so I had to shoot those...
I also got the pop outs assembled and installed.
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2173 Location: Graz, Austria, Europe
D-train Samba Member
Posted: Tue Sep 29, 2020 1:44 pm Post subject: Re: 1952 Deluxe |
djfordmanjack wrote: |
Beautiful detail work on the door glass ! piano hinge madness !!!
Thank god, no safaris. they just don't look right in a Barndoor, imho. |
That’s the 2nd bd deluxe I’ve noticed without safaris, not that I’m looking that hard _________________ shiny paint doesnt make it worth any more |
Posted: Wed Sep 30, 2020 8:06 am Post subject: Re: 1952 Deluxe |
D-train wrote: |
That’s the 2nd bd deluxe I’ve noticed without safaris, not that I’m looking that hard |
I really try to discourage safaris these days. They're just so much work to really make fit well and operate correctly. But I agree, especially on a barndoor. I would rather not drill those holes through the window frame on a bus like this.
On a side note, would they even be correct for this bus? I'm still not aware of any bus '52 and earlier having them originally fitted. _________________ David S |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
Posted: Thu Oct 29, 2020 7:39 am Post subject: Re: 1952 Deluxe |
The interior is coming together. Thanks to Matt Miller for help with wrapping the door panels...
mr. warehouse Samba Member
Joined: February 27, 2001 Posts: 5001 Location: Nor Cal 707
Posted: Thu Oct 29, 2020 8:16 am Post subject: Re: 1952 Deluxe |
Looks great! |
wcfvw69 Samba Purist
Posted: Thu Oct 29, 2020 8:20 am Post subject: Re: 1952 Deluxe |
Wow, simply stunning work! Looks amazing. _________________ Contact me at [email protected]
The Samba member since 2004.
