Windex_ Samba Member
Joined: March 30, 2016 Posts: 30 Location: Los Angeles, CA
Posted: Sat Mar 18, 2017 12:46 pm Post subject: Vanagon Solar/ACR install with pics (Yes, another one) |
I just wanted to share this with the community. I hopes that it might help someone with their install. I spent so much time trying to figure out exactly how to do the install the way I wanted to that I actually put the install off for 3 months because I was sick of thinking about it.
In the end I probably 100+ tabs opened across 10 or more websites and had a few PMs back and forth with a VERY helpful Samba member: thatvwbusguy.
I wanted to run everything as discreetly as possible; I didn't want the wires running down the back then under the hatch, down the side into the vent, or through the actual top itself. If anyone ever sleeps up there I never wanted to hear "Oops!"
The pictures will explain most of the install itself.
Here is a parts list of everything I used. (minus cables, terminals, and screws)
Yakima 1A towers w/ 66" round bars
Yakima Artificial Gutters
Yakima Loadstops (What I secured the panels to the round bar with)
1.25" Aluminum angle to marry the 2 panels together
Renogy 200w Eclipse Kit (Panels, MPPT, Trace Meter, Wires, Fuses)
Blue Sea 5029 Fuse Block
Blue Sea 7610 SI-ACR
Blue Sea 7720 AMI/MIDI Fuse Block
Blue Sea 80a MIDI fuse
Trojan XHS30 130AH Battery
Xantrex 1000w Inverter
I found that running the wires over the hinge was the best way to keep them from being pinched by the hinge. Piece of advice, be smarter than me if you go this route; run the wires behind the hinge right after putting them through the poptop. I ran them into the van before I realized it could be a problem and had to squeeze the wires between the canvas rails and hinge. It was a P.I.T.A.
Getting the wires through the hole up top was as easy enlarging with a step bit, dropping a string with a nut tied at the end, attaching the wires to the string with a crapload of tape, and pulling it back up.
I live in Los Angeles, I figured the fan couldn't hurt if it ever gets too hot over the summer .
I drilled hole as well as one within the wall to run the wire for my trace meter. I later used a step bit to enlarge the hole.
I used a 1/2" drill-bit many times and a Dremel to make the 3" hole to flat mount my trace-meter. My cupholder was broken anyway.
Removing my broken rear heater opened up an easy access point to run the wire for my ACR.
This is the set up as it is now, I'm sure I'll be changing or cleaning things up in the future.
With the added weight, the GoWesty dampers are a life saver
Thanks for looking! |
Gruppe B Samba Member
Posted: Sat Mar 18, 2017 12:56 pm Post subject: Re: Vanagon Solar/ACR install with pics (Yes, another one) |
That is the best wire routing from the roof top solar I've yet seen on Thesamba!
I'm definitely revising my system to follow that routing. I'm presently just going thru the rear engine intakes but it messy and needs loose cable for when the top is opened.
Great post thanks! |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Sat Mar 18, 2017 4:26 pm Post subject: Re: Vanagon Solar/ACR install with pics (Yes, another one) |
Great install.
Cool H1 in the background too.
I want to mount my panel on the roof, but have a tintop. The most obvious way is to drop the wires down through the vent or hatch, but it's a long run to where I've mounted the charge controller under the driver's seat...
Any idea how to turn the display off? The backlight on mine is always on and it's annoying when sleeping in the van. |
newfisher Samba Member
Joined: January 05, 2012 Posts: 1764 Location: The wet spot--Oregon
Posted: Sat Mar 18, 2017 8:03 pm Post subject: Re: Vanagon Solar/ACR install with pics (Yes, another one) |
Nice work! +1H1 |
VanAllen_84 Samba Member
Joined: October 17, 2016 Posts: 55 Location: Ventura County
Posted: Sat Mar 18, 2017 10:18 pm Post subject: Re: Vanagon Solar/ACR install with pics (Yes, another one) |
Wow! Nice work!
I think I will have to come knocking on your door for some help once I am ready to start on this project.
Thanks for sharing! _________________ 1984 VW Vanagon Westfalia 1.9L Water-cooled (aka "Osmo") |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Sun Mar 19, 2017 11:30 am Post subject: Re: Vanagon Solar/ACR install with pics (Yes, another one) |
Nice work! I did mine very similarly. That channel behind the hinge is perfect, like it was made for a wire run. Even fishing the wires through is a tight fit at the back corner though.
I also added a loom clamp inside the back to hold the cable, then fished it through the defroster wire hole above the cabinet.
_________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
afmercure Samba Member
Posted: Fri May 19, 2017 9:54 am Post subject: Re: Vanagon Solar/ACR install with pics (Yes, another one) |
Very nice setup!
I notice you did not use the optional "start isolation" connection. Do you know if the batteries are still automatically isolated while cranking the engine?
It's not clear to me what protection that optional connection adds.
Thanks! |
Jcbabin66 Samba Member
Joined: August 14, 2017 Posts: 1 Location: Quebec, canada
Posted: Thu Sep 14, 2017 2:07 pm Post subject: Re: Vanagon Solar/ACR install with pics (Yes, another one) |
Great job!
I'm in the process right of doing something similar. I really wish you had a better picture of the attachment gismo between panel and Yakima bars.
Thanks |
jamin307 Samba Member
Joined: October 16, 2015 Posts: 82 Location: Denver, Colorado
Posted: Thu Sep 14, 2017 3:44 pm Post subject: Re: Vanagon Solar/ACR install with pics (Yes, another one) |
Jcbabin66 wrote: |
Great job!
Thanks |
I believe he used Yakima Loadstops.
http://www.roadracks.com/wp-content/uploads/2015/01/yakima-load-stops-450x506.jpg |
