jeffinohio Samba Member
Joined: February 02, 2017 Posts: 197 Location: Scio Ohio
Posted: Sat Mar 18, 2017 1:17 pm Post subject: Found a really good jack for VW engine removal |
Hey Guys,Bought this jack at Harbor Frieght for 80 bucks.It is great for removing VW engines.I just took the engine out of my Bug alone,and it worked great.No more balancing on my floor jack.It has a flat surface around 14X14,and is padded.Fits the sump perfectly.Goes around 18 inches high.
_________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1171 Location: San Angelo, Texas
Posted: Sat Mar 18, 2017 1:27 pm Post subject: Re: Found a really good jack for VW engine removal |
Find a way to lock the sump to the jack and it would work similar to the real factory one. The VW ones were a big screw jack with interchangable heads for Type 1's and later model Type 2's and 4's.
Can u get it out without taking the fan shroud off?
Outstanding!!! _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!!
hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Sat Mar 18, 2017 1:28 pm Post subject: Re: Found a really good jack for VW engine removal |
Nice! _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Sat Mar 18, 2017 1:29 pm Post subject: Re: Found a really good jack for VW engine removal |
I have one with a busted cylinder, was thinking of modifying it to lift the full height of an engine, about 75 cm.
80 bucks? Wow! Y'all don't know how good you got it! |
Posted: Sat Mar 18, 2017 1:35 pm Post subject: Re: Found a really good jack for VW engine removal |
Yes it would work with the shroud on.I was not sure I was going to pull the motor when I removed the shroud.I removed the motor while the car was sitting on the floor.Pulled it back and lowered it,then jacked the car up off of it.Nice thing is,when you raise the engine on the jack,it is the perfect height to work on while sitting on a stool.I can also roll the engine around my garage.It is very stable.Basically just like sitting on the floor.I always struggled removing the engine alone.Best 80 bucks I have spent in quite a while. _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Mar 18, 2017 2:41 pm Post subject: Re: Found a really good jack for VW engine removal |
Yes good jack got mine almost 15 years ago... What took you so long....
Posted: Sat Mar 18, 2017 2:44 pm Post subject: Re: Found a really good jack for VW engine removal |
Dale M. wrote: |
Dale |
Been away from Bugs for 20 years or so.Until the blue one followed me home.....Here I am again... _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Sat Mar 18, 2017 3:38 pm Post subject: Re: Found a really good jack for VW engine removal |
Use the coupon from the back of the current Harbor Freight circular and you get another 20% off. _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
richierich Samba Member
Posted: Sat Mar 18, 2017 5:13 pm Post subject: Re: Found a really good jack for VW engine removal |
Now that is a good idea. I'm going to pick one up this week! |
Axitech Samba Member
Joined: August 31, 2011 Posts: 1265 Location: Bucks County, Pa
Posted: Sat Mar 18, 2017 5:35 pm Post subject: Re: Found a really good jack for VW engine removal |
I have the same one.
WORD OF WARNING!!,!!!!!
If you have a deep sump installed, do something to secure the motor! I didn't. The motor did a backflip off the Jack, landed on my left. Carb, broke the manifold and the throttle linkage. I was out $500 and four months of good weather .
It is a great Jack other than that! _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Sat Mar 18, 2017 7:06 pm Post subject: Re: Found a really good jack for VW engine removal |
jeffinohio wrote: |
Yes it would work with the shroud on.I was not sure I was going to pull the motor when I removed the shroud.I removed the motor while the car was sitting on the floor.Pulled it back and lowered it,then jacked the car up off of it.Nice thing is,when you raise the engine on the jack,it is the perfect height to work on while sitting on a stool.I can also roll the engine around my garage.It is very stable.Basically just like sitting on the floor.I always struggled removing the engine alone.Best 80 bucks I have spent in quite a while. |
I always pull them with the shroud on if I can help it-
I do need one of those ATV jacks though! Nice find. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76935 Location: Sneaking up behind you
Posted: Sat Mar 18, 2017 7:09 pm Post subject: Re: Found a really good jack for VW engine removal |
Floor jack is all i've used for the past45 years.
_________________ Glenn
Member #1009
#BlueSquare |
jason Samba Member
Posted: Sat Mar 18, 2017 9:58 pm Post subject: Re: Found a really good jack for VW engine removal |
Get a bus and you can leave the dual carbs on when taking out. |
Posted: Sun Mar 19, 2017 5:35 am Post subject: Re: Found a really good jack for VW engine removal |
Axitech wrote: |
It is a great Jack other than that! |
it has anchor points on the platform section for ratchet straps,tie downs ect.I didn't use them,but after hearing this I will from now on. _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sun Mar 19, 2017 8:47 am Post subject: Re: Found a really good jack for VW engine removal |
Quote: |
anchor points on the platform section |
I have a deep sump too. This plywood cutout helped keep the engine from sliding around without straps and stuff.
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Posted: Sun Mar 19, 2017 9:18 am Post subject: Re: Found a really good jack for VW engine removal |
runamoc wrote: |
Interesting power plug.... How does it work?...
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Sun Mar 19, 2017 9:32 am Post subject: Re: Found a really good jack for VW engine removal |
[quote="Dale M."]
runamoc wrote: |
Dale |
Its one of those government subsidized power cords. Its free....just feeds itself...kind of....
I got one of the mighty jack brand (I think) motorcycle jacks about 10 years ago as well. Works well. I have a pair of bars that I put on mine longitudinally to allow holding a complete type 4 motor and trans without tipping.
Ray |
Posted: Sun Mar 19, 2017 11:09 am Post subject: Re: Found a really good jack for VW engine removal |
Dale M. wrote: |
runamoc wrote: |
Dale |
Remarkably well. I run a one 'plugin' extension cord into the short cord of the box on the stand. The stand also has a bracket that I attach one of those fluorescent lights with a magnifying glass in the middle. More light on the attached engine. It plugs into the box. Then sometimes I need to use a Dremel grinder or something on an engine getting built, or rebuilt. It can be plugged in also. Then when I have to move the stand around, I just unplug the extension cord and move the whole thing around without cords getting in the way. When no power is needed I plug it into itself. I know it looks 'weird' when it's not in use but it is convenient when used.
The picture is kinda fuzzy but you can see the light plugged in.
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
Posted: Sun Mar 19, 2017 11:15 am Post subject: Re: Found a really good jack for VW engine removal |
I wanted to take my decades-old 3-ton floor jack up north, so I recently bought for $75 on sale at HF the 3 ton Low Profile Steel Heavy Duty Floor Jack with Rapid Pump. This goes from 2 7/8 to 19 3/4 inches, so considerably more range than my old jack. Plus, I needed the 3-ton for our Yukon, and the 2-ton HF jack that goes at least 3 inches higher is about $130, and marginal for the Yukon.
http://harborfreight.com/catalogsearch/result?q=floor+jack _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
ekimthemad Samba Member
Posted: Sun Mar 19, 2017 12:49 pm Post subject: Re: Found a really good jack for VW engine removal |
I have one of those jacks for this purpose as well. The only problem I had with it was the cheap hardware in it bent at some point so that got replaced. I bought mine years ago so maybe they've gotten better since then.
Mike _________________ Remember never argue with a moron. They'll drag you down to their level and beat you with a lifetime's worth of experince. |
