shakers73 Samba Member
Joined: June 14, 2011 Posts: 820 Location: Saltville, Va
Posted: Sat Mar 18, 2017 2:11 pm Post subject: wheel house repair |
left lower wheelhouse needs some work. Question is "Does the channel need a patch or can these small holes be welded up?" My plan for the wheelhouse is to remove just enough of it and cut a patch from a repair panel from WW.
_________________ shakers73
'74 Super Beetle
'67 Beetle
Where there is no vision, the people perish. |
maskinmester Samba Member
Posted: Sat Mar 18, 2017 2:34 pm Post subject: Re: wheel house repair |
This on takes a patch - no doubt. The whole area seems heavily rusted and what left is probably very thing. Only cases where it could make sense to weld up holes is if it is very localized corrosion and area around is in good shape - then you can fill by welding. This small piece of donor metal should be fairly easy to form by hand with normally available tools - Would be a shame to use such small portion of the panel for this small job. _________________ 1954 Beetle - running - Went to HO 17
1961 Beetle in the workshop
1960 Beetle waiting for repair
1956 Unimog 411
30 old farm tractors and stationary engines
1999 Golf - daily driver |
wcfvw69 Samba Purist
Posted: Sat Mar 18, 2017 4:21 pm Post subject: Re: wheel house repair |
[quote="shakers73"]left lower wheelhouse needs some work. Question is "Does the channel need a patch or can these small holes be welded up?" My plan for the wheelhouse is to remove just enough of it and cut a patch from a repair panel from WW.
You need to open that up further to access how bad the rust is inside. That's the common spot to rust due to the debris coming off the tires, chipping the paint and rust.
You don't need that repair panel. You can buy small sheets of steel from Ace Hardware, Lowes, etc and cut and fab your own. Just get the same thickness. _________________ Contact me at [email protected]
The Samba member since 2004.
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Sat Mar 18, 2017 8:13 pm Post subject: Re: wheel house repair |
Heater Channel repair sections are available if the rest of the Heater Channel checks out good. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
Posted: Sun Mar 19, 2017 3:00 pm Post subject: Re: wheel house repair |
Thanks for the links. BTW, it is a curved windscreen super beetle. The photo is of a small section near the A pillar. Struts are not visible in this photo. _________________ shakers73
'74 Super Beetle
'67 Beetle
Posted: Sun Mar 19, 2017 5:54 pm Post subject: Re: wheel house repair |
I thought your wheel housing repair panel was for a standard. I'll have to remember that there is a piece available that is not the entire wheel housing. I have a 72 that needs that work done as well. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
