GPM Samba Member
Joined: February 21, 2008 Posts: 133 Location: Leicestershire, UK
Posted: Sun Mar 19, 2017 2:36 pm Post subject: Corvair/IRS set ups |
Guys,
I've a few questions about the above.
Before i get to those, a little about my set up. 64, 110 Corvair engine, rebuilt, running standard rotation using a swing axle chassis/gearbox with a flipped diff.
Looking ahead to where I'd like to be with my buggy, I'd love to run it with IRS. Can only be a huge benefit in a shortened pan with all that weight at the rear (bit like a pendulum at the moment!) Porsche arms, brakes etc.
Now, problem i have is i don't think a diff can be flipped in an IRS box, unless it's an early one with twin side plates? Please correct me if I'm wrong one that front. From that, I'll assume that all of you running Vair's have reversed the rotation of the engine to allow it to run with a STD IRS box? Again, tell me if I'm wrong.
The answers to those questions will tell me where i go next with this as a project.
Thanks,
Ben |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Sun Mar 19, 2017 2:49 pm Post subject: Re: Corvair/IRS set ups |
The dual side cover IRS transaxles are the one to use for flipping the ring gear.
I'm currently in process of flipping IRS ring gear for a standard rotation Corvair swap. You do understand that the 1-4 gears will be running opposite of the way they were designed to run? So I'd recommend that you have a good look at the gears on any transaxle used to see what you are starting out with. And don't Hammer the trans too hard...
The camshafts & bits required to reverse rotate the Corvair engine are not that commonly available these days. Clark's Corvair has some of the required goodies, but they are spending. Also, general consensus is that you should change the orientation of all the Pistons so that they will work more effectively with the reverse rotation. Which means tearing down the engine...
Bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
joescoolcustoms Samba Member
Posted: Sun Mar 19, 2017 6:23 pm Post subject: Re: Corvair/IRS set ups |
A buddy went reverse rotation on a Corvair Engine for the one intent that if he had a issue out on the road, a VW engine would be easier to get ahold of and swap in so he could drive it back home. (speaking of cross continent tripping). _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
JOHN D Samba Member
Joined: April 21, 2004 Posts: 67 Location: Dunbar, West Virginia
Posted: Mon Mar 20, 2017 4:08 am Post subject: Re: Corvair/IRS set ups |
On flipping the ring gear (only in dual side cover tranny cases) - consider using a Rhino case or a gusseted case since that will be a big weak point. Standard case was not designed to take that kind of load and have seen many RGB tranny's crack across the top of the case . Also use the late model gears (super beetle shaft) from a single side cover tranny - they are heavier and would take the load better |
isucorvair Samba Member
Posted: Mon Mar 20, 2017 10:32 am Post subject: Re: Corvair/IRS set ups |
or....ditch the VW pan all together, and find a Turchan, or Warshawski/JC Whitney frame set up for 65-69 Corvair rear suspension
Eric P.
DeWitt, IA
Corvair Manx, in process. |
GPM Samba Member
Posted: Mon Mar 20, 2017 12:28 pm Post subject: Re: Corvair/IRS set ups |
Thanks for the advice thus far guys.....
Remember, I'm in the UK. Finding the engine was hard enough, never mind a Vair ready chassis! |
Posted: Mon Mar 20, 2017 3:21 pm Post subject: Re: Corvair/IRS set ups |
JOHN D wrote: |
Single side cover transaxles can be flipped, but take extra clearancing work internally. And reassembly is interesting...
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
JOHN D Samba Member
Posted: Wed Mar 22, 2017 5:50 am Post subject: Re: Corvair/IRS set ups |
Yes -- but not for the weary first timers - not worth the extra time and expense - nothing gained for the trouble.
John |
