Wheel cylinder question ?? replacing 4 bolt with 2 bolt
Tim MacDonald
Tim MacDonald is offline
PostPosted: Sun Mar 19, 2017 7:09 pm    Post subject: Wheel cylinder question ?? replacing 4 bolt with 2 bolt Reply with quote
I have been reading and just want to confirm this before I order new wheel cylinders. I have a 53 with 4 bolt wheel cylinders on all 4 corner. From what I understand I can put on 2 bolt wheel cylinders with no modification. These are the ones I am looking at buying.
http://store.concept1.ca/Whl-Cyl-T1-52-57-Front-113611055/
http://store.concept1.ca/Whl-Cyl-T1-52-57-Rear-113611053/
61 so34 flip seat
78 automatic champagne Westfalia
84 mint original paint westfalia
57 oval project barn find
88 cabriolet
Mr. OGPaint
Mr. OGPaint is offline
PostPosted: Sun Mar 19, 2017 7:35 pm    Post subject: Re: Wheel cylinder question ?? replacing 4 bolt with 2 bolt Reply with quote
This swap is easy and direct and very common. 4-bolt wheel cylinder rebuild kits cost about $4 per wheel, it is a very simple process if you have core wheel cylinders
https://instagram.com/mr.ogpaint
Patrick Hall
Tim MacDonald
PostPosted: Sun Mar 19, 2017 7:39 pm    Post subject: Re: Wheel cylinder question ?? replacing 4 bolt with 2 bolt Reply with quote
Cool. Just looking for a quick fix to get it running and driving for now. Its a big project and I won't be throwing away the 4 bolt stuff or anything original for that matter
61 so34 flip seat
88 cabriolet
ToolBox
ToolBox is offline
PostPosted: Mon Mar 20, 2017 9:29 am    Post subject: Re: Wheel cylinder question ?? replacing 4 bolt with 2 bolt Reply with quote
I use Brake Material and Parts to rebuild stuff that is not common or unobtainium.
http://www.brakematerialsandparts.webs.com/
obieoberstar
obieoberstar is offline
PostPosted: Mon Mar 20, 2017 6:50 pm    Post subject: Re: Wheel cylinder question ?? replacing 4 bolt with 2 bolt Reply with quote
Thanks for the tip on Brake Material and Parts. Some local places here that do hoses will not do DOT brake lines.
